Flipping direction of section plane
dimitar
Post by dimitar »
Is there a way to flip the direction of the section plane so it cuts the model on the opposite side of the plane, with the Vie -> Cut View property on?
I have played with negative normals flipping t-1, and change the angle or rotation to 180 deg and -180 deg, and the section still cuts the same way.
paullee
Re: Flipping direction of section plane
Post by paullee »
dimitar
Post by dimitar »
Yes along those lines, but I am cutting a 3d section and the 3d section does not seem to respect positive or negative angles or normals in regards to which side of the section plane is shown and which side of the section plane is visible
paullee
Post by paullee »
Do you want to post a file to show what you are after?
The discussion in the link indicates the section plane can be rotated to alter the direction of cut - with some unexpected result though I remember.
dimitar
Post by dimitar »
paullee wrote: Fri Aug 09, 2019 5:55 pm Do you want to post a file to show what you are after?
Yes, I read it. I tried rotating the section, flipping the normals, positive rotation, negative rotation, but in the viewport, it still cut in the same way.
dimitar wrote: Fri Aug 09, 2019 6:46 pm but in the viewport, it still cut in the same way.
Did you make a full recompute of the whole document?
yorik
Founder
Post by yorik »
Normally just rotating it 180° along its X or Y axis should do it... But I'll check here when I have a moment
FATHI RAMMAH
Post by FATHI RAMMAH »
you must add the desired objects to the section plane
yorik
Founder
Post by yorik »
It seems to work ok for me... Note that by double-clicking the section plane in the tree, you have several options to quickly rotate and resize it.
