I found a strange behaviour when checking the option in the topic title:
- using draft move the lengthValue box is not present in the task panel and the focus is not set to x coordinate;
- when drawing a line and approaching y axis, the focus is set on the yValue box instead of length box.
Tryed to solve with: https://github.com/FreeCAD/FreeCAD/pull/2139
can you confirm?
Draft set focus on length instead of x coordinates
Re: Draft set focus on length instead of x coordinates
I was also thinking about adding the length/angle input boxes on the point UI taskpanel. I found a bit non consistent that is just displayed this when drawing a line, but not when drawing a DWire, or moving an object...
What do you think?
What do you think?
You're right. It should be available for more tools.
Basically in DraftTools.py, line 563, the line tool calls DraftGui.lineUi() which adds the extra fields. Inside the lineUi() function, the extra fields are separated in another function called extraLineUi(). I think we could start by calling extraLineUi() from wireUI() too. But there might be other steps needed...
The move tool, I think could simply use lineUI instead of pointUi, as it works basically the same way as a line.
Thanks for the hint!
I'll give it a try
I'll give it a try
I ended up fixing all these issues!
- The focus now goes on the length field when you lock the angle
- The Arch Wall, Arch Structure (in Beam mode) and Draft Move now make use of the Line interface. Still need to adapt the Draft Wire...
Great, I didn't even have the time to breath in the last few days! Thanks Yorik
Playing more with Draft and the topic title property set, i realized that many incommand shortcuts don't work:
they are forwarded to the lenght text box, but don't produce any property change. Same for some really useful keys such as x y z to lock the axis.
Anybody can confirm?
I checked the code but i couldn't realize where this is handled.
