Draft Scale doesn't Work in FC0.19.16883
openBrain
Re: Draft Scale doesn't Work in FC0.19.16883
Postby openBrain » Wed Jun 05, 2019 5:54 pm
yorik wrote:
Mon Jun 03, 2019 9:11 pm
Hmm many regressions because of last changes to allow working on subelements... I hadn't noticed the clone option had been removed too... Should have watched this closer... *EDIT* Fixed in git commit e2f65ef01
Hi Yorik,
After testing, there is still a regression compared to (eg.) 0.18 release. The preview isn't available during scale factor edition -only- when the reference point has been entered by manual coordinates (not with mouse click). ;) Does it deserve a ticket ?
As a collateral point, it appears that issue #3980 is now fixed. Should I just close the ticket, or will you manage to do it with some extra detail about the fixing commit and so on ?
Postby yorik » Sun Jun 09, 2019 8:35 pm
Yes, you can close the ticket I think...
About the preview not being visible anymore, it works for me both when entering scale factor and when clicking points... Can you check again?
openBrain
Postby openBrain » Sun Jun 09, 2019 9:05 pm
I confirm preview bug is still present, but maybe I didn't clearly explain.
Actually Scale function is a 2 step process. First step is to select a reference point, second is to set the scaling factors.
The difference lies in the first step (below screen) :
If you select this point with a mouse click in the 3D view, everything runs fine.
But the problem appears if you enter the reference point coordinates with keyboard.
Eg. when you land on the above screen, you don't use your mouse but instead enter with your keyboard : "0", "Enter", "0", "Enter", "0", "Enter" -- i.e. use as reference the point @(0,0,0) --. Then you will (correctly) get the step where you choose scaling factors, but in this special case (because reference point was entered with keyboard), preview won't be available when factors are changed. ;)
Postby yorik » Mon Jul 08, 2019 10:56 pm
openBrain
Postby openBrain » Sat Aug 31, 2019 11:27 am
Fixed in git commit dadd8a858
Bump this topic following some recent tests.
2 weird behaviors :
  1. Scale is always rejected if applied on original object (i.e. neither Copy nor Clone is checked) whatever are the reference point, scale values, ...
  2. When Clone is used, scaled object placement is always reset to origin whatever is the reference point
OS: Ubuntu 18.04.3 LTS (KDE/plasma)
Version: 0.19. (2019/08/21)
Python version: 3.6.8
Qt version: 5.9.5
Locale: French/France (fr_FR)
mario52
Postby mario52 » Sat Aug 31, 2019 2:17 pm
hi
weird behaviors
same
OS: Windows 10 (10.0)
Version: 0.19.17877 (Git)
Hash: 1e19ef5be4735f4200eaf99ce9e487d2be6f4151
Qt version: 5.12.1
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
Postby yorik » Tue Sep 03, 2019 3:18 am
point 1) is true only for objects that cannot natively be rescaled. Basically ATM only Draft objects support this... Maybe we should make it clearer somewhere.
point 2) indeed I see it too. Will investigate...
vocx
Postby vocx » Tue Sep 03, 2019 5:58 am
Draft Scale
Three options control the result of the scaling operation:
Modify original. The original object will have its size modified. This will only work with Draft objects and non-parametric Part shapes.
openBrain
Postby openBrain » Tue Sep 03, 2019 10:22 am
My mistake I didn't read the doc before posting... :?
However, if it isn't too much work, it would be good to get notified in FC directly that the transformation will fail. ;)
openBrain
Do you need a ticket to remember later on ?
