New unit tests for Draft Workbench
vocx
Post by vocx »
Taking inspiration from the FEM Workbench, I decided to re-work the unit tests of the Draft Workbench.
The new tests are in pull request #2668.
Test with
freecad -t TestDraft
freecadcmd -t TestDraft
Basic tests include being able to import the existing modules of the workbench like Draft.py, DraftTools.py, DraftGui.py, etc. So if new modules are added, or renamed, the unit tests need to be changed accordingly.
Then we test each of the "creation" tools, like line, wire, circle, arc, rectangle, etc. And then each of the "modification" tools, like move, copy, clone, array, polar array, etc.
Not every test is currently implemented. Why? Because in order to test a tool automatically, we need to have a basic function that produces the action we want. For example, to test a rectangle, we just run Draft.makeRectangle(). But to test the Draft Trimex tool there is no Draft.trimex() function that we can call; this tool is implemented as a combination of various instructions but there is no single function that does the task. So we must have basic functions in Draft.py that encapsulate the action that we want, and then we can test them.
For the tests that are not implemented, we define a fake function that just returns True resulting in the test passing automatically. The fake function serves as a placeholder for the real function that should be written at some point in the future.
This also ties into this thread, Discussion: renaming the graphical commands. As I mentioned, a button or a menu action is a "graphical" command that requires the graphical interface loaded. We must be certain each of these have an underlying command that doesn't need the graphical interface. For example, the Draft Facebinder tool is most commonly used from the 3D view but the underlying Draft.makeFacebinder() can also be called without the interface by specifying a correct list of objects and faces.
This also ties with this thread, [Discussion] Splitting Draft tools into their own modules. Splitting the tools in many modules may introduce some errors, so by having the unit tests we have more certainty that the tools are still working as we expect them to.
There are also simple tests for the import and export of SVG, DXF, DWG, and OCA files. Currently none of these are truly implemented; they use the fake function that I mentioned above. In order to have real tests, we should provide sample files in the source tree, a sample SVG, sample DXF, sample DWG, etc., and see if the operations of open, import, and export, work correctly with those.
For a more exhaustive unit test, we should write many tests for each geometrical element, that is, line, circle, arc, rectangle, etc., and check that each is correctly imported and exported. This is a bit tedious to do; maybe a student from a Google Summer of Code can work on it.
The new proposed TestDraft.py is pretty long. But similarly to FEM, later we can split the tests into various modules, which is better for managing them, and adding new tests.
I still get the crash reported here, Crash: when testing Draft Dimension. Since not many people get the crash, I suspect it's a combination of Coin3D with my particular version of Ubuntu, Qt 5.9, or something else.
Both of these crash in my system, but only if run individually. If I run the entire set of tests, there is no crash.
freecad -t TestDraft.DraftCreation.test_dimension_linear
freecad -t TestDraft.DraftCreation.test_label
I suspect the problem has something to do with the textual element created by Coin. These two produce App::FeaturePython objects instead of Part::Part2DObjectPython (wiki Part_Part2DObject) or Part::FeaturePython (wiki Part_Feature), like most Draft geometrical elements.
Re: New unit tests for Draft Workbench
Post by Kunda1 »
Ran PR against
OS: Manjaro Linux (XFCE/xfce)
Version: 0.19.18614 (Git) AppImage
Hash: efd55884ad7d40e77571a60c5bb906bbd8d1cbbd
Python version: 3.7.3
Qt version: 5.12.5
Result:
Here is error for convenience:
ERROR: test_cubicbezcurve (TestDraft.DraftCreation)
Create a cubic bezier curve of four points.
  File "/home/foo/bin/squashfs-root/usr/Mod/Draft/TestDraft.py", line 467, in test_cubicbezcurve
    Vector(9, 0, 0)], Degree=3)
TypeError: makeBezCurve() got an unexpected keyword argument 'Degree'
Ran 66 tests in 1.912s
FAILED (errors=1)
Here is the function that the problem is in:
    def test_cubicbezcurve(self):
        """Create a cubic bezier curve of four points."""
