draft working plane, normal to a straight edge
bernd
Postby bernd » Wed Jul 17, 2019 4:48 am
Is there smart way to get the working plane normal to a straight edge with FreeCAD Gui?
microelly2
Re: draft working plane, normal to a straight edge
Postby microelly2 » Wed Jul 17, 2019 9:20 am
Marios Workfeature macro
yorik
Site Admin
Postby yorik » Wed Jul 17, 2019 1:48 pm
That would be an interesting feature to add... But there are 360° possibilities around the axis... We need a way to define the X direction too
bernd
Postby bernd » Wed Jul 17, 2019 3:39 pm
:o I missed that one ... since I needed just the plane in my case ...
bernd
Postby bernd » Wed Jul 17, 2019 4:15 pm
I needed it to make a circle which normal to an edge. I used Python to create the circle. But anyway I must admit it would be cool to set this.
yorik
Site Admin
Postby yorik » Thu Jul 18, 2019 2:07 pm
What we could do it simply rotate the current WP so the current axis direction becomes the edge direction (we still need to define which direction, as a linear edge can have two). The rotation around the edge will be rather uncontrollable, though...
microelly2
Postby microelly2 » Thu Jul 18, 2019 4:47 pm
I would prefer the normal and binormal vector to define the coordinate system for the plane.
I work with this direction tangent/normal or tangent/binormal here
https://www.youtube.com/watch?v=fScyrV9fB80
for the case here a 3rd combination normal/binormal is required
this are only some extra lines of code for another selection
https://en.wikipedia.org/wiki/Frenet%E2 ... t_formulas
yorik
Site Admin
Postby yorik » Fri Jul 19, 2019 2:54 pm
So the thing would be for ex. to select two edges, or an edge and a point... But then, the user could want to place the plane coplanar to it, not perpendicular...
I think this begins to bee too many options for the working plane tool. Maybe a better path would be indeed to integrate the workplane WB tools better in it?
mario52
Postby mario52 » Sun Jul 21, 2019 12:50 pm
hi
is it this ? (not perfect if the object angle change)
thanks but Marios Rentlau Workfeature macro
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
