[ PR - Arch Wall - BUG ] Sketch Base RemoveSplitter Problem - EDITED
[EDIT] 2019.10.13 - maybe it had been 0.18 bug (see below post at https://forum.freecadweb.org/viewtopic. ... 13#p340613)
Title edited.
Dimitar reported Arch Wall do not properly build if base on Sketch in
https://forum.freecadweb.org/viewtopic. ... 50#p326160
https://forum.freecadweb.org/viewtopic. ... 50#p326189
https://forum.freecadweb.org/viewtopic. ... 50#p326197
I further test the same file works properly to build wall on 0.18, but no longer....
"In addition to my test that 0.18 works without problem,
and FreeCAD_0.19-16790-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage had been not working ...
I had
FreeCAD_0.19.16291_Conda_Py3Qt5_glibc2.12-x86_64.AppImage
and it is not working then.."
[EDIT]
tested below AppImage on Fedora 30
FreeCAD_0.19-17512-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
Title edited.
I had
[EDIT]
- WallTest_ Paul.FCStd
- (8.93 KiB) Downloaded 45 times
- walltest.FCStd
- (20.42 KiB) Downloaded 45 times
Re: [ 0.19_pre BUG ] Arch Wall on Sketch Problem after 0.18
Found only 'Center' Align is problematic
No problem if it is Left or Right Align ...
Interestingly removing the shortest line from the sketch fixes the problem. The same goes for reversing the direction of this line.
OS: Windows 8.1 (6.3)
Version: 0.19.17505 (Git)
Hash: 755536e9df94d2d39da1468420f1fd333c35da7a
Python version: 3.6.8
Qt version: 5.12.1
Pretty weird, no idea what has changed from 0.18.3 to 0.19_pre resulting this ...
... missing edges this time ... no problem in 0.18.3
0.19_pre
FreeCAD_0.19-17512-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage on Fedora 30
0.18.3
0.19_pre
0.18.3
- Test_ ArchWall_ Various Width_ on Sketch Multiple Wire_ 14a _ Layout.fcstd
- (20.63 KiB) Downloaded 43 times
Similarly... when align is Center, there is a bug...
When align is left or right, no problem
Probably our wire offsetting code in DraftGeomUtils fails. Maybe we could make it more verbose...
Thanks looking into this.
But it works on 0.18.3, no longer in 0.19_pre whatever the earliest AppImage I have.
Tried to look at the difference between the 2 version of DraftGeomUtils, but do not notice anything special to my knowledge ...
This time, it is Left Align which return problematic wall solid ?
Curious why 0.18.3 works... no such problem though sketch is complex ...
- Test_ ArchWall_ Various Width_ on Sketch Multiple Wire_ 15 _ Layout.fcstd
- (8.52 KiB) Downloaded 44 times
Suspect there maybe something wrong about :-
- DraftGeomUtils.removeSplitter()
- removing the ArchWall.getExtrusionData()... removeSplitter ... code make it works again
# baseface = baseface.removeSplitter() #s = DraftGeomUtils.removeSplitter(baseface) #if s: # baseface = s
Seem i was wrong, repeating test on 0.18, it was not working
(Maybe kind of random?)
( FreeCAD_0.18-16131-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
on
Fedora 30 )
on
Fedora 30 )
