draft layer separate line and shape color override
- petit_chat_noir
Hello,
Will it be possible to separate line color override and shape color override please?
Re: draft layer separate line and shape color override
Hmm you are right actually... Each of these settings should be on/off controllable individually...
Adding to my TODO list (but buried under work until december... might take some time. Feel free to try if you want it earlier )
- petit_chat_noir
I will, if I have time
- petit_chat_noir
Okay,
This is not quite clean but it work !
I can't post .diff file ....
# -*- coding: utf-8 -*-
#* Copyright (c) 2009, 2010 *
#* Yorik van Havre <yorik@uncreated.net>, Ken Cline <cline@frii.com> *
#* This program is free software; you can redistribute it and/or modify *
#* it under the terms of the GNU Lesser General Public License (LGPL) *
#* as published by the Free Software Foundation; either version 2 of *
#* the License, or (at your option) any later version. *
#* for detail see the LICENCE text file. *
#* This program is distributed in the hope that it will be useful, *
#* but WITHOUT ANY WARRANTY; without even the implied warranty of *
#* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
#* GNU Library General Public License for more details. *
#* You should have received a copy of the GNU Library General Public *
#* License along with this program; if not, write to the Free Software *
#* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 *
#* USA *
import FreeCAD
def translate(ctx,txt):
return txt
def QT_TRANSLATE_NOOP(ctx,txt):
return txt
"""This module contains everything related to Draft Layers"""
def makeLayer(name=None,linecolor=None,drawstyle=None,shapecolor=None,transparency=None):
"""makeLayer([name,linecolor,drawstyle,shapecolor,transparency]):
creates a Layer object in the active document
if not FreeCAD.ActiveDocument:
FreeCAD.Console.PrintError(translate("draft","No active document. Aborting")+"\n")
return
obj = FreeCAD.ActiveDocument.addObject("App::FeaturePython","Layer")
Layer(obj)
if name:
obj.Label = name
else:
obj.Label = translate("draft","Layer")
if FreeCAD.GuiUp:
ViewProviderLayer(obj.ViewObject)
if linecolor:
obj.ViewObject.LineColor = linecolor
if drawstyle:
obj.ViewObject.DrawStyle = drawstyle
if shapecolor:
obj.ViewObject.ShapeColor = shapecolor
if transparency:
obj.ViewObject.Transparency = transparency
getLayerContainer().addObject(obj)
return obj
def getLayerContainer():
"""getLayerContainer(): returns a group object to put layers in"""
for obj in FreeCAD.ActiveDocument.Objects:
if obj.Name == "LayerContainer":
return obj
obj = FreeCAD.ActiveDocument.addObject("App::DocumentObjectGroupPython","LayerContainer")
obj.Label = translate("draft","Layers")
LayerContainer(obj)
if FreeCAD.GuiUp:
ViewProviderLayerContainer(obj.ViewObject)
return obj
class CommandLayer():
"""The Draft_Layer FreeCAD command"""
def GetResources(self):
return {'Pixmap' : 'Draft_Layer',
'MenuText': QT_TRANSLATE_NOOP("Draft_Layer", "Layer"),
'ToolTip' : QT_TRANSLATE_NOOP("Draft_Layer", "Adds a layer")}
def Activated(self):
import FreeCADGui
FreeCAD.ActiveDocument.openTransaction("Create Layer")
FreeCADGui.addModule("Draft")
FreeCADGui.doCommand('Draft.makeLayer()')
FreeCADGui.doCommand('FreeCAD.ActiveDocument.recompute()')
FreeCAD.ActiveDocument.commitTransaction()
class Layer:
"""The Draft Layer object"""
def __init__(self,obj):
self.Type = "Layer"
obj.Proxy = self
self.Object = obj
self.setProperties(obj)
def onDocumentRestored(self,obj):
def setProperties(self,obj):
if not "Group" in obj.PropertiesList:
obj.addProperty("App::PropertyLinkList","Group","Layer",QT_TRANSLATE_NOOP("App::Property","The objects that are part of this layer"))
def __getstate__(self):
return self.Type
def __setstate__(self,state):
if state:
self.Type = state
def execute(self,obj):
pass
def addObject(self,obj,child):
g = obj.Group
if not child in g:
g.append(child)
obj.Group = g
class ViewProviderLayer:
