Apparent error when rotating host with elements
A forum dedicated to the Arch and BIM workbenches development.
mickele
Postby mickele » Wed Jan 23, 2019 8:27 am
After creating two structural elements, I add one of them to the other.
In the child element I set the option "Move with host" to true. If I translate the host object everything works as expected: child object moves with the host.
If I rotate the host I have strange behaviour: child object doesn't rotate; moreover child object starts moving in a not easyly predicatable way.
Possible bug?
Version: 0.18.15646 (Git)
Hash: fdf8fe7bc6ed671e8b7ee064000b6f00567ce795
Python version: 2.7.14
OCC version: 7.2.0
Locale: Italian/Italy (it_IT)
rotation-compound.FCStd
(9.03 KiB) Downloaded 2 times
Re: Apparent error when rotating host with elements
Postby yorik » Wed Jan 23, 2019 5:38 pm
Yes there is definitely a bug there. Working on it...
Postby yorik » Wed Jan 23, 2019 10:00 pm
Ok there are multiple bugs there... I can't unfortunately solve it right now because it could potentially break many existing models, which is a bad idea to do just before an official release. So I openend a bug issue at https://www.freecadweb.org/tracker/view.php?id=3789 and will handle it after the 0.18 release.
In the meantime, you have many other ways to solve this, for example: Union your pieces with Part Fuse tool, then turn the union into an Arch Structure. Then you can move/rotate it without problems.
mickele
Postby mickele » Thu Jan 24, 2019 1:58 pm
Ok, thanks!