        App.Console.PrintLog('Checking Draft CubicBezCurve...\n')
        Draft.makeBezCurve([Vector(0, 0, 0),
                            Vector(2, 2, 0),
                            Vector(5, 3, 0),
        self.assertTrue(App.ActiveDocument.getObject("BezCurve"),
                        "Draft CubicBezCurve failed")
The rest of the output
$ ./AppRun -t TestDraft
/home/beast/bin/squashfs-root
FreeCAD 0.19, Libs: 0.19R18614 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
connect failed: No such file or directory
test_export_DXF (TestDraft.DraftAirfoilDAT)
Export a DXF. ... Test currently not implemented
ok
test_read_DXF (TestDraft.DraftAirfoilDAT)
Read a DXF. ... Test currently not implemented
ok
test_arc (TestDraft.DraftCreation)
Create a circular arc. ...
Temporary document 'DraftCreation'
Test 'Draft Arc'
ok
test_arc_3points (TestDraft.DraftCreation)
Create a circular arc from three points. ...
Test 'Draft Arc 3Points'
# This test is not implemented currently #
Automatic PASS
ok
test_bezcurve (TestDraft.DraftCreation)
Create a bezier curve of six points, degree five. ...
ok
test_bspline (TestDraft.DraftCreation)
Create a BSpline of three points. ...
ok
test_circle (TestDraft.DraftCreation)
Create a circle. ...
Test 'Draft Circle'
ok
Create a cubic bezier curve of four points. ...
ERROR
test_dimension_linear (TestDraft.DraftCreation)
Create a linear dimension. ...
Test 'Draft Dimension'
ok
test_dimension_radial (TestDraft.DraftCreation)
Create a radial dimension. NOT IMPLEMENTED CURRENTLY. ...
Test 'Draft Dimension Radial'
Automatic PASS
ok
test_ellipse (TestDraft.DraftCreation)
Create an ellipse. ...
Test 'Draft Ellipse'
ok
test_facebinder (TestDraft.DraftCreation)
Create a Facebinder. NOT IMPLEMENTED CURRENTLY. ...
This test doesn't do anything at the moment. In order to test this, a selection is needed.
ok
test_fillet (TestDraft.DraftCreation)
Create a fillet between two lines. ...
Test 'Draft Fillet'
o1: Line, length: 8.0
o2: Line001, length: 8.0
e1, length: 3.999999999999999
e2, length: 6.283185307179587
e3, length: 3.999999999999999
ok
test_label (TestDraft.DraftCreation)
Create a label. ...
ok
test_line (TestDraft.DraftCreation)
Create a line. ...
Test 'Draft Line'
ok
test_point (TestDraft.DraftCreation)
Create a point. ...
ok
test_polygon (TestDraft.DraftCreation)
Create a regular polygon. ...
Test 'Draft Polygon'
ok
test_polyline (TestDraft.DraftCreation)
Create a polyline. ...
Test 'Draft Wire'
ok
test_rectangle (TestDraft.DraftCreation)
Create a rectangle. ...
Test 'Draft Rectangle'
ok
test_shapestring (TestDraft.DraftCreation)
Create a ShapeString. NOT IMPLEMENTED CURRENTLY. ...
This test doesn't do anything at the moment. In order to test this, a font file is needed.
ok
test_text (TestDraft.DraftCreation)
Create a text object. ...
Test 'Draft Text'
ok
test_export_DXF (TestDraft.DraftDWG)
ok
test_read_DXF (TestDraft.DraftDWG)
ok
test_export_DXF (TestDraft.DraftDXF)
ok
test_read_DXF (TestDraft.DraftDXF)
ok
test_import_GUI_DraftGui (TestDraft.DraftGuiImport)
Import Draft TaskView GUI tools. ...
Try importing 'DraftGui'
ok
test_import_GUI_Draft_snap (TestDraft.DraftGuiImport)
Import Draft snapping. ...
Try importing 'DraftSnap'
ok
test_import_GUI_Draft_tools (TestDraft.DraftGuiImport)
Import Draft graphical commands. ...
Try importing 'DraftTools'
ok
test_import_GUI_Draft_trackers (TestDraft.DraftGuiImport)
Import Draft tracker utilities. ...
Try importing 'DraftTrackers'
ok
test_import_Draft (TestDraft.DraftImport)
Import the Draft module. ...
Try importing 'Draft'
ok
test_import_Draft_SVG (TestDraft.DraftImport)
Import Draft SVG utilities. ...
