BIM Workbench
Re: BIM Workbench
I think I found the problem. I downloaded the appimage from the FreeCAD main site and the IFC properties buttons worked. But I think the ppa 2:0.18.4+dfsg1~201911060029~ubuntu18.04.1, dated 2019-11-06, may have a bug in it that prevents these buttons from becoming active.
Re: BIM Workbench
I replaced the version 0.18.4 with the latest daily build (0.19~pre2~202003311403~ubuntu18.04.1). Now the Ifc Elements Manager tool buttons show up in the BIM workbench, so that problem is solved. However, I cannot draw walls using either the Arch or BIM workbenches. When FreeCAD starts, I get an error message that says, "During initialization the error "No module named 'DraftSnap'" occurred in /home/cheroki/.FreeCAD/Mod/flamingo/InitGui.py
Please look into the log file for further information." When I try to draw a wall in either the Arch or BIM workbench, I get an error message that says, "Running the Python command 'Arch_Wall' failed:
File "/usr/share/freecad-daily/Mod/Arch/ArchWall.py", line 235, in Activated
import DraftTrackers
No module named 'DraftTrackers'
Is there a simple fix? Thanks!
Re: BIM Workbench
See Wall command fails in FreeCAD_0.19.20310-Win-Conda.
For Flamingo and Dodo, as they are external workbenches, please contact the author of that workbench and tell him to update his code to the latest version of Draft.
Edit: I forgot, the issue of DraftSnap is already solved upstream, in pull request #4.When FreeCAD starts, I get an error message that says, "During initialization the error "No module named 'DraftSnap'" occurred in /home/cheroki/.FreeCAD/Mod/flamingo/InitGui.py
Get the latest code of dodo. You shouldn't be using Flamingo as it's basically obsoleted by Dodo.
Re: BIM Workbench
Looks like the latest Draft code merges are effecting other workbenches that rely on Draft code. Try for the sake of experimentation, uninstalling the Flamingo external workbench. Restart and see if you see the issue.neophyte1 wrote: ↑Wed Apr 01, 2020 12:33 am I replaced the version 0.18.4 with the latest daily build (0.19~pre2~202003311403~ubuntu18.04.1). Now the Ifc Elements Manager tool buttons show up in the BIM workbench, so that problem is solved. However, I cannot draw walls using either the Arch or BIM workbenches. When FreeCAD starts, I get an error message that says, "During initialization the error "No module named 'DraftSnap'" occurred in /home/cheroki/.FreeCAD/Mod/flamingo/InitGui.py
Note: we need to let the @oddtopus about possible changes that may effect his workbenches. FYI, Flamingo has been superceded by dodo workbench (with is Python3/Qt5 compliant). So better to test Dodo WB and remove Flamingo WB all together.
Re: BIM Workbench
I uninstalled Freecad and installed today's latest daily build (0.19~pre2~202004011358~ubuntu18.04.1), and I uninstalled the Flamingo workbench and installed the Dodo workbench. Everything seems to be working right now. Thanks much!Looks like the latest Draft code merges are effecting other workbenches that rely on Draft code. Try for the sake of experimentation, uninstalling the Flamingo external workbench. Restart and see if you see the issue.
Re: BIM Workbench
Indeed there is a big code refactor of the Draft WB going on (on which several others depend), that can affect many other workbenches. However these changes are much needed and will make all future development much easier and faster. So we need a bit of patience until it is finished...
For your issue however, usually if a button is greyed out it is because there is no document open or there is another command running
Re: BIM Workbench
Trying to check again the ArchSchedule and happen to find there is a Quantity Manager !
It is noted there is a remark indicates ' Length, Width and Height can be changed here...' and it looks great ! It is much easier to organise than the Window Manager, which though organise all Windows / Doors in a single view, only allow change of attribute one by one.
In fact, if this Schedule / Table can be customised and become an object that can be insert into ArchView / TechDraw, it will help making production drawings ?
p.s.
It seems there are a few bugs noted e.g. when BIM is installed and run, it complains 'Rebar' is missing, needs to install 'Reinforcement' and then BIM runs.
Quantity Manager
Window Manager
Common Window / Door Schedule format found online
Re: BIM Workbench
p.s.
And I had tested some time ago a Macro to list out ArchSpace, this included some attributes like SpaceType, Finishes of Wall, Floor and Ceiling, Floor Thickness.
Wonder if / how these should be included in the Quantity Manager. And if every Arch/BIM object list their unique attributes in the Quantity Manager, the columns will be soon used up.
The Quantity Manger Table Layout is just excellent to fill out / edit all the attributes in a flat model manner !
Re: BIM Workbench
The missing rebar WB error in BIM is fixed already.
The Quantities manager is originally made only for IFC export... But you are right, it could become much more. And indeed exporting it (or bidirectionally link it) to a spreadsheet is a pretty interesting idea...
A tool that lists spaces and their properties is also interesting...
Re: BIM Workbench
Now, I try to see how far I can use the Information available in the model to do something like a Construction Drawing, Door Schedule etc.
I had a number of Clones to same Door in the Villa Savoye Model, each of them with a Tag W14, W15 etc. DLabel can show their Tag on the model, OK. So far, DLabel can show their Height, Width, Label etc...
Picking up from what I left 2 years ago Arch Window/Door - Identification of 'Inside / Outside' + Finishes & Material + Hinge Offset... Seem still kind of difficult just want to show e.g. the Materials / Thickness of Door Frame, Door Panel, Window Frame, Glass Panel ?
Any idea ? Thanks.
