OBJ importer error (python 3.7)
olof
Postby olof » Tue Apr 02, 2019 12:21 pm
When I try to export an OBJ file (such as when uploading to Sketchfab) I get an error like:
  File "~/.FreeCAD/Mod/WebTools/Sketchfab.py", line 220, in upload
    pack = self.saveFile()
  File "~/.FreeCAD/Mod/WebTools/Sketchfab.py", line 138, in saveFile
    importOBJ.export(objects,filename+".obj")
  File "~/miniconda3/envs/freecad_py37/Mod/Arch/importOBJ.py", line 199, in export
    outfile.write("# FreeCAD v" + ver[0] + "." + ver[1] + " build" + ver[2] + " Arch module\n")
TypeError: a bytes-like object is required, not 'str'
At the moment the file is being opened for writing in binary mode. Given OBJ files (as I understand it) are text files is this needed? If I change it to open as a text file it works as expected.
I seem to have an old account for the issue tracker associated with my email address but can't find/remember my username to allow me to reset my password...
OS: elementary OS 5.0 Juno
Version: 0.18.14555 (Git shallow)
Hash: 51b953e2c6edd7f76b1d8faa584424cfb6367d45
Python version: 3.7.1
Qt version: 5.6.2
vocx
Re: OBJ importer error (python 3.7)
Postby vocx » Wed Apr 03, 2019 1:08 am
The error you get sounds like it could be an incompatibility between Python 2 and Python 3 (http://python3porting.com/problems.html). I think Python 3 handles all strings as Unicode, but Python 2 used to consider them byte arrays (each character a byte). Since FreeCAD was developed with Python 2, there may still be some issues if you use Python 3. As far as I know, the developers are still working on ironing out all issues with Python 3, so that FreeCAD 0.19 (next release cycle) be fully compatible with Python 3. Porting to python3
Did you compile your own FreeCAD? I'm using a pre-packaged FreeCAD for Ubuntu, compiled against Python 2. Did you try with the latest, stable 0.18? I'm using Version: 0.18.16093 (Git), and it seems to work. Your version is several thousands commits behind.
I also suggest you to try a simple export, without using the Sketchfab stuff.
import Arch
import importOBJ
FreeCAD.ActiveDocument.addObject("Part::Box", "Box")
b = FreeCAD.ActiveDocument.ActiveObject
b.Label = "Cube"
b.Length = 1000
b.Width = 300
b.Height = 200
eq = Arch.makeEquipment(b)
importOBJ.export([eq], "/home/olof/model.obj")