Try importing 'getSVG'
ok
test_import_Draft_geomutils (TestDraft.DraftImport)
Import Draft geometrical utilities. ...
Try importing 'DraftGeomUtils'
ok
test_import_Draft_vecutils (TestDraft.DraftImport)
Import Draft vector utilities. ...
Try importing 'DraftVecUtils'
ok
test_import_GUI_DraftEdit (TestDraft.DraftImportTools)
Import Draft Edit. ...
Try importing 'DraftEdit'
ok
test_import_GUI_DraftFillet (TestDraft.DraftImportTools)
Import Draft Fillet. ...
Try importing 'DraftFillet'
ok
test_import_GUI_DraftLayer (TestDraft.DraftImportTools)
Import Draft Layer. ...
Try importing 'DraftLayer'
ok
test_import_GUI_DraftPlane (TestDraft.DraftImportTools)
Import Draft SelectPlane. ...
Try importing 'DraftSelectPlane'
ok
test_import_WorkingPlane (TestDraft.DraftImportTools)
Import Draft WorkingPlane. ...
Try importing 'WorkingPlane'
ok
testCloneOfPart (TestDraft.DraftModification)
Create a clone of a Part.Box. ... ok
testCopy (TestDraft.DraftModification)
Create a line, then copy and move it. ... ok
testMove (TestDraft.DraftModification)
Create a line and move it. ... ok
testOffset (TestDraft.DraftModification)
Create a rectangle, then produce an offset copy. ... ok
testRotate (TestDraft.DraftModification)
Create a line, then rotate it. ... ok
test_downgrade (TestDraft.DraftModification)
Downgrade a face. NOT IMPLEMENTED. ... ok
test_draft_to_drawing (TestDraft.DraftModification)
Create a draft projection in a Drawing page. NOT IMPLEMENTED. ... ok
test_draft_to_sketch (TestDraft.DraftModification)
Convert a Draft object to a Sketch. NOT IMPLEMENTED. ... ok
test_extend (TestDraft.DraftModification)
Extend a line. NOT IMPLEMENTED. ... ok
test_join (TestDraft.DraftModification)
Join two lines. NOT IMPLEMENTED. ... ok
test_mirror (TestDraft.DraftModification)
Create a mirrored shape. NOT IMPLEMENTED. ... ok
test_path_array (TestDraft.DraftModification)
Create a path array. NOT IMPLEMENTED. ... ok
test_point_array (TestDraft.DraftModification)
Create a point array. NOT IMPLEMENTED. ... ok
test_polar_array (TestDraft.DraftModification)
Create a polar array. NOT IMPLEMENTED. ... ok
test_rectangular_array (TestDraft.DraftModification)
Create a rectangular array. NOT IMPLEMENTED. ... ok
test_shape_2D_view (TestDraft.DraftModification)
Create a 2D projection. NOT IMPLEMENTED. ... ok
test_sketch_to_draft (TestDraft.DraftModification)
Convert a Sketch to Draft object. NOT IMPLEMENTED. ... ok
test_split (TestDraft.DraftModification)
Split a polyline. NOT IMPLEMENTED. ... ok
test_stretch (TestDraft.DraftModification)
Stretch a line. NOT IMPLEMENTED. ... ok
test_trim (TestDraft.DraftModification)
Trim a line. NOT IMPLEMENTED. ... ok
test_upgrade (TestDraft.DraftModification)
Upgrade series of edges. NOT IMPLEMENTED. ... ok
test_wire_to_Bspline (TestDraft.DraftModification)
Convert a polyline to BSpline. NOT IMPLEMENTED. ... ok
test_export_DXF (TestDraft.DraftOCA)
ok
test_read_DXF (TestDraft.DraftOCA)
ok
test_Pivy (TestDraft.DraftPivy)
Import Pivy Coin. ...
Temporary document 'DraftPivy'
Try importing 'pivy.coin'
ok
test_Pivy_draw (TestDraft.DraftPivy)
Use Coin (pivy.coin) to draw a cube on the active view. ...
Draw cube
Adding cube to the active view scene
ok
test_export_SVG (TestDraft.DraftSVG)
Export an SVG. ... Test currently not implemented
ok
test_read_SVG (TestDraft.DraftSVG)
Read an SVG. ... Test currently not implemented
ok
FAILED (errors=1)
System exit
carlopav
Post by carlopav »
Great @Vox, this will be really helpful!
