Wall fails to form using closed dwire
I am experiencing some unusual results when making a wall from a closed dwire shape. Using the multipoint draftwire button I construct a
closed shape and then press the wall button. The wall appears in the combo view but not in the 3D view.
When I try the same procedure using an open dwire it works correctly except for the gap. Using a slightly overlapping dwire it seems to work correctly also but if the overlap is to much the wall has a large open space in it. Has anyone else had this problem?
Re: Wall fails to form using closed dwire
Maybe something related...Dgingrey wrote: ↑Thu Mar 29, 2018 9:35 pm I am experiencing some unusual results when making a wall from a closed dwire shape. Using the multipoint draftwire button I construct a
When I try the same procedure using an open dwire it works correctly except for the gap.Wall from Open Dwire.PNG
https://forum.freecadweb.org/viewtopic. ... 79#p173635 ArchWall Creation Problem on Sketch
EDIT:
It seem however i have no problem on a closed DWire .... MakeFace option should have been 'False' right? (should be as no face in screenshot.)
Maybe you can share your file.
Version: 0.17.13452 (Git)
Hash: 34633c144de9133c1f9aeb7da783f369cae9bfaf
Python version: 2.7.14
OCC version: 7.1.0
Make Face was set to false. Here is a screen shot of the wall formed when the dwire is open and overlapped too much. Also attached is an example of the file using a closed dwire as a basis for the wall.
OCC version: 7.1.0
- Closed Dwire Wall v17.FCStd
- (15.32 KiB) Downloaded 60 times
Some thoughts:-
- DraftWire has some bug - see screenshot. See if Yorik (creator of Arch + Draft WB to my understanding) may help.
- I copy the Wire and offset it, 1 point seem Stick to Origin
- I edit Wire and move a point, the wire do not move
See first 3 pictures below + File. I do not use Draft a lot so I am not acquaint with its function and usage in fact.
yorik wrote: - ArchWall does not like the way the start and end edge connect in linear manner... ?
Add, usually you do not need to draw the 'last' edge to close, just click close in Draw Wire diaglog, or select Close...
ArchWall works afterwards
- Closed Dwire Wall v17__Test.FCStd
- (15.57 KiB) Downloaded 44 times
Hi
OS: Ubuntu 16.04.4 LTS
Version: 0.17.13472 (Git)
Build type: None
Hash: 7fd1e543febced04e779bda3debb7fbfdee7ffa3
Python version: 2.7.12
OCC version: 7.1.0
Talking about Draft Wire, everything seems to work fine here. Please, post your version
Build type: None
OCC version: 7.1.0
Forgot the info:
Mainly latest AppImage on Fedora
The file / Wire Dgingrey work on has some weird problem, you may try (the file I attached has modified it).
FreeCAD_0.17.13472.glibc2.17-x86_64.AppImage
OS: Linux
Version: 0.17.13472 (Git) AppImage
Build type: None
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Locale: English/HongKong (en_HK)
Good morning @paulle
- edit point and the close option of a DWire is working
- the offset of a DWire is working
Please, revisit your workflow with this tools.
I didn't test the walls.
PD: Divide and conquer
The tests better with a clean document. Tested the DWire I can confirm you that:
After further testing there seems to be a problem with the forming of the dwire.
way it appears in the 3D view. Looking at the combo view the end point is at -8yd, 0,0 not 0,0,0 as it was drawn.
When I correct the end point in the combo view to 0,0,0 the 3D view changes to this: If I draw the dwire starting at -8 yd,0,0 and ending at -8 yd,0,0 it works correctly and the wall forms as expected.
I drew the dwire starting at the origin and placed the vertices in a counter clockwise rotation and ended back at the origin which is theway it appears in the 3D view. Looking at the combo view the end point is at -8yd, 0,0 not 0,0,0 as it was drawn.
good evening @Dgingrey and @paulle
To my understanding
It doesn't seem an appealing proceed
To my memory, there was a function which deals with the 'aligned edges' or 'intermediate vertices'. Perhaps it can not resolve the situations when the two 'aligned edges' are the first and the last edges of the Dwire.
I see that you know the 'right hand' rule.
There is another main rule: 'lower left point'. You follow this rule when
- you can draw your wall
- for me it is not clear that this must be 'solved', or on the contrary, the user must follow some orthodox rules
To my understanding
It's correct. In "End" must appear the last point before "Start"
Obviously, you can do this and the DWire doesn't break. Simply you have eliminated an edge.
Conclusions:
Hi!
Thanks!
Should that 'last point before start be 0,7.33,0? (rather than -8yd, 0,0 or 0,0,0)
I do not quite remember where I might have read the FC 'right hand' rule? and more explanation of 'lower left point;\'? Can you help pointing it out?damian wrote:
There is another main rule: 'lower left point'. You follow this rule whenDgingrey wrote: If I draw the dwire starting at -8 yd,0,0 and ending at -8 yd,0,0 it works correctly and the wall forms as expected.
Thanks!
