Arch Fence
engdham
Re: Arch Fence
Post by engdham »
I'd love to test it.
Is there any appimage or something like that with this tool enabled, or I'll have to build from source? (I have never done it :? )
furti
Re: Arch Fence
Post by furti »
If you install a 0.19 development version the fence tool should be available.
Re: Arch Fence
Post by Kunda1 »
furti wrote: Thu Jul 25, 2019 3:52 pm
@furti heads-up:
https://lgtm.com/projects/g/FreeCAD/Fre ... c3c40525:1
vocx
Re: Arch Fence
Post by vocx »
Kunda1 wrote: Tue Dec 17, 2019 3:52 am @furti heads-up:
        for i in range(8):
            parts.append(Part.makeBox(20, 20, 1000 - 60,
                                      FreeCAD.Vector((2000 / 9 * (i + 1)) - 10, 15, 30)))
LGTM wrote:Result of division may be truncated as its left and right arguments may both be integers.
This is a warning about Python 2, because in Python 2 the division operator truncates the decimal part if both quantities are integers. That is, 2000/9 = 222.
In Python 3 it works as expected, 2000/9 = 222.222.
To solve this for Python 2, at least one value must be a float, 2000.0/9
See pull request #2788.
Re: Arch Fence
Post by Kunda1 »
Thanks @vocx
You rock ;)
furti
Re: Arch Fence
Post by furti »
vocx wrote: Tue Dec 17, 2019 7:59 pm See pull request #2788.
Thanks for the quick fix :) I added a comment to your pull request.
For me there are two questions:
1. As python 2 is end of life and this is not a security relevant thing, should such warnings still be fixes?
2. For this actzal warning it might be better to use "from __future__ import division" because there are more divisions in the code that might fail.
vocx
Re: Arch Fence
Post by vocx »
furti wrote: Wed Dec 18, 2019 6:01 am ... should such warnings still be fixes?
I think adding from __future__ is ugly.
But your first point is valid: this isn't a problem in Python 3 only in Python 2. We shouldn't care any more about Python 2.
Kunda, is there a way you can set LGTM to check only Python 3 errors? This would be better.
My fix just has the intention to suppress the warning. And it's a quick fix that doesn't really impact the code, whether you use Python 2 or 3, so it's the simplest solution, I feel.
Re: Arch Fence
Post by Kunda1 »
vocx wrote: Wed Dec 18, 2019 4:53 pm Kunda, is there a way you can set LGTM to check only Python 3 errors? This would be better.
Did some cursory searching and wasn't successful. I'm asking for consensus and help in:
https://forum.freecadweb.org/viewtopic. ... 59#p354959
deramirezd
Re: Arch Fence
Post by deramirezd »
Hi furti, could you please help me on understanding how how to use the fence tool? Maybe it is clear but I can't see it, I create a line and afterwards, when trying to select the fence toll, I get the message "Select the section, post and path in exactly that order to build a fence", does it mean, that I have to use the Path workbench and convert the line firstly? And if so, how? Sorry, I am quite new in the use of FreeCAD and probably the question is too simple, but I find no answer in any place how to do it. Thanks in advance!
jpolonia
Re: Arch Fence
Post by jpolonia »
I am new using this program.
But I have tried to create the fence, but I can't find it.
Could you please explain the process to create one?
Thanks for your help.
JPoland.