BTW can you explain i should i be supposed to run it in windows? I'm a real beginner :)
vocx
Post by vocx »
Kunda1 wrote: Mon Oct 28, 2019 10:53 am ...
Use code tags, not quote tags.
You have an old version of my branch. You have to use the newest version.
Previously, the makeBezCurve() function had an argument called Degree. This was changed in git commit 0c18f5e25 (0.19.18433) to lowercase, degree.
An old version of my branch tests for "Degree", while the newest version tests for the current lowercase argument.
vocx
Post by vocx »
carlopav wrote: Mon Oct 28, 2019 2:10 pm Great @Vox, this will be really helpful!
Have you ever run FreeCAD from the command line in Windows?
If the FreeCAD executable is in the PATH, I think you should be able to open a command prompt, and run this
freecad --run-test TestDraft
This should be possible already as there is already a TestDraft.py, in src/Mod/Draft. However, currently there are only 17 tests, which don't test every single tool in the Draft Workbench. See testing (this page needs to be greatly expanded, by the way).
If you get my branch, through Git, then new tests, 66 in total, will be available. You test them the same.
You can also run the tests from within FreeCAD, by switching to the Test Framework Workbench. Then Test commands -> TestToolsGui -> Self test -> Select test name -> TestDraft -> Start.
carlopav
Post by carlopav »
thanks, really useful. Guess that i have to build your branch to be able to run it, isnt'it? this is another thing to learn :)
Post by Kunda1 »
vocx wrote: Mon Oct 28, 2019 3:56 pm
I pulled what you submitted as a PR. You may want to update that, in that case.
https://github.com/FreeCAD/FreeCAD/pull ... ac2c91758b
vocx
Post by vocx »
carlopav wrote: Mon Oct 28, 2019 4:44 pm thanks, really useful. Guess that i have to build your branch to be able to run it, isnt'it? this is another thing to learn :)
Well, obviously. Currently the code is not in master, so you have to get my branch to test this.
Since this is Python code, it doesn't need recompilation actually. You can just grab the single src/Mod/Draft/TestDraft.py file in my branch, and paste it over the existing TestDraft.py in your Mod/Draft directory.
vocx
Post by vocx »
Kunda1 wrote: Mon Oct 28, 2019 5:30 pm I pulled what you submitted as a PR. You may want to update that, in that case.
That's not possible. You are clearly running outdated code, according to your log above.
I suspect you have to refresh the repositories in your GitKraken or something like that. I pushed my branch to GitHub, and then squashed all commits to have a single commit for the pull request. If a user forks my branch before the squashing, they may experience problems because of the re-written history.
If you see the pull request now, it clearly tests for the new code. https://github.com/FreeCAD/FreeCAD/pull ... 7R547-R558
        operation = "Draft CubBezCurve"
        _msg("  Test '{}'".format(operation))
        a = Vector(0, 0, 0)
        b = Vector(2, 2, 0)
        c = Vector(5, 3, 0)
        d = Vector(9, 0, 0)
        _msg("  a={0}, b={1}".format(a, b))
        _msg("  c={0}, d={1}".format(c, d))
        obj = Draft.makeBezCurve([a, b, c, d], degree=3)
        self.assertTrue(obj, "'{}' failed".format(operation))
This is the output you should see
bin/FreeCAD -t TestDraft
FreeCAD 0.19, Libs: 0.19R18628 +1 (Git)
(FreeCAD:14930): Gtk-WARNING **: 12:17:02.980: Theme parsing error: gtk.css:27:35: Junk at end of value for background-color
(FreeCAD:14930): Gtk-WARNING **: 12:17:02.980: Theme parsing error: gtk.css:40:48: Junk at end of value for background-color
(FreeCAD:14930): Gtk-WARNING **: 12:17:02.980: Theme parsing error: gtk.css:48:46: Junk at end of value for background-color
(FreeCAD:14930): Gtk-WARNING **: 12:17:02.980: Theme parsing error: gtk.css:59:58: Junk at end of value for background-color
(FreeCAD:14930): Gtk-WARNING **: 12:17:02.980: Theme parsing error: gtk.css:66:28: The :prelight pseudo-class is deprecated. Use :hover instead.
