Roy_043 wrote: ↑Thu Oct 10, 2019 8:03 am
@wandererfan:
Yes, it works! I'll have to get used to the dialog, but I can live with that. Thank you!
I've made a crude hack to only have the non-native dialog for the ShapeString Task Panel by changing src\Mod\Draft\DraftGui.py around line 2460 from:
self.stringText = translate("draft","Default")
self.task.leString.setText(self.stringText)
self.task.fcFontFile.setFileName(Draft.getParam("FontFile",""))
self.fileSpec = Draft.getParam("FontFile","")
self.point = FreeCAD.Vector(0.0,0.0,0.0)
self.pointPicked = False
QtCore.QObject.connect(self.task.fcFontFile,QtCore.SIGNAL("fileNameSelected(const QString&)"),self.fileSelect)
QtCore.QObject.connect(self.task.pbReset,QtCore.SIGNAL("clicked()"),self.resetPoint)
self.point = None
self.view = Draft.get3DView()
self.call = self.view.addEventCallback("SoEvent",self.action)
FreeCAD.Console.PrintMessage(translate("draft", "Pick ShapeString location point:")+"\n")
def fileSelect(self, fn):
self.fileSpec = fn
def resetPoint(self):
origin = FreeCAD.Vector(0.0,0.0,0.0)
self.setPoint(origin)
def action(self,arg):
"""scene event handler"""
import DraftTools
if arg["Type"] == "SoKeyboardEvent":
if arg["Key"] == "ESCAPE":
self.reject()
elif arg["Type"] == "SoLocation2Event": #mouse movement detection
self.point,ctrlPoint,info = DraftTools.getPoint(self.sourceCmd,arg,noTracker=True)
if not self.pointPicked:
self.setPoint(self.point)
elif arg["Type"] == "SoMouseButtonEvent":
if (arg["State"] == "DOWN") and (arg["Button"] == "BUTTON1"):
self.pointPicked = True
def setPoint(self, point):
self.task.sbX.setProperty('rawValue',point.x)
self.task.sbY.setProperty('rawValue',point.y)
self.task.sbZ.setProperty('rawValue',point.z)
def createObject(self):
"""creates object in the current doc"""
dquote = '"'
if sys.version_info.major < 3: # Python3: no more unicode
String = 'u' + dquote + str(self.task.leString.text().encode('unicode_escape')) + dquote
else:
String = dquote + self.task.leString.text() + dquote
FFile = dquote + str(self.fileSpec) + dquote
Size = str(FreeCAD.Units.Quantity(self.task.sbHeight.text()).Value)
Tracking = str(0.0)
x = FreeCAD.Units.Quantity(self.task.sbX.text()).Value
y = FreeCAD.Units.Quantity(self.task.sbY.text()).Value
z = FreeCAD.Units.Quantity(self.task.sbZ.text()).Value
ssBase = FreeCAD.Vector(x,y,z)
# this try block is almost identical to the one in DraftTools
try:
qr,sup,points,fil = self.sourceCmd.getStrings()
FreeCADGui.addModule("Draft")
self.sourceCmd.commit(translate("draft","Create ShapeString"),
['ss=Draft.makeShapeString(String='+String+',FontFile='+FFile+',Size='+Size+',Tracking='+Tracking+')',
'plm=FreeCAD.Placement()',
'plm.Base='+DraftVecUtils.toString(ssBase),
'plm.Rotation.Q='+qr,
'ss.Placement=plm',
'ss.Support='+sup,
'Draft.autogroup(ss)'])
except Exception as e:
FreeCAD.Console.PrintError("Draft_ShapeString: error delaying commit\n")
def accept(self):
self.createObject();
if self.call: self.view.removeEventCallback("SoEvent",self.call)
FreeCADGui.ActiveDocument.resetEdit()
FreeCADGui.Snapper.off()
self.sourceCmd.creator.finish(self.sourceCmd)
return True
def reject(self):
return True
to:
tDialog = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Dialog")
import platform
if platform.system() == 'Windows':
tDialog.SetBool("DontUseNativeDialog", True)
self.point = None
self.fileSpec = fn
import DraftTools
self.reject()
dquote = '"'
else:
Tracking = str(0.0)
try:
'ss.Placement=plm',
'ss.Support='+sup,
def accept(self):
import platform
tDialog.SetBool("DontUseNativeDialog", False)
return True
def reject(self):
import platform
return True
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18504 (Git)
Hash: f66023a646db4b2502bb3637897443b3525ca3c7
Python version: 3.6.8
Qt version: 5.12.1
