[SOLVED] How do I constrain a sketch to an axis?
Moult
Postby Moult » Tue Jan 15, 2019 8:30 pm
Not entirely sure how to do this, but it would seem like a very, very, useful tool.
Re: How do I constrain a sketch to an axis?
Postby chrisb » Tue Jan 15, 2019 8:35 pm
Do you mean the point-on-object constraint Image where you select the axis and a point?
Moult
Postby Moult » Tue Jan 15, 2019 9:02 pm
No. I meant an arch axis object, axis system, or grid system object .
yorik
Site Admin
Postby yorik » Tue Jan 15, 2019 10:00 pm
At the moment, you can't. The axis is not part-based and therefore not seen by the sketcher. We could actually try to change that...
Moult
Postby Moult » Tue Jan 15, 2019 10:05 pm
I see. It would be absolutely great if it could be changed so that it could be recognised. I'm sure you understand the benefits of doing so :)
What is involved in changing it? Is it easy / hard?
Postby Kunda1 » Wed Jan 16, 2019 12:45 pm
I'm not sure if there is one yet, but you may want to open a ticket on the tracker to track this feature
Moult
Postby Moult » Thu Jan 17, 2019 9:35 pm
yorik
Site Admin
Postby yorik » Fri Jan 18, 2019 7:41 pm