(FreeCAD:14930): Gtk-WARNING **: 12:17:02.980: Theme parsing error: gtk.css:70:46: Junk at end of value for background-color
(FreeCAD:14930): Gtk-WARNING **: 12:17:02.980: Theme parsing error: gtk.css:77:35: The :prelight pseudo-class is deprecated. Use :hover instead.
(FreeCAD:14930): Gtk-WARNING **: 12:17:02.980: Theme parsing error: gtk.css:81:58: Junk at end of value for background-color
libpng warning: iCCP: known incorrect sRGB profile
test_export_airfoildat (TestDraft.DraftAirfoilDAT)
Create some figures and export them to an airfoil DAT file. ...
  Temporary document 'DraftAirfoilDAT'
  Test 'importAirfoilDAT.export'
  file=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/out_test.dat
  exists=False
  Arguments to placeholder function
  p1=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/out_test.dat; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
test_read_airfoildat (TestDraft.DraftAirfoilDAT)
Read an airfoil DAT file and import its elements as objects. ...
  Test 'importAirfoilDAT.import'
  This test requires a DAT file with airfoil data to read.
  file=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/test.dat
  exists=False
  p1=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/test.dat; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  Test 'Draft Arc'
  radius=2
  startangle=0, endangle=90
ok
  a=Vector (5.0, 0.0, 0.0), b=Vector (4.0, 3.0, 0.0)
  c=Vector (0.0, 5.0, 0.0)
  p1=Vector (5.0, 0.0, 0.0); p2=Vector (4.0, 3.0, 0.0)
  p3=Vector (0.0, 5.0, 0.0); p4=None
  p5=None
  Automatic PASS
ok
  Test 'Draft BezCurve'
  a=Vector (0.0, 0.0, 0.0), b=Vector (2.0, 2.0, 0.0)
  c=Vector (5.0, 3.0, 0.0), d=Vector (9.0, 0.0, 0.0)
  e=Vector (12.0, 5.0, 0.0), f=Vector (12.0, 8.0, 0.0)
ok
  Test 'Draft BSpline'
  a=Vector (0.0, 0.0, 0.0), b=Vector (2.0, 0.0, 0.0)
  c=Vector (2.0, 2.0, 0.0)
ok
  Test 'Draft Circle'
  radius=3
ok
  Test 'Draft CubBezCurve'
ok
  Occasionaly crashes
  a=Vector (0.0, 0.0, 0.0), b=Vector (9.0, 0.0, 0.0)
  c=Vector (4.0, -1.0, 0.0)
ok
  p5=None
  Automatic PASS
ok
  major_axis=5, minor_axis=3
ok
Create a box, and then a facebinder from its faces. ...
  Test 'Draft Facebinder'
  or an App::PropertyLinkSubList
  Box
  object='Solid' (Part::Box)
  sub-elements=('Face1', 'Face6')
ok
Create two lines, and a fillet between them. ...
  Test 'Draft Fillet'
  Lines
  a=Vector (0.0, 0.0, 0.0), b=Vector (8.0, 0.0, 0.0)
  b=Vector (8.0, 0.0, 0.0), c=Vector (8.0, 8.0, 0.0)
  Fillet
  radius=4
ok
Create a label. ...
  Test 'Draft Label'
  Occasionaly crashes
  target_point=Vector (0.0, 0.0, 0.0), distance=-25
  placement=Placement [Pos=(50,50,0), Yaw-Pitch-Roll=(0,0,0)]
ok
Create a line. ...
  Test 'Draft Line'
ok
Create a point. ...
  Test 'Draft Point'
  p.x=5.0, p.y=3.0, p.z=2.0
ok
  n_faces=6, radius=5
ok
  Test 'Draft Wire'
ok
  length=5, width=2
ok
  Test 'Draft ShapeString'
  text='Testing Shapestring ', font='None'
  p1=Text; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  Test 'Draft Text'
  text='Testing testing'
ok
test_export_dwg (TestDraft.DraftDWG)
Create some figures and export them to a DWG file. ...
  Temporary document 'DraftDWG'
  Test 'importDWG.export'
  file=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/out_test.dwg
  exists=False
  p1=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/out_test.dwg; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
test_read_dwg (TestDraft.DraftDWG)
Read a DWG file and import its elements as Draft objects. ...
