[PR] [0.18] [0.19_pre] Arch Stair - More Geometry Control? Profile Generator
paullee
Re: [PR] Arch Stair - More Geometry Control? Opening at Floor?
Postby paullee » Sat Jan 05, 2019 10:25 pm
@Yorik, no it doesn't show 'sketch + sortEdges() problem', i use another workflow.... lazy to capture the moment and debug what exactly is wrong at the moment :)
paullee
Postby paullee » Sat Jan 05, 2019 10:48 pm
hammax wrote:
Sat Jan 05, 2019 3:13 pm
… I was looking for an easy / closed procedure to model something like this kind of staircase.
Ok understand now :)
There seems some macros available, not sure if they are still valid, and some other video / tutorial for that...
But no simpler direct solution to my understanding... in ArchStairs, there is a Winder property but it was not implemented.
.... Seems there are so many different design that 'pre-built' models may not likely be available to fit. On one hand, it needs resources to build codes / template for different models, and on the other problems in adding parameters to allow variations. I have not used Revit etc. but peoples like Regis, Yorik pointed out the problems and complexity in using those stairs tools.
... Maybe another approach, and hopefully not another series of problem, thinking if tools here whilst can produce the model, also produce underlying sketches so users can tweak the sketches to produce custom design model - discussion in Civil Engineering thread... maybe that are other complexities.
https://www.freecadweb.org/wiki/Macro_Half_turn_stairs
https://www.freecadweb.org/wiki/Macro_Stairs
https://www.youtube.com/watch?v=tBO-Bk7NYAs
https://www.youtube.com/watch?v=mNdwYBBSPQw
hammax
Postby hammax » Sun Jan 06, 2019 7:12 am
… thanks paullee.
Now it is simple enough. => the last YouTube link showed/reminded me to use the "z-interval axis" feature.
( I hope to never forget it again…)
Final version (no more "stairs")
Treppe.FCStd
FC.18.15572
(51.74 KiB) Downloaded 18 times
paullee
Re: [PR] [0.18] Arch Stair - More Geometry Control? Opening at Floor?
Postby paullee » Sun Jan 20, 2019 1:43 am
paullee wrote:
Sat Jan 05, 2019 12:05 pm
.... found some bugs in the progress, good for debugging :D
Railing disposition is not correct when Align is "Right" :(
Fixed now :)
Screenshot from 2019-01-20 09-40-36.png (251.45 KiB) Viewed 529 times
Screenshot from 2019-01-20 09-28-40.png (248.83 KiB) Viewed 529 times
Renato Rebelo
Postby Renato Rebelo » Mon Feb 04, 2019 11:54 pm
Hello
the stair-building tool is getting really powerful, but as I experimented, I discovered a missing feature, the thickness of the riser.
it would be nice to add this property.
thank you,
Renato Rebelo
my native language is not English, please excuse me any incorrectness, I apologize for any inconvenience caused, thank you
paullee
Postby paullee » Tue Feb 05, 2019 1:42 am
Hello
thank you,
Renato Rebelo
Hi, is Tread Thickness in below screencapture what you want?
Which FC version you are using?
BTW there are bugs e.g. in Align property in the current 0.18_pre version I had fixed but had not Pull Request yet - trying to tackle curvilinear railing but not successful being beginner in python :)
Screenshot from 2019-02-05 09-28-00.png (325.07 KiB) Viewed 470 times
paullee
Postby paullee » Tue Feb 05, 2019 7:03 am
yorik wrote:
Hi, I created 3d wires with curvilinear LineSegment for railing but found many problems :(
One being FC crash occasionally - e.g. select the RailingWire in attached file and and apply ArchPipe and it crash.
With straight wire, no problem so far, no idea any problem with the wire or otherwise.
No urgency though :)
Screenshot from 2019-02-05 14-53-09.png (218.01 KiB) Viewed 461 times
Screenshot from 2019-02-05 09-28-00.png (325.07 KiB) Viewed 461 times
FreeCAD_0.18.15780.glibc2.17-x86_64.AppImage on Fedora 29
Test_ ArchStairs_ code revision test_ 12_ Simple Half-Turn Stairs with curve landing .fcstd
(127.27 KiB) Downloaded 15 times
paullee
Postby paullee » Tue Feb 05, 2019 8:37 am
Hello
thank you,
Renato Rebelo
I think you mean the vertical piece / finishes other the the horizontal tread and the stair structure itself right?
Hmm... geometric problem to resolve ... and another is how to apply different material on different parts of the Stairs itself for it to be useful :) Need to see if the master (Yorik) has any direction :D
BTW, what in native English the term for 'thickness of the riser' ?
paullee
Postby paullee » Tue Feb 05, 2019 8:43 am
yorik wrote:
Hi again.
@Renato Rebelo ask if the "thickness of the riser" could be added in the Stairs.
Whilst this is another geometric problem to solve, it raise another issue I have not looked into.
For the current many 'parts' of Stairs - structure, tread, stringer, railing - how could different materials be 'applied' to it (and successfully output to IFC)?
BTW, is Window (glass panel / frame /...), Wall etc. with different materials layer working currently?
Thanks for any idea :)
Renato Rebelo
Postby Renato Rebelo » Tue Feb 05, 2019 10:42 pm
Hello
thank you,
Renato Rebelo
yes I mean the vertical part, as in the image
thank you
