Draft Edit improvements
yorik
Site Admin
Re: Draft Edit improvements
Postby yorik » Fri Feb 22, 2019 9:25 pm
Amazing job @carlopav !
It's quite exciting to see all the recent developments you guys are doing around arch and draft.
regis
Postby regis » Sat Feb 23, 2019 1:44 am
Moult wrote:
Wed Feb 20, 2019 8:44 pm
@Regis, if you are inclined towards using Linux-like tools, ffmpeg can do what you are asking for:
ffmpeg -video_size 1920x1080 -framerate 25 -f x11grab -i :0.0+0,0 test.mp4
ffmpeg -i test.mp4 -vf scale=480:270 my gif.gif
The first line records your full screen at that resolution (change as necessary) and the second line converts it to a gif at 480x270 resolution.
Thanks a bunch. tested it and it doesn't seem quite as obvious. I ran the command you gave me and there was no way to stop aside from closing the terminal and I couldn't tell where it saved it all.
Moult
Postby Moult » Sat Feb 23, 2019 2:13 am
That is correct. It is terminated in a shell usually by ctrl-c. It will save it to the current working directory of the shell. Run "pwd" to see your working directory.
paullee
Postby paullee » Sat Feb 23, 2019 2:45 am
... there was no way to stop aside from closing the terminal and I couldn't tell where it saved it all.
:D That's the strength and weakness of command line
I need to write down some commands In a text file as many of them are not used occassionally - otherwise forgot the other day I figured out how to use the command.
regis
Postby regis » Sat Feb 23, 2019 3:06 am
Yeah not quite practical, I need to search for a different solution. I was back researching how to open an extract an appimage when we had a dedicated forum discussion on it the other day. So yeah...
carlopav
Postby carlopav » Sat Feb 23, 2019 10:54 am
Playing with auto edit set by a selection observer as Yorik suggested. It's already quite fast on my 7 years old cheap laptop, but i was thinking to split the edit command in two so the gui part is activated only if an editpoint is pressed.
Moult
Postby Moult » Sat Feb 23, 2019 11:36 am
I noticed that when you activate draft edit mode on click, it hides the properties. I suspect that this could be an issue, as most of the time in a BIM model you want to inspect properties by clicking on objects. What do you reckon?
carlopav
Postby carlopav » Sat Feb 23, 2019 12:51 pm
Yes, it's just an experiment at the moment, still figuring out how to properly make it work... i just wanted to understand if auto running the command would slow down the drawing process, but doesnt seems so. Anyway i was thinking to refactor the tool a loot... i'll be back to ask for help if i get stucked on some point... and i think i will :)
carlopav
Postby carlopav » Sat Feb 23, 2019 7:11 pm
yorik wrote:
Sat Feb 16, 2019 10:08 pm
Another idea, if not possible to depend on getObjectsInfo: We do our own routine:
- take the point returned by getObjectInfo, no matter which object was clicked
- take the view direction (ortho cameras) or a vector from the point to the camera position (perspective cameras)
- take another vector from the clicked point to all our edit points
- for each of these, get the angle between it and the view direction vector
- if they are aligned (angle is 0° or 180°), then this edit point is exactly in the line of our clicked point. Then we can consider it was clicked.
Help wanted: i rewrote the "set editpoints trackers" based on a selection observer, so when an object is selected the editpoints trackers are displayed. Also if an object is unselected using Ctrl, the editpoints of that object are removed, etc... So at the moment you can launch every command while points are displayed. if at the end of the command the selection is kept, editpoints are diplayed again, if not, they are removed. Until that point everything works.
Now i'd like to proceed converting the rest of the old edit tool to be activated when a editpoint is clicked, displaying the editui and modifying the object. Do you think that could be a good job or am i going to the wrong path? also i have no idea on how to implement your suggestion. Any code to inspire to? thx.