  Test 'importDWG.import'
  This test requires a DWG file to read.
  file=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/test.dwg
  exists=False
  p1=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/test.dwg; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
test_export_dxf (TestDraft.DraftDXF)
Create some figures and export them to a DXF file. ...
  Temporary document 'DraftDXF'
  Test 'importDXF.export'
  file=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/out_test.dxf
  exists=False
  p1=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/out_test.dxf; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
test_read_dxf (TestDraft.DraftDXF)
Read a DXF file and import its elements as Draft objects. ...
  Test 'importDXF.import'
  This test requires a DXF file to read.
  file=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/test.dxf
  exists=False
  p1=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/test.dxf; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
test_import_gui_draft_snap (TestDraft.DraftGuiImport)
ok
test_import_gui_draft_tools (TestDraft.DraftGuiImport)
ok
test_import_gui_draft_trackers (TestDraft.DraftGuiImport)
ok
test_import_gui_draftgui (TestDraft.DraftGuiImport)
ok
test_import_draft (TestDraft.DraftImport)
ok
test_import_draft_geomutils (TestDraft.DraftImport)
ok
test_import_draft_svg (TestDraft.DraftImport)
ok
test_import_draft_vecutils (TestDraft.DraftImport)
ok
test_import_gui_draftedit (TestDraft.DraftImportTools)
ok
test_import_gui_draftfillet (TestDraft.DraftImportTools)
ok
test_import_gui_draftlayer (TestDraft.DraftImportTools)
ok
test_import_gui_draftplane (TestDraft.DraftImportTools)
ok
test_import_gui_workingplane (TestDraft.DraftImportTools)
ok
test_circular_array (TestDraft.DraftModification)
Create a rectangle, and a circular array. ...
  Temporary document 'DraftModification'
  Test 'Draft CircularArray'
  Rectangle
  length=4, width=2
  Array
  radial_distance=10, tangential_distance=8
  axis=Vector (0.0, 0.0, 1.0)
  center=Vector (0.0, 0.0, 0.0)
  number=3, symmetry=1
ok
test_clone (TestDraft.DraftModification)
Create a box, then create a clone of it. ...
  Test 'Draft Clone'
  object: 'Solid' (Part::Box)
  clone: 'Clone' (Part::FeaturePython)
ok
test_copy (TestDraft.DraftModification)
  Test 'Draft Move with copy'
  Line
  a=Vector (0.0, 3.0, 0.0), b=Vector (2.0, 3.0, 0.0)
  Translation vector (copy)
ok
Downgrade a closed Draft Wire into three simple Part Edges. ...
  Test 'Draft Downgrade'
  Closed wire
  c=Vector (2.0, 4.0, 0.0), a=Vector (0.0, 0.0, 0.0)
Found 1 parametric object: breaking its dependencies
  1: Result 'Face' (Part::Feature)
Found 1 face: extracting its wires
  2: Result 'Wire' (Part::Feature)
Found only wires: extracting their edges
  3: Result 3 x 'Edge' (Part::Feature)
No more downgrade possible
  4: Result '[]'
  The last objects cannot be downgraded further
ok
Create a solid, and then a projected view in a Drawing page. ...
  Test 'Draft Drawing'
  The Drawing Workbench is obsolete since 0.17,
  consider using the TechDraw Workbench instead
  Prism
  n_sides=5
  placement=Placement [Pos=(0,0,0), Yaw-Pitch-Roll=(0,45,0)]
  Drawing view
  page=Drawing::FeaturePage
  template=/opt/freecad-build-vocx/share/Mod/Drawing/Templates/A3_Landscape.svg
ok
Convert a Draft object to a Sketch and back. ...
  Test 'Draft Draft2Sketch'
  Wire
  1: Result 'Wire' (Sketcher::SketchObject)
  2: Result 'Wire' (Part::Part2DObjectPython)
ok
  Test 'Draft Trimex extend'
  Line
  a=Vector (0.0, 0.0, 0.0), b=Vector (1.0, 1.0, 0.0)
  Line 2
  c=Vector (2.0, 2.0, 0.0), d=Vector (4.0, 2.0, 0.0)
  p1=<Part::Part2DObject>; p2=<Part::Part2DObject>
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
Join two lines into a single Draft Wire. ...
