[PR] [0.18] [0.19_pre] Arch Stair - More Geometry Control? Profile Generator
paullee
Re: [PR] [0.18] [0.19_pre] Arch Stair - More Geometry Control? Profile Generator
Postby paullee » Sun Jun 16, 2019 6:24 pm
Still stuck...
For fun, play with simple experiment to build a box theatre like model ...
... mainly on 2 master sketches
... 1st with 4 edges for the theatre enclosure
... 2nd with 5 edges for the steps
Need some more features to add to make the model more refined :)
Screenshot from 2019-06-17 02-14-57.png (221.87 KiB) Viewed 387 times
Screenshot from 2019-06-17 02-16-07.png (208.47 KiB) Viewed 387 times
Screenshot from 2019-06-17 02-16-18.png (208.81 KiB) Viewed 387 times
yorik
Site Admin
Postby yorik » Mon Jun 17, 2019 4:51 pm
cool!
paullee
Postby paullee » Mon Jun 17, 2019 6:15 pm
Thanks, slightly modified version.
Hope can find some seats to put in :) In addition to finding some potential features to add, found some bugs too :lol:
Screenshot from 2019-06-18 02-10-52.png (234.86 KiB) Viewed 360 times
paullee
Postby paullee » Sat Jun 29, 2019 10:39 am
Ok, it seems I have made up my mind on how to do 'Profile / Face / Solid (BIM Object) Generator'.
How would you like to do a curve audience steps below?
  • Still 3 simple straight lines - like the previous rectangle steps - representing 2 'flights' and 1 'landing'
  • 3 ArchStair Objects with the 3 lines as base - still same as previous
  • Now, Stairs has options like StructureOutput, StepsOutput ... that you can pick Profile, Face, Solid (BIM Object)
  • Pick Profile and Stairs only give you profile, instead of the default 'rectilinear shape' stair flight solid
  • Do whatever you like with the Profile (like Revolve in this case)
  • (House the solid in an Stair Object as desired)
It seem much simple this way than to add 'more built-in features' in Stairs.
Any comments and ideas?
Then, the Profile should be 'editable' to let user fine-tune / adjust the 'default' structure / steps / risers profiles ?
Screenshot from 2019-06-29 18-18-51.png (305.13 KiB) Viewed 304 times
Screenshot from 2019-06-29 18-19-43.png (305.81 KiB) Viewed 304 times
Screenshot from 2019-06-29 18-32-10.png (278.9 KiB) Viewed 304 times
Screenshot from 2019-06-29 18-20-09.png (347.68 KiB) Viewed 304 times
Screenshot from 2019-06-29 18-18-21.png (295.15 KiB) Viewed 304 times
paullee
Postby paullee » Sat Jun 29, 2019 10:52 am
In fact, just as simple as 1 line should do as Stairs has a 'Landing' attribute... just pick 'At center'
No need for 3 lines ... hmmm, just find a problem that the 'landing profile' is not produced in this way yet... :)
Screenshot from 2019-06-29 18-44-56.png (326.18 KiB) Viewed 301 times
Screenshot from 2019-06-29 18-45-23.png (344.15 KiB) Viewed 301 times
Screenshot from 2019-06-29 18-45-50.png (319.79 KiB) Viewed 301 times
Screenshot from 2019-06-29 18-46-03.png (330.69 KiB) Viewed 301 times
paullee
Postby paullee » Sat Jun 29, 2019 3:37 pm
OK fixed - 1 line to create 2 flight + 1 landing
But with more more lines, one can tweak different risers height for each 'flight'
Screenshot from 2019-06-29 23-29-23.png (271.94 KiB) Viewed 278 times
Screenshot from 2019-06-29 23-29-32.png (290.57 KiB) Viewed 278 times
Different risers height for each 'flight'
Screenshot from 2019-06-29 23-31-24.png (290.15 KiB) Viewed 278 times
paullee
Postby paullee » Mon Jul 01, 2019 3:38 pm
Hi, anybody know how to design a theatre? Just imitating some online images to test out the idea of using Stairs ...
Screenshot from 2019-07-01 23-40-41.png (271.3 KiB) Viewed 240 times
dimitar
Postby dimitar » Tue Jul 02, 2019 9:25 pm
Here is a typical section. This one is of Libeskind's Grand Canal Theatre in Dublin.
And he is a Revit section of a theatre I worked on that has a similar cross section:
And here is the process of building theatre from a 2d cross-section, similar to the way you are building them, while making sure it works with the sightlines, and then sweeping the cross section along a profile (Curved or straight)
paullee
Postby paullee » Wed Jul 03, 2019 12:57 am
Thanks for the drawings!
It's good the section has some dimension and sightline illustrating the considerations and provisions :)
dimitar
Postby dimitar » Fri Jul 12, 2019 12:28 am
Have you looked at the wall creation in Blender with the architools addon? It's not 100% intuitive, but it does a pretty decent job.
