Wall fails to form using closed dwire
Dgingrey
Postby Dgingrey » Thu Mar 29, 2018 9:35 pm
I am experiencing some unusual results when making a wall from a closed dwire shape. Using the multipoint draftwire button I construct a
closed shape and then press the wall button.
Wall from Closed Dwire.PNG (136.19 KiB) Viewed 479 times
The wall appears in the combo view but not in the 3D view.
When I try the same procedure using an open dwire it works correctly except for the gap.
Wall from Open Dwire.PNG (140.6 KiB) Viewed 479 times
Using a slightly overlapping dwire it seems to work correctly also but if the overlap is to much the wall has a large open space in it.
Wall from overlapped Dwire.PNG (141.97 KiB) Viewed 479 times
Has anyone else had this problem?
paullee
Re: Wall fails to form using closed dwire
Postby paullee » Fri Mar 30, 2018 1:04 am
When I try the same procedure using an open dwire it works correctly except for the gap.Wall from Open Dwire.PNG
Maybe something related...
https://forum.freecadweb.org/viewtopic. ... 79#p173635 ArchWall Creation Problem on Sketch
EDIT:
It seem however i have no problem on a closed DWire .... MakeFace option should have been 'False' right? (should be as no face in screenshot.)
Maybe you can share your file.
Screenshot from 2018-03-30 09-07-39.png (197.59 KiB) Viewed 469 times
Dgingrey
Postby Dgingrey » Fri Mar 30, 2018 4:14 am
Version: 0.17.13452 (Git)
Hash: 34633c144de9133c1f9aeb7da783f369cae9bfaf
Python version: 2.7.14
OCC version: 7.1.0
Make Face was set to false. Here is a screen shot of the wall formed when the dwire is open and overlapped too much.
Wall from overlapped too much Dwire.PNG (146.41 KiB) Viewed 461 times
Also attached is an example of the file using a closed dwire as a basis for the wall.
Closed Dwire Wall v17.FCStd
(15.32 KiB) Downloaded 7 times
paullee
Postby paullee » Fri Mar 30, 2018 12:09 pm
Make Face was set to false. Here is a screen shot of the wall formed when the dwire is open and overlapped too much.Wall from overlapped too much Dwire.PNG
Some thoughts:-
  1. DraftWire has some bug - see screenshot. See if Yorik (creator of Arch + Draft WB to my understanding) may help.
    - I copy the Wire and offset it, 1 point seem Stick to Origin :!: :?:
    - I edit Wire and move a point, the wire do not move :!: :?:
    See first 3 pictures below + File. I do not use Draft a lot so I am not acquaint with its function and usage in fact.
    yorik wrote:
  2. ArchWall does not like the way the start and end edge connect in linear manner... ?
    Add, usually you do not need to draw the 'last' edge to close, just click close in Draw Wire diaglog, or select Close...
    ArchWall works afterwards
Hope it helps.
Screenshot from 2018-03-30 20-04-20.png (210.3 KiB) Viewed 443 times
Screenshot from 2018-03-30 20-04-11.png (228.78 KiB) Viewed 443 times
Screenshot from 2018-03-30 19-54-34.png (182.52 KiB) Viewed 443 times
Screenshot from 2018-03-30 20-02-15.png (148.67 KiB) Viewed 443 times
Closed Dwire Wall v17__Test.FCStd
(15.57 KiB) Downloaded 8 times
damian
Postby damian » Fri Mar 30, 2018 3:40 pm
Hi
Talking about Draft Wire, everything seems to work fine here. Please, post your version
OS: Ubuntu 16.04.4 LTS
Version: 0.17.13472 (Git)
Build type: None
Hash: 7fd1e543febced04e779bda3debb7fbfdee7ffa3
Python version: 2.7.12
OCC version: 7.1.0
paullee
Postby paullee » Fri Mar 30, 2018 10:54 pm
Hi
Forgot the info:
Mainly latest AppImage on Fedora
The file / Wire Dgingrey work on has some weird problem, you may try (the file I attached has modified it).
FreeCAD_0.17.13472.glibc2.17-x86_64.AppImage
OS: Linux
Version: 0.17.13472 (Git) AppImage
Build type: None
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Locale: English/HongKong (en_HK)
damian
Postby damian » Sat Mar 31, 2018 11:02 am
Good morning @paulle
The tests better with a clean document. Tested the DWire I can confirm you that:
- edit point and the close option of a DWire is working
- the offset of a DWire is working
Please, revisit your workflow with this tools.
I didn't test the walls.
PD: Divide and conquer
Dgingrey
Postby Dgingrey » Sun Apr 01, 2018 2:37 pm
After further testing there seems to be a problem with the forming of the dwire.
Wall from Closed Dwire.PNG (136.19 KiB) Viewed 323 times
I drew the dwire starting at the origin and placed the vertices in a counter clockwise rotation and ended back at the origin which is the
way it appears in the 3D view. Looking at the combo view the end point is at -8yd, 0,0 not 0,0,0 as it was drawn.
When I correct the end point in the combo view to 0,0,0 the 3D view changes to this:
Dwire with corrected end point.PNG (75.75 KiB) Viewed 323 times
If I draw the dwire starting at -8 yd,0,0 and ending at -8 yd,0,0 it works correctly and the wall forms as expected.
Dwire started from non origin point.PNG (120.39 KiB) Viewed 323 times
damian
Postby damian » Sun Apr 01, 2018 5:11 pm
good evening @Dgingrey and @paulle
To my understanding
It's correct. In "End" must appear the last point before "Start"
Obviously, you can do this and the DWire doesn't break. Simply you have eliminated an edge.
It doesn't seem an appealing proceed
To my memory, there was a function which deals with the 'aligned edges' or 'intermediate vertices'. Perhaps it can not resolve the situations when the two 'aligned edges' are the first and the last edges of the Dwire.
I see that you know the 'right hand' rule.
There is another main rule: 'lower left point'. You follow this rule when
Conclusions:
- you can draw your wall
- for me it is not clear that this must be 'solved', or on the contrary, the user must follow some orthodox rules
paullee
Postby paullee » Sun Apr 01, 2018 10:47 pm
Hi!
To my understanding
Should that 'last point before start be 0,7.33,0? (rather than -8yd, 0,0 or 0,0,0)
Dgingrey wrote: If I draw the dwire starting at -8 yd,0,0 and ending at -8 yd,0,0 it works correctly and the wall forms as expected.
I do not quite remember where I might have read the FC 'right hand' rule? and more explanation of 'lower left point;\'? Can you help pointing it out?
Thanks!