  Test 'Draft Join'
  Line 1
  Line 2
  b=Vector (2.0, 2.0, 0.0), c=Vector (2.0, 4.0, 0.0)
ok
Create a rectangle, then a mirrored shape. ...
  Test 'Draft Mirror'
  Rectangle
  length=4, width=2
  Mirror axis
  p1=Vector (6.0, -2.0, 0.0)
  p2=Vector (6.0, 2.0, 0.0)
ok
test_move (TestDraft.DraftModification)
  Test 'Draft Move'
  Line
  a=Vector (0.0, 2.0, 0.0), b=Vector (2.0, 2.0, 0.0)
  Translation vector
  c=Vector (3.0, 1.0, 0.0)
ok
test_offset (TestDraft.DraftModification)
  Test 'Draft Offset'
  Rectangle
  length=4, width=2
  Offset
  vector=Vector (-1.0, -1.0, 0.0)
ok
Create a wire, a polygon, and a path array. ...
  Test 'Draft PathArray'
  Wire
  c=Vector (2.0, 4.0, 0.0), d=Vector (8.0, 4.0, 0.0)
  Polygon
  n_faces=3, radius=1
  Path Array
  number=4, translation=Vector (0.0, 1.0, 0.0)
  align=False
ok
Create a polygon, various point, and a point array. ...
  Test 'Draft PointArray'
  Points
  Upgrade
Found several non-treatable objects: creating compound
  Polygon
  n_faces=3, radius=1
  Point Array
ok
Create a rectangle, and a polar array. ...
  Test 'Draft PolarArray'
  Rectangle
  length=4, width=2
  Array
  center=Vector (-4.0, 0.0, 0.0)
  polar_angle=180, number=5
ok
Create a rectangle, and a rectangular array. ...
  Test 'Draft Array'
  Rectangle
  length=4, width=2
  Array
  direction_x=Vector (5.0, 0.0, 0.0)
  direction_y=Vector (0.0, 4.0, 0.0)
  number_x=3, number_y=4
ok
test_rotate (TestDraft.DraftModification)
  Test 'Draft Rotate'
  Line
  a=Vector (1.0, 1.0, 0.0), b=Vector (3.0, 1.0, 0.0)
  Rotation
  angle=90 degrees
ok
test_shape_2d_view (TestDraft.DraftModification)
Create a prism and then a 2D projection of it. ...
  Test 'Draft Shape2DView'
  Prism
  n_sides=5
  Projection 2D view
  direction=Vector (0.0, 0.0, 1.0)
ok
Split a Draft Wire into two Draft Wires. ...
  Test 'Draft_Split'
  Wire
  c=Vector (2.0, 4.0, 0.0), d=Vector (6.0, 4.0, 0.0)
  Split at
  p=Vector (2.0, 2.0, 0.0), index=1
ok
  Test 'Draft Stretch'
  This test requires an object and a selection
  Line
  p1=<Part::Part2DObject>; p2=Vector (4.0, 1.0, 0.0)
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  Test 'Draft Trimex trim'
  Line
  a=Vector (0.0, 0.0, 0.0), b=Vector (3.0, 3.0, 0.0)
  Line 2
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
Upgrade two Draft Lines into a closed Draft Wire. ...
  Test 'Draft Upgrade'
  Line 1
  Line 2
Found several edges: wiring them
  1: Result 'Wire' (Part::Feature)
Found 1 open wire: closing it
Found closed wires: creating faces
  3: Result 'Face' (Part::Feature)
Found 1 non-parametric objects: draftifying it
  4: Result 'Wire' (Part::Part2DObjectPython)
  The last object cannot be upgraded further
ok
test_wire_to_bspline (TestDraft.DraftModification)
Convert a polyline to BSpline and back. ...
  Test 'Draft WireToBSpline'
  Wire
  1: Result 'BSpline' (Part::Part2DObjectPython)
ok
test_export_oca (TestDraft.DraftOCA)
Create some figures and export them to an OCA file. ...
  Temporary document 'DraftOCA'
  Test 'importOCA.export'
  file=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/out_test.oca
  exists=False
  p1=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/out_test.oca; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
test_read_oca (TestDraft.DraftOCA)
Read an OCA file and import its elements as Draft objects. ...
