[PR] [0.18] [0.19_pre] Arch Stair - More Geometry Control? Profile Generator
carlopav
Re: [PR] [0.18] [0.19_pre] Arch Stair - More Geometry Control? Riser Thickness
Postby carlopav » Mon Apr 01, 2019 8:26 pm
paullee wrote:
Mon Apr 01, 2019 5:17 pm
I do not know Revit :) Any reason not letting Stairs to help create opening on floors?
No reason if we can modify the shape of the hole after it's creation without breaking the relation,
And eventually disable it but keep the automatic calculation of floor height :)
paullee
Re: [PR] [0.18] [0.19_pre] Arch Stair - More Geometry Control? Profile Generator
Postby paullee » Mon May 20, 2019 6:00 pm
Profile Generator (of ArchStairs) discussion at:-
https://forum.freecadweb.org/viewtopic. ... 91#p309591
ArchStairs.py
(71.35 KiB) Downloaded 6 times
paullee
Re: Discussion: Arch generators - naming
Postby paullee » Tue May 21, 2019 5:04 pm
'ArchStairs Profile' vs 'ArchStairs' ?
Original ArchStairs Tool - Pic 1
  1. Build a simple Flight from a Simple Line
  2. Currently do not build circular stair, curvilinear steps etc.
ArchStairs Profile - Pic 2 to 5 - Profile Generator Possibilities
  1. Now ArchStairs has an option to also build the Cross-Section Profile of the flight
  2. (Likewise, build the Steps, Riser, 'Multi-Segment Landing' etc.)
  3. Then, user can use e.g. resolve / sweep tool to do more fancy 3d compound shape
  4. Finally another ArchStairs Object to house all these shapes
Screenshot from 2019-05-22 00-38-36.png (231.88 KiB) Viewed 267 times
Screenshot from 2019-05-22 00-29-22.png (218.39 KiB) Viewed 267 times
Screenshot from 2019-05-22 00-29-04.png (231.37 KiB) Viewed 267 times
Screenshot from 2019-05-22 00-28-24.png (227.17 KiB) Viewed 267 times
Screenshot from 2019-05-22 00-30-06.png (179.5 KiB) Viewed 267 times
paullee
Postby paullee » Tue May 21, 2019 5:09 pm
Other Possibility Using the Generated Profile - Not Necessarily Stairs ?
Just use the generated Profile to do other Object... save time to build the profile
And if it generate a Sketch rather than a simple Part::Feature, user can edit the sketch to fine tune the profile to use.
Screenshot from 2019-05-22 01-03-23.png (169.26 KiB) Viewed 264 times
Screenshot from 2019-05-22 01-03-41.png (265.05 KiB) Viewed 264 times
vocx
Postby vocx » Tue May 21, 2019 6:10 pm
You should not discuss this tool in that thread. Your discussion, adding many pictures, is obfuscating the conversation in that thread. That thread is more general, but you are talking a very specific tool. If you want to discuss the particular case of this stairs tool, it should be in this thread, which you can link to in the other thread. You are doing the opposite and just complicating the conversation for everybody.
Postby Kunda1 » Wed May 22, 2019 2:13 pm
@paullee i think our friend @vocx is asking to please be aware of what he's bringing to your attention. It's not a command, it's a request...right? ;)
paullee
Postby paullee » Wed May 22, 2019 4:14 pm
Indeed this involves more general issue about renaming / separating tool and the specific ArchStair in ArchWB which works as an example to illustrate the possibilities and/or consideration - confusing enough for me also.
Anyhow, if there is comments on what is suggesting, please discuss. Hope some time would be invested to develop this further for more peoples who agree rather than people disagree.
paullee
Postby paullee » Wed May 22, 2019 7:36 pm
and Steps Profiles?
Screenshot from 2019-05-23 02-43-18.png (254.54 KiB) Viewed 198 times
Screenshot from 2019-05-23 02-43-22.png (254.24 KiB) Viewed 198 times
Screenshot from 2019-05-23 03-10-06.png (240.52 KiB) Viewed 198 times
Screenshot from 2019-05-23 02-43-34.png (247.4 KiB) Viewed 198 times
paullee
Postby paullee » Thu May 23, 2019 5:23 pm
Riser Face Profile
Screenshot from 2019-05-24 01-16-39.png (272.42 KiB) Viewed 169 times
