Hi, finally try BuildingPart...Seem some problem with Move with Host?
It seems if I rotate the BuildingPart e.g. by 10 deg, all children rotate, that's fine.
But when I enter again another rotation figure, e.g. say want it to return to 0 deg, the children Do Not...
Anybody has similar experience? Maybe need more test to single it out to demonstrate.
[Bug?] BuildingPart + Move with Host
Re: [Bug?] BuildingPart + Move with Host
(Remember to show what FreeCAD version are you using)
Do you mean something like this?
Version: 0.18.15007 (Git)
Hash: 70fef3934190aabc61f5e1346483359d5ad21403
Python version: 2.7.14
OCC version: 7.2.0
OCC version: 7.2.0
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Wow. This is a terrifying behavior. I can confirm this bug.
OS: Ubuntu 18.04.1 LTS
Version: 0.18.15115 (Git)
Hash: 684b4ab03a27231e0cc603ca815bf9ea367fd0b9
Python version: 2.7.15rc1
I have expressed in another thread about the difficulty of moving and rotating Windows and Doors. Their orientation (axis and rotation values) seems pretty weird, and whenever you try to move them around they don't display correctly: https://forum.freecadweb.org/viewtopic.php?f=23&t=31697
Basically, don't rotate them! Once the window or door is in its place, that is, aligned to a plane (a Wall), only change the [x, y, z] coordinates, but don't touch the rotation values.
Thanks for testing.
Move with Host - Angle Properties
Arch Window create Wrong Opening Position Bug?Arch Window create Wrong Opening Position Bug?
See full report there...
FC Version
FreeCAD_0.18.14928.glibc2.17-x86_64.appimage
on Fedora 27
- I always forget Yorik mention in another thread need to use Draft Move for 'Move with Host' to work
- I directly input in the properties field - though it seems x,y,z has not problem, changes in angle make the object's angles attribute go uncontrollable
- The problem I found is slightly different from Bitacovir find -
- ... I enter say 30 deg in the field, ok, all object rotate
- ... then I enter say 0 deg, expecting all object back to original orientation, no, they each go to different angle!
FC Version
on Fedora 27
