Latest BIM does not work in V0.18
Roy_043
Post by Roy_043 »
FYI: The latest BIM download does not work properly in V0.18. Switching to the BIM WB is not possible. The following error is displayed:
class _CommandStructure has no attribute '__init__'
File "<string>", line 110, in Initialize
File "C:\Users\UserName\AppData\Roaming\FreeCAD\Mod\BIM\BimCommands.py", line 402, in __init__
ArchStructure._CommandStructure.__init__(self)
vocx
Re: Latest BIM does not work in V0.18
Post by vocx »
Roy_043 wrote: Fri Oct 11, 2019 5:59 pm ...
Is there more to this error? It is complaining about a missing __init__() function, but it is there.
https://github.com/FreeCAD/FreeCAD/blob ... re.py#L188
class _CommandStructure:
    "the Arch Structure command definition"
    def __init__(self):
        self.beammode = False
yorik
Founder
Post by yorik »
Should be fixed now! However, in 0.18, both the column and beam tools will work exactly the same...
Roy_043
Post by Roy_043 »
The fix seems to work here. Thank you Yorik.
OS: Windows 8.1
Word size of FreeCAD: 32-bit
Version: 0.18.16093 +38 (Git)
Branch: (HEAD detached at 0.18.3)
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 2.7.14
OCC version: 7.2.0
Roy_043
Post by Roy_043 »
MaxP may be a spammer (off-topic link in signature).
Thanks for reporting! I removed all of his posts and banned him.
