the negative Z axis Direction in Section plane
hello
how does the section plane produce the negative z axis direction (slab plane), i could produce the foundation plane but i don't understand how to produce the slab plane
thank you
thank you
- 2.PNG (174.22 KiB) Viewed 1904 times
Re: the negative Z axis Direction in Section plane
If I understand correctly. I think you need to create another section plane through the element that you want to show. Also. if you want to change de direction of the section you can rotate it.FATHI RAMMAH wrote: ↑Sun Mar 24, 2019 11:26 pm hello
thank you
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Angle = 180bitacovir wrote: ↑Mon Mar 25, 2019 1:29 pmIf I understand correctly. I think you need to create another section plane through the element that you want to show. Also. if you want to change de direction of the section you can rotate it.FATHI RAMMAH wrote: ↑Sun Mar 24, 2019 11:26 pm hello
thank you
Axis-X = 1
Axis-Y = 0
Axis-Z = 0 ... to turn the plane 'upside-down'?
thank you guyspaullee wrote: ↑Mon Mar 25, 2019 3:35 pmAngle = 180bitacovir wrote: ↑Mon Mar 25, 2019 1:29 pmIf I understand correctly. I think you need to create another section plane through the element that you want to show. Also. if you want to change de direction of the section you can rotate it.FATHI RAMMAH wrote: ↑Sun Mar 24, 2019 11:26 pm hello
thank you
Axis-X = 1
Axis-Y = 0
i did the all of that and more but i couldn't produce my slab plane , i think the horizontal section always looking at down
Share your file.
::bitacovir::
this is my file
- building.FCStd
- (165.06 KiB) Downloaded 28 times
See the problem... do you do the same thing?
Section plane can produce plan and elevation / vertical section - I add another 'TopView', 'SectionView' , which are fine in TechDraw.
Add a 'BottomView' with rotation 'upside-down', then in TechDraw only have 'outline' of slab I think ...
Should be a 'Bug / Feature not implemented' ?
Maybe @Regis have some idea?
- building_r.FCStd
- (180.82 KiB) Downloaded 27 times
yes , this is exactly what i want to say ,i think its not a bug may be its not implemented yet,its a very important feature ,i'll try to contact with yorik or Regis for thatpaullee wrote: ↑Mon Mar 25, 2019 10:51 pm See the problem... do you do the same thing?
I don't see any problem.
'BottomView' section only contains the slab object. Do you want to include the pillars? Then you must add them.
But I don't understand why he needs an upside down section view. It is not very common. If the user wants to show the slab with a section view, he must select the slab object and then click on section command. The section will show the slab only (a square). If he needs to show the location of the pillars, he should include in the section view the axes. But the point of view is always from the top. Anyway, he could include a section view that shows slab and pillars, if he wants that. Just selects the slab and column objects and click on section view command. Then, he must rotate the section upside down, as paulle explained.
::bitacovir::
Ohhh. I see. He wants to include the beams.
It's the same. He must select the slab and all the beams elements. Then, create the section view containing all these elements. And then, he can rotate the section view upside down.
::bitacovir::