class autoEditObserver:
    def __init__(self):
        self.trackers = []
        self.editpoints = []
    def addSelection(self, document, object, element, position):
        """Add single object to selection. Usually gets called when selecting in the 3d view"""
        '''FreeCAD.Console.PrintMessage(document+"\n")
        FreeCAD.Console.PrintMessage(object+"\n")
        FreeCAD.Console.PrintMessage(element+"\n")
        FreeCAD.Console.PrintMessage(str(position)+"\n")'''
        self.setEditPoints(FreeCAD.getDocument(document).getObject(object))
    def removeSelection(self, document, object, element):
        """Remove single object from selection. Usually gets called when deselecting in the 3d view"""
        self.deleteTrackers(object)
    def setSelection(self, document):
        """Add one or more objects to selection. Usually gets called when selecting in the tree view"""
        self.deleteTrackers()
        self.setEditPoints(FreeCADGui.Selection.getSelection())
    def clearSelection(self, document):
        """Remove all objects of the given document from the selection"""
    def setEditPoints(self,obj):
        #FreeCAD.Console.PrintMessage("\n setting editpoint")
        #FreeCAD.Console.PrintMessage(str(print(selection)))
        pl = None
        if "Proxy" in obj.PropertiesList and hasattr(obj.Proxy,"Type"):
            objType = Draft.getType(obj)
            FreeCAD.Console.PrintMessage(str(objType)+"\n start editing")
            pl = None
            if "Placement" in obj.PropertiesList:
                pl = obj.Placement
                invpl = pl.inverse()
            if objType in ["Wire","BSpline"]:
                #self.ui.editUi("Wire")
                for p in obj.Points:
                    if pl: p = pl.multVec(p)
                    self.editpoints.append(p)
            if objType == "Circle":
                self.editpoints.append(obj.Placement.Base)
                #if obj.FirstAngle == obj.LastAngle:#self.obj is a circle
                    #self.ui.editUi("Circle")
                    #self.editpoints.append(obj.Shape.Vertexes[0].Point)
                #else:#self.obj is an arc
                    #self.ui.editUi("Arc")
                    #self.editpoints.append(obj.Shape.Vertexes[0].Point)#First endpoint
                    #self.editpoints.append(obj.Shape.Vertexes[1].Point)#Second endpoint
                    #self.editpoints.append(getArcMid())#Midpoint
                FreeCAD.Console.PrintMessage(str(self.editpoints)+"\n ")
            self.setTrackers(obj)
            #self.proceed()
            return
        FreeCAD.Console.PrintMessage("\n This object type is not editable")
        return
    def setTrackers(self,obj):
        if self.editpoints:
            FreeCAD.Console.PrintMessage("\n SETTING EDITTRACKER")
            for ep in range(0,len(self.editpoints),1):
                self.trackers.append(editTracker(self.editpoints[ep],obj.Name,ep))
            #self.call = self.view.addEventCallback("SoEvent",self.action)
            #self.running = True
            '''plane.save()
            if "Shape" in self.obj.PropertiesList:
                if plane.weak:
                    plane.alignToFace(self.obj.Shape)
            if self.planetrack:
                self.planetrack.set(self.editpoints[0])'''
        else:
            return
        FreeCAD.Console.PrintMessage("trackers lenght = "+ str(len(self.trackers)) + "\n endpoints lenght  = " + str(len(self.editpoints)))
    def deleteTrackers(self,object = None):
        if object != None:
            removeIdx = []
            for t in range(0,len(self.trackers),1):
                if object == self.trackers[t].name:
                    #FreeCAD.Console.PrintMessage(str(t.idx) + "  "+ str()"\n OBJECT DESELECTED")
                    removeIdx.append(t)
            n = 0
            for t in removeIdx:
                self.trackers[t-n].finalize()
                self.trackers.pop(t-n)
                n = n + 1
        elif self.trackers:
            for t in self.trackers:
                t.finalize()
            self.trackers.clear()
            self.editpoints.clear()
            self.trackers = []
Moult
Postby Moult » Sun Feb 24, 2019 2:59 am
Hey @carlopav, maybe it's a good time to discuss how we both envision draft editing :)
In a nutshell here's what I'm thinking of:
  1. There are essentially two types of draft objects: graph objects (lines / wires) and parametric objects (arcs / circles / splines, etc). graph objects have subelements (vertices / edges), and parametric objects have editing points (arc handle / circle centroid / etc). This distinction is important because subelements are always visible, but editing points are generally invisible unless the current draft edit mode is activated.
  2. Because subelements are always visible, at any time, any combination of zero or more subelements can then be selected and you can perform transformation modifiers (move / rotate / scale / fillet, align, etc) without the need to create or join new draft objects. This is achieved via a "subelement" mode in those respective modifiers. This is already implemented in my PR for the "move" modifier. I can continue working on this to implement subelement mode for all other transformation modifiers
  3. Also at any time, any combination of zero or more subelements can then be selected and you can perform non-transformation modifiers (copy / array / mirror / etc) in a "subelement" mode, but it will result in brand new draft objects for each non-connected graph of 2 or more vertices. This subelement mode covers the majority of usecases around manipulating graph objects. I can build this, seeing as it's part of the whole subelement mode thing.
  4. Because of this subelement mode, the stretch tool can be deleted. All of its functionality is already included and improved. Easily done by anybody when this code matures
  5. The existing draft edit mode can stay with all of its current functionality + improvements by @carlopav. That is because its primary purpose will now be in modifying editing points for parametric objects. Admittedly, there is a slight double up with the ability to move vertices in the draft edit mode, and the ability to move it using the move command + subelement mode, but that's OK :) Maybe it can be renamed to be more specific to help users understand, to something like draft node mode. @carlopav has already been doing great work in improving this! He should continue!
  6. When working in a complex scene, draft bases and draft elements may be invisible, obscured, or otherwise hard to select. A new draft highlight mode can be activated which finds and shows all draft elements, including invisible component bases (see https://peertube.social/videos/watch/86 ... e332e916f4). This visibility as well as the improved cycle selection should improve the ability to select these draft objects to get ready to manipulate them. This feature is already done in the PR, just needs more testing and maturity
Once all that is done, I think I will be happy with all of the draft editing functionality in FreeCAD :) What do you guys think?
