Missing objects
Missing objects
I wrote down a small gif`s, which would be more visible.
Report view:
Updating geometry: Error build geometry(1): Both points are equal
Invalid solution from DogLeg solver.
App::Document::recompute(): cyclic dependency detected
How to fix it?
Report view:
How to fix it?
- Screenshot_20180709_150301.png (170.89 KiB) Viewed 1659 times
- Peek 2018-07-09 14-47.gif (649.43 KiB) Viewed 1659 times
Join me.
Re: Missing objects
It is best to provide the FreeCAD info as described in the Forum guidelines. It needs less bandwith and has yet more information.
Re: Missing objects
I am very lost as to what your request is. If you can explain your self better and what is it you are trying to do.
Re: Missing objects
I want to draw a draft of my future home. I paint windows, doors and they just disappear after creation. If necessary, I can capture the entire creation process.
Sorry for my English.
https://yadi.sk/d/MeAOux1X3Yznz5
Join me.
Re: Missing objects
Regis, it`s youre channel?
https://www.youtube.com/channel/UClhtX- ... 2w5_u2ShTQ
I'm learning to work with FreeCAD on your videos. Thank you very much!
But sometimes I have some strange problems that I try to describe as I can, because I do not speak English well.
I attached a gif`s in the previous answer. It turned out big, so I had to put it on file storage.
Join me.
Re: Missing objects
nop. I don't see the problem in your video. You create a couple of holes on a wall and slab and they don't disappear. What I don't understand is why you click on recompute again and again. You don't need it.mad_max wrote: ↑Mon Jul 09, 2018 4:59 pm I want to draw a draft of my future home. I paint windows, doors and they just disappear after creation. If necessary, I can capture the entire creation process.
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Re: Missing objects
Holes on the wall and slab disappear when I start creating other walls and holes, and to see them again, I have to click on recompute. But I found another way of creating holes, in which there are no such problems.bitacovir wrote: ↑Wed Jul 11, 2018 1:01 pmnop. I don't see the problem in your video. You create a couple of holes on a wall and slab and they don't disappear. What I don't understand is why you click on recompute again and again. You don't need it.mad_max wrote: ↑Mon Jul 09, 2018 4:59 pm I want to draw a draft of my future home. I paint windows, doors and they just disappear after creation. If necessary, I can capture the entire creation process.
Thank you all, you can close the topic.
Join me.
Re: Missing objects
And would you mind sharing your recently acquired wisdom?
Re: Missing objects
Thanks a bunch,mad_max wrote: ↑Wed Jul 11, 2018 2:36 amRegis, it`s youre channel?
I'll also pass on your thanks to the Freecad folks who create freecad in a dedicated way because without them none of this would be possible.
Hehe we are all curious about what that might be.
I'm still trying to figure if that is what my videos are showing?
Anyways if what you are doing works well for you, well this is open source, there are many ways to do something.
Re: Missing objects
I started using Part Workbench.
- Screenshot_20180712_094344.png (5.92 KiB) Viewed 1532 times
Join me.
