[Annoucement] ArchWall support Multiple Width
paullee
Postby paullee » Sun Jul 14, 2019 12:54 am
[EDIT] Latest change
- Sketch with multiple numbers of wires is supported
- And conceiving usecase of building only 1 Wall on a Sketch as layout plan
[EDIT]
Following discussion in below thread, the feature to support ArchWall to have multiple width is accepted.
https://forum.freecadweb.org/viewtopic.php?f=23&t=36772
The concept is simple, example workflow as below:-
  1. Use Draft Wire to outline the series of connecting Wall with different width
  2. Create a Wall based on the Wire
  3. Click 'OverrideWidth' in Property Panel
  4. Enter the figures of width for each segment following the order of Wire
  5. Done
Other Remarks:-
  1. You may note that it may be easier if you have the Wire alignment to either Left or Right of the Wall
    - all depends on what dimensions you have for your walls
    - whether building connecting walls on 1 wire is helpful depends on the layout and advance planning
  2. The classic Width input is overridden apparently when OverrideWidth is used
  3. When a figure in OverrideWidth is 0, the 1st figure in OverrideWidth would be used - less repeated input if possible
  4. - if 1st figure in OverrideWdth is 0, it will fallback to use figure in Width
  5. Using Sketch is similar, but watch the 'order' of the edge, 'connect' all edge in same direction ( as Sketcher 'construct' the Wire taking into account of edge direction )
Example Images / Files below and In Original Discussion Thread:-
Screenshot from 2019-07-14 08-42-00.png (300.77 KiB) Viewed 581 times
Screenshot from 2019-07-14 08-42-10.png (266.67 KiB) Viewed 581 times
Example of model if Multiple Width is not used
Wires needs some gaps / overlapping somehow
Screenshot from 2019-07-14 08-42-45.png (292.5 KiB) Viewed 581 times
Screenshot from 2019-07-14 08-42-55.png (272.3 KiB) Viewed 581 times
Test_ ArchWall_ Various Width_ 5.FCStd
(55.52 KiB) Downloaded 8 times
paullee
Re: [Annoucement] ArchWall support Multiple Width
Postby paullee » Sun Jul 14, 2019 12:56 am
More Examples in original thread
Screenshot from 2019-07-14 08-05-48.png (248.86 KiB) Viewed 579 times
Screenshot from 2019-07-14 08-10-39.png (250.83 KiB) Viewed 579 times
Screenshot from 2019-07-14 08-43-54.png (275.63 KiB) Viewed 579 times
Test_ ArchWall_ Various Width_ 3.FCStd
(10.4 KiB) Downloaded 10 times
Test_ ArchWall_ Various Width_ 2r.FCStd
(9.47 KiB) Downloaded 9 times
dimitar
Postby dimitar » Sun Jul 14, 2019 10:45 pm
Pretty neat tool! Thanks for sharing :)
paullee
Postby paullee » Fri Jul 19, 2019 6:26 pm
Ok, it should now support Sketch which resulted in multiple numbers of wires.
- just as previous, input list of figures in OverrideWidth
Screenshot from 2019-07-20 02-12-01.png (212.55 KiB) Viewed 480 times
paullee
Postby paullee » Fri Jul 19, 2019 6:30 pm
And conceiving usecase ...
- of using Sketch as layout plan
- Just 1 ArchWall on the Sketch
- set widths of different width as desired
Screenshot from 2019-07-20 02-12-27.png (223.39 KiB) Viewed 478 times
Screenshot from 2019-07-20 02-18-23.png (262.85 KiB) Viewed 478 times
Screenshot from 2019-07-20 02-21-23.png (229.79 KiB) Viewed 478 times
paullee
Postby paullee » Sun Jul 21, 2019 8:12 pm
If there are a numbers of walls with different Width in 1 Wall Object, which is based on 1 Sketch Object...
is it desirable to edit width of each wall segment with GUI?
A Mock-Up:-
phpBB [video]
paullee
Postby paullee » Thu Aug 08, 2019 6:30 pm
Another mock-up of GUI to edit width of each wall segment
phpBB [video]
