G'day all, I am using FreeCAD_0.18.15609_Conda_Py3Qt5_glibc2.12-x86_64.AppImage
OS: Gentoo/Linux
Version: 0.18.15609 (Git) AppImage
Hash: a14af0f2bd26f980d71be80a799ee48127bc7619
Python version: 3.6.7
Qt version: 5.6.2
Steps to reproduce:
1. Draw a new draft wire which does not start at the origin. (i.e. the draft wire's placement position is not 0, 0, 0)
2. Select an edge on the wire
3. S,C to start scaling
4. Click a base point
5. Change the scale factor to anything
6. Press OK.
You will notice that the draft wire will jump so that the position is reset to 0, 0, 0.
Can others replicate this? If so, I will attempt to fix it in my PR which is adding the feature to scale subelements.
[SOLVED] Draft scale v0.18 is broken?
Re: Draft scale v0.18 is broken?
I can concur with you, It seems on the latest version I donwloaded last night, the scale tool seems to be broken and behaves exactly as you have described. except mine doesn't put the new scaled tool at 0,0,0 but puts it way off someone lost in 3D space
FreeCAD_0.18.15972_Conda_Py3Qt5_glibc2.12-x86_64.AppImage
OS: Linux Mint 19.1
Version: 0.18.15972 (Git) AppImage
Hash: 4e973324ae03c6db9188c08483232fa059c1c9ae
Qt version: 5.6.2
OS: Linux Mint 19.1
Qt version: 5.6.2
here:
OS: Linux Mint 18.3 Sylvia
Version: 0.18.15987 (Git)
Hash: be45d5e7bab63a9c8566803ea1394d88445251dd
Python version: 2.7.12
Locale: Italian/Italy (it_IT)
but also here:
Version: 0.17.13541 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
I have this strange behavior.
But only with option "Create a clone" selected.
With options "Modify original" and "Create a copy" selected the result of Scale command is correct.
Thanks for the confirmations. It is clear something is broken. I will fix.
It is "fixed" (except for rectangles, which I think we can deprecate).
Commit: https://github.com/FreeCAD/FreeCAD/pull ... 8823cea776
Marking thread as solved.
