Draft Edit improvements
carlopav
Postby carlopav » Sun Feb 03, 2019 12:58 pm
Back to stalke you, promise i'll stop tomorrow when I'm back to work. =)
having some fun with the Draft Edit tool and walls:
yorik
Site Admin
Re: Draft Edit improvements
Postby yorik » Tue Feb 05, 2019 12:32 am
Oh, cool! Did you modify it somehow?
carlopav
Postby carlopav » Tue Feb 05, 2019 7:35 am
Yes, i added some more lines to the draft edit tool to make it edit walls base objects. At the moment just if they are single line sketches or every other kind of draft 2d objects, but I'd like to keep working on it...
And btw I'm not sure it's the right approach: I mean, is it preferred to edit the base object or the wall itself with the edit tool? I think the base object, but that's just my opinion.
I think i made also a pull request, but i'm not sure if it worked or not... have you noticed anything on your side?
carlopav
Postby carlopav » Tue Feb 05, 2019 7:42 am
I was thinking also to the new 3points arc: i plan to implement an edit option that let you edit every arc object with end/mid/end mode or center/radius/angle/angle mode. That should help because the arc created could be always the same draft object, stored in the same way.
do you agree
carlopav
Postby carlopav » Tue Feb 05, 2019 7:43 am
Oh, cool!
Too kind Yorik
paullee
Postby paullee » Tue Feb 05, 2019 8:09 am
Again! Glad to see there are more people contributing to Arch/BIM WB! :)
yorik
Site Admin
Postby yorik » Wed Feb 06, 2019 12:54 pm
I think it's the right approach, the same I did with the Stretch tool: From the user point of view, you are just editing the wall. But internally, "programmatically", we are in fact editing the line underneath. But the user doesn't see it.
I don't see your pull request...
do you agree
Yes! I wasn't sure if the new 3-point arc should be stored as the same object as the existing draft arc or not. But indeed if you offer both editing modes, then the question is solved ;)
carlopav
Postby carlopav » Wed Feb 06, 2019 4:56 pm
Great, i will work in this direction so.
I should have done something wrong... i'll try again tonight!
carlopav
Postby carlopav » Wed Feb 06, 2019 8:51 pm
I think i did again something wrong merging it without waiting... i had to stop at the pull request... right? ok i'll give a deeper look on how git works, sorry :? :?
carlopav
Postby carlopav » Wed Feb 06, 2019 9:14 pm
Thanks Paullee, just having some weekend fun for the moment =) but glad to have discovered this great community!
cron
