rebar based on wire
rebar based on wire
attached some screen of a stirrup and a FreeCAD file. This rebar is based on a wire. But I could not found a GUI tool to make a rebar based on a Draft-Wire. Did I miss something?
Is there a Python method to make a Rebar out of a wire?
bernd
bernd
Re: rebar based on wire
I use pivy.coin to represent rebar shape. This code for create U-Shape rebar.
Test Create rebars by pivy.coin
24 Apr 2019
Version: 0.19.16502 (Git)
Python version: 3.6.8
import os
from pivy import coin
from math import sin,cos ,pi
def creteRebarU(dia = 12, A= 300, B=1000 , num = 1 , spacing = 100):
Switch = coin.SoSwitch()
Switch.whichChild = 1
Group1 = coin.SoGroup()
Switch.addChild(Group1)
myNode = coin.SoSeparator()
Group1.addChild(myNode)
myNode.setName('RebarU1')
material = coin.SoMaterial()
material.diffuseColor.setValue(0.667, 0.000,0.000)
material.specularColor.setValue(1,1,1)
rebar = coin.SoVRMLExtrusion()
rebar.beginCap = True
rebar.endCap = True
n = 3*4
r = dia/2.0
points = []
for i in range(0,n+1):
x = r * cos(2*pi/n*i); y = r * sin(2*pi/n*i)
points.append( coin.SbVec2f( x , y) )
crossSection = coin.SoMFVec2f()
crossSection.setValues(points)
rebar.crossSection=crossSection
R = 2.0*dia
points = []
points.append( coin.SbVec3f( 0 , -B/2 , A) )
points.append( coin.SbVec3f( 0 , -B/2 , R) )
n = 6
for i in range(0,n):
dx = R * cos(pi/2/n*i); dy = R * sin(pi/2/n*i)
x = -B/2 + R-dx ; y = +R-dy
points.append( coin.SbVec3f( 0 , x , y) )
points.append( coin.SbVec3f( 0 , -B/2+R , 0) )
points.append( coin.SbVec3f( 0 , +B/2-R , 0) )
x = +B/2-R + dy ; y = +R-dx
points.append( coin.SbVec3f( 0 , +B/2 , R) )
points.append( coin.SbVec3f( 0 , +B/2 , A) )
rebar.spine.setValues(points )
myNode.addChild(material)
myNode.addChild(rebar)
Group2 = coin.SoGroup()
Switch.addChild(Group2)
tr = coin.SoTransform()
tr.translation.setValue(0,0,0)
tr.rotation.setValue(0,0,1 , 0.00 )
Group2.addChild(tr)
array1 = coin.SoArray()
Group2.addChild(array1)
array1.origin = 'CENTER'
array1.numElements1 = num
array1.separation1.setValue(spacing,0,0)
array1.addChild(myNode)
return Switch
if __name__=='__main__':
B = 1500; L = B
t = 300
numRebar = 10
dia = 12
B = 5000; L = B
t = 800
numRebar = 48
dia = 19
covering = 50
R = 2*dia
spacing1 = (B-2*covering - dia - 2*R)/float(numRebar-1)
rebarA = t-2*covering - dia
rebarB = B-2*covering - dia
rebarSet1 = creteRebarU(A= rebarA , B=rebarB ,dia = dia, num=numRebar , spacing = spacing1)
rebarSet2 = creteRebarU(A= rebarA-dia , B=rebarB ,dia = dia, num=numRebar , spacing = spacing1)
footingSep = coin.SoSeparator()
group1 = rebarSet1.getChildren()[1]
tr = group1.getChildren()[0]
tr.translation.setValue(0,0,covering+dia/2.0)
group2 = rebarSet2.getChildren()[1]
tr = group2.getChildren()[0]
tr.translation.setValue(0,0,dia)
tr.rotation.setValue(coin.SbRotation(coin.SbVec3f(0.0, 0.0, 1.0), pi/2.0))
material.transparency.setValue(0.55)
material.diffuseColor.setValue(0.000,0.667,1.000)
tr.translation.setValue(0,0,+t/2)
concSep = coin.SoSeparator()
concrete = coin.SoCube()
concrete.width = L
concrete.height=B
concrete.depth = t
concSep.addChild(material)
concSep.addChild(tr)
concSep.addChild(concrete)
#footingSep.addChild(concSep)
footingSep.addChild(rebarSet1)
footingSep.addChild(rebarSet2)
sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
sg.addChild(footingSep)
filePath, fileName = os.path.split(__file__)
out=coin.SoOutput()
out.openFile(filePath+os.sep+'Rebar_U_temp.iv')
wa = coin.SoWriteAction(out)
wa.apply(footingSep)
#wa.apply(rebarSet2)
#wa.apply(concSep)
out.closeFile()
Msg('Done!!\n\n')
Very interesting? Is there any specific reason for using pivy.coin for this ?
import FreeCAD, Arch, Draft
myh = 3000
Structure = Arch.makeStructure(None, length=1000, width=1000, height=myh)
Structure.ViewObject.Transparency = 80
FreeCAD.ActiveDocument.recompute()
p1 = FreeCAD.Vector(0, 0, 0)
p2 = FreeCAD.Vector(0, 0, myh)
Wire1 = Draft.makeWire([p1, p2])
Rebar = Arch.makeRebar(Structure, Wire1, diameter=30, amount=1, offset=0)
But somehow it seams not possible to make rebar without a structure object? This should be possible IMHO.
I think you are right.. But indeed there is no real need, I think it would be easy to change
When I use python macro to create rebar in all beam, it takes a long time to generate rebars, and it has a file's size about 5.05 MB.(Not included rebars in columns, footings, and slab)
I like the coin idea. Especially if I think of the reinforcement we do on work ... But I would not move all to coin. Might it be a good idea to leave the wire as a real shape and only make the solid a pivy.coin node. With this all rebar operation could be done with the wire, like material bill, place rebare against each other etc.
- ebrahim raeyat
It is good idea. we must set the wire shape default for rebars and if user want to view reality we can set a render option. because it is time consuming process for real structures.bernd wrote: ↑Thu Apr 25, 2019 8:26 pm I like the coin idea. Especially if I think of the reinforcement we do on work ... But I would not move all to coin. Might it be a good idea to leave the wire as a real shape and only make the solid a pivy.coin node. With this all rebar operation could be done with the wire, like material bill, place rebare against each other etc.
