That is Autodesk's software right? Haven't really used software other than AutoCAD.
I think yes but I do not know which one, it was an image that I googled ...
With latest code, no FC crash.
Hi, the Riser Thickness feature is added below, see anybody would test before PRRenato Rebelo wrote: ↑Tue Feb 05, 2019 10:42 pm
yes I mean the vertical part, as in the image
thank you
Thanks for testing.
I think it would be just brilliant to have the possibility to make the placement height dependant from base floor (using the z placement in a relative way), and height calculated as difference between upper floor and lower floor levels. Instead I don't think that the stair should cut something from the upper floor slab... (at least that's the Revit way: two parameters with drop down list showing list of floors) What do u think?
I do not know Revitcarlopav wrote: ↑Mon Apr 01, 2019 5:55 amI think it would be just brilliant to have the possibility to make the placement height dependant from base floor (using the z placement in a relative way), and height calculated as difference between upper floor and lower floor levels. Instead I don't think that the stair should cut something from the upper floor slab... (at least that's the Revit way: two parameters with drop down list showing list of floors) What do u think?
