[solved] Problem extruding section along path in arch WB
mickele
Post by mickele »
I have problems extruding a section along a path in an arch object.
Working with part workbench I have the expected behavoiur
Working with arch workbench I have a strange result
Is there anything wrong in my model?
Version: 0.18.15656 (Git)
Hash: a60b6957db228c42a00a1e002a415cbb8309d3c8
Python version: 2.7.14
OCC version: 7.2.0
Locale: Italian/Italy (it_IT)
arch-extrusion.FCStd
(11.39 KiB) Downloaded 22 times
yorik
Founder
Re: Problem extruding section along path in arch WB
Post by yorik »
Use your line as "Tool" instead of "Axis". This will get you the desired result.
mickele
Re: [solved] Problem extruding section along path in arch WB
Post by mickele »
Thanks!
