Previous walls change when a new wall is created
bitacovir
Postby bitacovir » Sun Jul 21, 2019 6:13 pm
When I start creating a random group of walls, with each new wall the previous ones change position and dimensions. I detected this in Arch and BIM WB.
Version: 0.19.17433 (Git)
Hash: 125380ddd9a1fdeb45ffc736040dad1f6343daa4
Python version: 3.6.6
Qt version: 5.6.2
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
yorik
Site Admin
Re: Previous walls change when a new wall is created
Postby yorik » Sun Jul 21, 2019 8:39 pm
That's crazy :shock:
No such problem for me here... Do you have your FreeCAD set to produce wall baselines as sketches or draft?
bitacovir
Postby bitacovir » Sun Jul 21, 2019 8:51 pm
The wall baselines are Sketches...
::bitacovir::
My old Blog
yorik
Site Admin
Postby yorik » Mon Jul 22, 2019 12:56 pm
Can you paste here the python code that appears in the python console when you create the walls?
bitacovir
Postby bitacovir » Tue Jul 23, 2019 2:48 am
Sorry Yorik. The description of the problem was incomplete. Apparently, you need to perform some actions to produce the bug. I did not notice because the bug remains through new projects if you don't close the program... It was hard to find the original actions that trigger the bug.
Ok, here the steps:
1) create a new project and open BIMWB. Do not change the top view position.
2) create a plane with a draft tool. e.g a rectangle
3) select the surface and click on the working plane tool
4) with the new working plane on the surface, select the surface again and create a wall (this should not be intentional, of course). Now you can start creating random walls and they will change as crazy. The bug remains through new projects unless you close the program.
See the gif...
Also, I copied the python code of this session.
Python 3.6.6 | packaged by conda-forge | (default, Jul 26 2018, 11:48:23) [MSC v.1900 64 bit (AMD64)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> pl = FreeCAD.Placement()
>>> pl.Rotation.Q = (0.0,0.0,0.0,1.0)
>>> pl.Base = FreeCAD.Vector(-1154.1419677734375,-3801.42626953125,0.0)
>>> rec = Draft.makeRectangle(length=2995.591552734375,height=963.212646484375,placement=pl,face=True,support=None)
>>> Draft.autogroup(rec)
>>> FreeCAD.ActiveDocument.recompute()
>>> FreeCADGui.Snapper.setGrid()
>>> import Arch
>>> obj = Arch.makeWall(FreeCAD.ActiveDocument.Rectangle)
>>> Draft.autogroup(obj)
>>> import Part
>>> trace=Part.LineSegment(FreeCAD.Vector (4531.916015625, 3949.171875, 0.0),FreeCAD.Vector (4223.68798828125, 2629.570556640625, 0.0))
>>> base=FreeCAD.ActiveDocument.addObject("Sketcher::SketchObject","WallTrace")
>>> base.Placement = FreeCAD.DraftWorkingPlane.getPlacement()
>>> base.addGeometry(trace)
>>> wall = Arch.makeWall(base,width=200.0,height=3000.0,align="Center")
>>> wall.Normal = FreeCAD.DraftWorkingPlane.getNormal()
>>> Draft.autogroup(wall)
>>> import Part
>>> trace=Part.LineSegment(FreeCAD.Vector (3751.7138671875, 3920.2755737304688, 0.0),FreeCAD.Vector (3896.19580078125, 2841.4775390625, 0.0))
>>> import Part
>>> trace=Part.LineSegment(FreeCAD.Vector (3472.382080078125, 3862.4827270507812, 0.0),FreeCAD.Vector (3087.096923828125, 2687.3634643554688, 0.0))
>>> import Part
>>> trace=Part.LineSegment(FreeCAD.Vector (2576.59423828125, 3804.690185546875, 0.0),FreeCAD.Vector (2759.604736328125, 2880.0059204101562, 0.0))
Qt version: 5.6.2
::bitacovir::
My old Blog
yorik
Site Admin
Postby yorik » Fri Jul 26, 2019 2:10 pm
I still can't reproduce the problem...
1) I create a rectangle
2) I set the WP to the rectangle
3) I create a wall with the rectangle selected. This produces a wall that uses the rectangle as its base shape
4) With or without that wall selected, I can create more walls, none shows the erratic behaviour...
Am I missing something?
bitacovir
Postby bitacovir » Fri Jul 26, 2019 8:25 pm
Yes. Those are the steps. That is how the problem happens. I tried with a different laptop running Ubuntu and the problem is the same. So, it is not my computer.
I recorded a video:
phpBB [video]
OS: Ubuntu 16.04.6 LTS (LXDE/Lubuntu)
Version: 0.19.17175 (Git) AppImage
Hash: 507c40669d48ae4732268324cd0140c80cf68222
Python version: 3.7.3
Qt version: 5.9.7
Locale: Spanish/Spain (es_ES)
Can anybody else reproduce this bug?
::bitacovir::
My old Blog
paullee
Postby paullee » Sat Jul 27, 2019 1:41 am
I had found some very minor weird behaviours in FC :) This one very hard to make, spending an hour repeat random test, not sure the exact steps in fact... capture this one.
I do not go through this step ...
(Not know how to make animated gif)
phpBB [video]
FreeCAD_0.19-17445-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
on
Fedora 30
Test_ ArchWall_ Weird Behaviour.FCStd
(16.5 KiB) Downloaded 19 times
paullee
Re:( Previous ) walls change when a new wall is created
Postby paullee » Sat Aug 17, 2019 7:44 pm
Capture another similar weird behaviour ...
- no need to add a new wall to make 'previous' wall changes
Steps to reproduce:-
  1. Probably add an new Wall with a segment ( or open the attached file )
  2. If the underlying sketch is marked for recompute ( or just mark the underlying sketch in attached file to recompute)
  3. (Keep press / click) Ctrl-R or click button to recompute
  4. The Wall / Sketch segment keep move / rotate
FreeCAD_0.19-17512-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage on Fedora 30
phpBB [video]
Test_ ArchWall_ Weird Behaviour_ 2.FCStd
(8.51 KiB) Downloaded 23 times
Roy_043
Postby Roy_043 » Sat Aug 17, 2019 7:59 pm
@paullee:
Confirmed:
OS: Windows 8.1 (6.3)
Version: 0.19.17505 (Git)
Hash: 755536e9df94d2d39da1468420f1fd333c35da7a
Python version: 3.6.8
Qt version: 5.12.1
