After Arch Remove geometry changes color
Create a wall with Arch Wall tool
Create a cube with PartWB
Move the cube on the wall to perform Arch Remove
Select first the cube and second the wall
Perform Arch Remove
Turn on the hidden cube. The color and transparency of the cube are different (blue, 80%).
Is It a new feature?
OS: Windows 10 (10.0)
Version: 0.19.18213 (Git)
Hash: 22babc09954ac6fda9135ee71d68550921659b1c
Python version: 3.6.8
Qt version: 5.12.1
Perform Arch Remove
Qt version: 5.12.1
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Re: After Arch Remove geometry changes color
I assume it is. Note: the Point color remains unchanged.
Depends on your definition of "new", but yes this is the normal behavior for a few months. Is it not present in 0.18?
I quickly looked at the source, but I don't know where the color change is defined.
When you press the Arch Remove button, it calls _CommandRemove(), https://github.com/FreeCAD/FreeCAD/blob ... s.py#L1342, which then calls Arch.removeComponents() https://github.com/FreeCAD/FreeCAD/blob ... ds.py#L158
It basically adds objects to the Subtraction attribute. So maybe there is some code inside the Object to change the appearance of each Subtraction element.
Thanks. It is new for me. I used to work with boolean operation rather than Arch Remove.
::bitacovir::
If you want to find it in the code: look at ArchCommands.py line 269. The construction color from the preferences is used.
As already mentioned the point color is not handled. @vocx: I think you have permissions to fix this (pull request etc.)?
def setAsSubcomponent(obj):
'''Sets the given object properly to become a subcomponent (addition, subtraction)
of an Arch component'''
Draft.ungroup(obj)
if FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Arch").GetBool("applyConstructionStyle",True):
if FreeCAD.GuiUp:
color = getDefaultColor("Construction")
if hasattr(obj.ViewObject,"LineColor"):
obj.ViewObject.LineColor = color
if hasattr(obj.ViewObject,"ShapeColor"):
obj.ViewObject.ShapeColor = color
if hasattr(obj.ViewObject,"Transparency"):
obj.ViewObject.Transparency = int(color[3]*100)
obj.ViewObject.hide()
What does it mean not handled? Do you also want to change the color of the point? Do you prefer a different color?
Everybody has permission to submit a pull request, but only a few developers can merge the requests, which I can't.
So, sure, I can submit a change, but since Yorik is traveling currently, he may take a while to merge things. As long as it's not urgent, I think we can just submit the change to the queue and wait for him.
That the color of the points remains unchanged is not a huge problem, unless you are very obsessive that the points should definitely also change their color.
No, man, no bug tracker; I just mean this: pull request #2532.
Now the pull request sits on the queue. The administrators can merge it if they want, although most probably they will wait for Yorik to return so he does it.
OK, thanks for the pull request.
Indeed: it is not very important, but not reporting these little things when you stumble over them would not make sense IMO.
Thanks for the fix, sorry for the delay! It's merged now
