Can't create a wall at all
udav441
Postby udav441 » Wed May 16, 2018 7:43 am
Note: this does NOT correspond to https://forum.freecadweb.org/viewtopic.php?f=23&t=27862
When I start a Arch workbench I can't create a wall.
When I try to draw a wall directly, CAD shows a wall during dragging it. And when I finish the wall it disappeers at all.
When I draw a line first and then try to create a wall via icon "Add Wall" CAD do nothing and throws and exception in status line.
I've tried it on two Win7 system 32bit and 64 bit.
This errors occurs on all 0.17 subversions that I used. 0.16 works fine. System cleaning didn't help.
Action 1:
Select Arch workbench
Draw line
Select line
Press "Add Wall" icon
Result 1:
Running the Python command 'Arch_Wall' failed: Traceback (most recent call last): File "C\Program Filees\FreeCAD 0.17\Mod\Arch\ArchWall.py", line 194, in Activated FreeCAD.ActiveDocument.openTransaction(translate("Arch","Create Wall")) Unknown C++ exception
Action 2:
Begin Wall
End Wall
Result 2:
Appers nothing
Additional Information
OS: Windows 7
Version: 0.17.13522 (Git)
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.14
OCC version: 7.2.0
Locale: Russian/RussianFederation (ru_RU)
Tags No tags attached.
DeepSOIC
Re: Can't create a wall at all
Postby DeepSOIC » Sat May 19, 2018 9:23 am
Hi!
Are you using FreeCAD with interface language set to Russian? If so, it would be nice if you check in English too. There are some problems with non-English interfaces.
udav441
Postby udav441 » Sat May 19, 2018 3:10 pm
Damn! This is the first thing I sould try.
Yes, GUI is set to Russian.
Yes, it helps me to change lanuage to English.
Thank you!
DeepSOIC
Postby DeepSOIC » Sat May 19, 2018 3:29 pm
I noticed you created issue #0003478. I'm pretty sure this problem was already reported, but I can't find it.
yorik
Site Admin
Postby yorik » Mon May 21, 2018 3:13 pm
this is strange... Normally openTransaction() accepts unicode (App/DocumentPyImp.cpp L327) since quite some time, but I see now that this code uses a wrong encoding (Latin1 instead of UTF8) which indeed must give problems with non-latin characters.
This is now fixed in git commit 4f5e304d6 (backported to the 017 release branch too)
Dgingrey
Postby Dgingrey » Wed May 23, 2018 3:40 pm
I'm having the same problem, see issue # 3423.
I have tried installing FreeCad v0.17 on 5 different machines running Windows 10 both 32 bit.
At first I thought it might be the 32 bit version of Windows but after upgrading to the 64 bit
version I still get an error when trying to create a wall. One of the machines I tried it on is set up for
dual booting for Windows 7 or Windows 10. FreeCad v17 works correctly when I boot Windows 7 but
not when I boot Windows 10. When I try and create the wall from scratch or from a d-wire and exception is thrown
and the 3D view freezes up but the wall is shown to have been created in the combo view. The 3D view cannot be
manipulated until the wall is deleted in the combo view. Then manipulation of the 3D view returns to normal.