  Test 'importOCA.import'
  This test requires an OCA file to read.
  file=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/test.oca
  exists=False
  p1=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/test.oca; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
test_pivy_draw (TestDraft.DraftPivy)
  Draw cube
ok
test_pivy_import (TestDraft.DraftPivy)
ok
test_export_svg (TestDraft.DraftSVG)
Create some figures and export them to an SVG file. ...
  Temporary document 'DraftSVG'
  Test 'importSVG.export'
  file=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/out_test.svg
  exists=False
  p1=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/out_test.svg; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
test_read_svg (TestDraft.DraftSVG)
Read an SVG file and import its elements as Draft objects. ...
  Test 'importSVG.import'
  This test requires an SVG file to read.
  file=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/test.svg
  exists=False
  p1=/opt/freecad-build-vocx/share/Mod/Draft/drafttest/test.svg; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
Ran 66 tests in 4.884s
OK
System exit
Post by Kunda1 »
Ok, not sure what happened. But it is sorted out now.
And you code runs without any complaints.
  file=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/out_test.dat
  exists=False
  p1=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/out_test.dat; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  file=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/test.dat
  exists=False
  p1=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/test.dat; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  Test 'Draft Arc'
  radius=2
ok
  p5=None
  Automatic PASS
ok
ok
ok
  Test 'Draft Circle'
  radius=3
ok
ok
  Occasionaly crashes
ok
  p5=None
  Automatic PASS
ok
ok
  Box
ok
  Test 'Draft Fillet'
  Lines
  Fillet
  radius=4
ok
Create a label. ...
  Test 'Draft Label'
  Occasionaly crashes
ok
Create a line. ...
  Test 'Draft Line'
ok
Create a point. ...
  Test 'Draft Point'
ok
  n_faces=6, radius=5
ok
  Test 'Draft Wire'
ok
  length=5, width=2
ok
  p1=Text; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  Test 'Draft Text'
ok
  file=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/out_test.dwg
  exists=False
  p1=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/out_test.dwg; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  file=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/test.dwg
  exists=False
  p1=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/test.dwg; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  file=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/out_test.dxf
  exists=False
  p1=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/out_test.dxf; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  file=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/test.dxf
  exists=False
  p1=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/test.dxf; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
  Rectangle
  length=4, width=2
  Array
ok
  Test 'Draft Clone'
ok
  Line
ok
  Closed wire
  4: Result '[]'
ok
  Prism
  n_sides=5
  Drawing view
  template=/home/foo/bin/squashfs-root/usr/share/Mod/Drawing/Templates/A3_Landscape.svg
ok
  Wire
ok
  Line
  Line 2
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  Test 'Draft Join'
  Line 1
  Line 2
ok
  Test 'Draft Mirror'
  Rectangle
  length=4, width=2
  Mirror axis
ok
  Test 'Draft Move'
  Line
  Translation vector
ok
  Test 'Draft Offset'
  Rectangle
  length=4, width=2
  Offset
ok
  Wire
  Polygon
  n_faces=3, radius=1
  Path Array
  align=False
ok
  Points
  Upgrade
  Polygon
  n_faces=3, radius=1
  Point Array
ok
  Rectangle
  length=4, width=2
  Array
ok
  Test 'Draft Array'
  Rectangle
  length=4, width=2
  Array
ok
  Test 'Draft Rotate'
  Line
  Rotation
  angle=90 degrees
ok
  Prism
  n_sides=5
  Projection 2D view
ok
  Test 'Draft_Split'
  Wire
  Split at
ok
  Line
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  Line
  Line 2
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  Line 1
  Line 2
ok
  Wire
ok
  file=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/out_test.oca
  exists=False
  p1=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/out_test.oca; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  file=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/test.oca
  exists=False
  p1=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/test.oca; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  Draw cube
ok
ok
  file=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/out_test.svg
  exists=False
  p1=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/out_test.svg; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
  file=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/test.svg
  exists=False
  p1=/home/foo/bin/squashfs-root/usr/share/Mod/Draft/drafttest/test.svg; p2=None
  p3=None; p4=None
  p5=None
  Automatic PASS
ok
Ran 66 tests in 2.208s
OK
System exit
