[PR] [0.18] [0.19_pre] Arch Stair - More Geometry Control? Profile Generator
paullee
Re: [PR] Arch Stair - More Geometry Control? Opening at Floor?
Postby paullee » Mon Dec 31, 2018 10:57 pm
Thanks!
Happy New Year 2019 to All!
There seems quite some bugs to fix ... :lol:
Screenshot from 2019-01-01 06-47-24.png (175.37 KiB) Viewed 746 times
paullee
Re: [PR] [0.18] Arch Stair - More Geometry Control? Opening at Floor?
Postby paullee » Tue Jan 01, 2019 12:06 am
Seem good start for 2019 :)
Screenshot from 2019-01-01 08-05-55.png (292.22 KiB) Viewed 741 times
paullee
Postby paullee » Tue Jan 01, 2019 1:08 am
Maybe nobody need a landing like these... just for fun ? :D
Screenshot from 2019-01-01 08-21-18.png (320.84 KiB) Viewed 736 times
Screenshot from 2019-01-01 08-31-14.png (265.13 KiB) Viewed 736 times
paullee
Postby paullee » Wed Jan 02, 2019 6:37 am
yorik wrote:
A 'side-effect' during 'debugging tests' - found 'sort-of-bug' / 'unreliable' in Part.sortEdges(), that may related to ArchWall Creation 'bugs' I reported occasionally :!: :?:
  1. I used Part.sortEdges() in the current job for curvilinear landing (see code below)
  2. Notice some edges in Sketch's Shape.Edges in obj.Base OCCASIONALLY become missing after Part.sortEdges()
  3. Resulted in missing final edges, then part of the landing
  4. Recompute the Sketch, then it is back (similar 'syndrome' as ArchWall Creation 'bug'
  5. Not yet tested Draw / Part Wire
Before any other idea, I may just keep using Part.sortEdges(), need recompute() occasionally
Or should also ping @abdullah, @realthunder who seems have discussed something about Part.sortEdges() if my memory is correct ?
Code
    print (obj.Base.Shape.Edges)
    ## TODO - Found Part.sortEdges() occasionally return less edges then 'input'
    edges = Part.sortEdges(obj.Base.Shape.Edges)[0]	## TODO - same result as edges = obj.Base.Shape.OrderedVertexes ?
    print (edges)
Output in Report - Missing Edges after sortEdges()
DEBUG - 2019.1.2
[<Edge object at 0x7650170>, <Edge object at 0x7021c60>, <Edge object at 0x6be4a60>, <Edge object at 0x43e89e0>, <Edge object at 0x72032d0>]
[<Edge object at 0x7b44ae0>, <Edge object at 0x72032d0>, <Edge object at 0x7b8bd80>, <Edge object at 0x8c74ca0>]
'Output' of Shape / Landing - Missing 1 last Landing
Screenshot from 2019-01-02 14-07-23.png (177.73 KiB) Viewed 706 times
Now... recompute()
'Output' of Shape / Landing - After Recompute() - All edges / landing normally come back
Screenshot from 2019-01-02 14-07-39.png (209.71 KiB) Viewed 706 times
yorik
Site Admin
Postby yorik » Wed Jan 02, 2019 8:02 pm
Would you be able to produce a test file with a sketch that presents the problem? Otherwise it's hard to debug...
paullee
Postby paullee » Sat Jan 05, 2019 9:35 am
Yes, see if I can single out what is before and after... or it is other problem in sketch...
hammax
Postby hammax » Sat Jan 05, 2019 10:29 am
… will there also be sometime a "simple" way to design stairs in / around a corner?
Or only the section between the straight stair parts. E.g. a section of a spiral staircase cut with a cube?
SpiralStCase.FCStd
FC.18.15536
(30.54 KiB) Downloaded 22 times
paullee
Postby paullee » Sat Jan 05, 2019 12:05 pm
Not sure I understand you. For simple right angle turn stairs, something like this?
Just 3 sketches with 3 lines, select them in order, and press ArchStairs button :)
.... found some bugs in the progress, good for debugging :D
Screenshot from 2019-01-05 19-58-19.png (118.63 KiB) Viewed 619 times
Screenshot from 2019-01-05 19-58-55.png (199.76 KiB) Viewed 619 times
Test_ ArchStairs_ 1.fcstd
(62.29 KiB) Downloaded 20 times
hammax
Postby hammax » Sat Jan 05, 2019 3:13 pm
… I was looking for an easy / closed procedure to model something like this kind of staircase.
SpiralStCase3.FCStd
FC.18.15536
(50.07 KiB) Downloaded 22 times
yorik
Site Admin
Postby yorik » Sat Jan 05, 2019 7:07 pm
But this file doesn't show the problem of the result of sortEdges() missing some edges... That's what would be interesting