"""A View Provider for the Layer object"""
def __init__(self,vobj):
vobj.addProperty("App::PropertyBool","OverrideLineColorChildren","Layer",QT_TRANSLATE_NOOP("App::Property","If on, the child objects of this layer will match its visual aspects"))
vobj.addProperty("App::PropertyBool","OverrideShapeColorChildren","Layer",QT_TRANSLATE_NOOP("App::Property","If on, the child objects of this layer will match its visual aspects"))
vobj.addProperty("App::PropertyColor","LineColor","Layer",QT_TRANSLATE_NOOP("App::Property","The line color of the children of this layer"))
vobj.addProperty("App::PropertyColor","ShapeColor","Layer",QT_TRANSLATE_NOOP("App::Property","The shape color of the children of this layer"))
vobj.addProperty("App::PropertyFloat","LineWidth","Layer",QT_TRANSLATE_NOOP("App::Property","The line width of the children of this layer"))
vobj.addProperty("App::PropertyEnumeration","DrawStyle","Layer",QT_TRANSLATE_NOOP("App::Property","The draw style of the children of this layer"))
vobj.addProperty("App::PropertyInteger","Transparency","Layer",QT_TRANSLATE_NOOP("App::Property","The transparency of the children of this layer"))
vobj.DrawStyle = ["Solid","Dashed","Dotted","Dashdot"]
vobj.OverrideLineColorChildren = True
vobj.OverrideShapeColorChildren = True
c = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/View").GetUnsigned("DefaultShapeLineColor",255)
vobj.LineColor = (((c>>24)&0xFF)/255,((c>>16)&0xFF)/255,((c>>8)&0xFF)/255)
w = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/View").GetInt("DefaultShapeLineWidth",2)
vobj.LineWidth = w
c = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/View").GetUnsigned("DefaultShapeColor",4294967295)
vobj.ShapeColor = (((c>>24)&0xFF)/255,((c>>16)&0xFF)/255,((c>>8)&0xFF)/255)
vobj.DrawStyle = "Solid"
vobj.Proxy = self
def getIcon(self):
if hasattr(self,"icondata"):
return self.icondata
import Draft_rc
return ":/icons/Draft_Layer.svg"
def attach(self,vobj):
self.Object = vobj.Object
from pivy import coin
sep = coin.SoGroup()
vobj.addDisplayMode(sep,"Default")
return
def claimChildren(self):
if hasattr(self,"Object") and hasattr(self.Object,"Group"):
return self.Object.Group
def getDisplayModes(self, vobj):
return ["Default"]
def getDefaultDisplayMode(self):
return "Default"
def setDisplayMode(self, mode):
return mode
return None
return None
def updateData(self,obj,prop):
if prop == "Group":
self.onChanged(obj.ViewObject,"LineColor")
def onChanged(self,vobj,prop):
if hasattr(vobj,"OverrideLineColorChildren") and vobj.OverrideLineColorChildren:
if hasattr(vobj,"Object")and hasattr(vobj.Object,"Group"):
for o in vobj.Object.Group:
if o.ViewObject:
for p in ["LineColor","ShapeColor","LineWidth","DrawStyle","Transparency"]:
if p == "ShapeColor":
if hasattr(vobj,"OverrideShapeColorChildren") and vobj.OverrideShapeColorChildren:
setattr(o.ViewObject,p,getattr(vobj,p))
else:
if hasattr(vobj,p) and hasattr(o.ViewObject,p):
# give line color to texts
if hasattr(vobj,"LineColor") and hasattr(o.ViewObject,"TextColor"):
o.ViewObject.TextColor = vobj.LineColor
if (prop == "Visibility") and hasattr(vobj,"Visibility"):
if o.ViewObject and hasattr(o.ViewObject,"Visibility"):
o.ViewObject.Visibility = vobj.Visibility
if (prop in ["LineColor","ShapeColor"]) and hasattr(vobj,"LineColor") and hasattr(vobj,"ShapeColor"):
from PySide import QtCore,QtGui
lc = vobj.LineColor
sc = vobj.ShapeColor
lc = QtGui.QColor(int(lc[0]*255),int(lc[1]*255),int(lc[2]*255))
sc = QtGui.QColor(int(sc[0]*255),int(sc[1]*255),int(sc[2]*255))
p1 = QtCore.QPointF(2,17)
p2 = QtCore.QPointF(13,8)
p3 = QtCore.QPointF(30,15)
p4 = QtCore.QPointF(20,25)
im = QtGui.QImage(32,32,QtGui.QImage.Format_ARGB32)
im.fill(QtCore.Qt.transparent)
pt = QtGui.QPainter(im)
pt.setBrush(QtGui.QBrush(sc, QtCore.Qt.SolidPattern))
pt.drawPolygon([p1,p2,p3,p4])
pt.setPen(QtGui.QPen(lc, 2, QtCore.Qt.SolidLine, QtCore.Qt.FlatCap))
pt.end()
ba = QtCore.QByteArray()
b = QtCore.QBuffer(ba)
b.open(QtCore.QIODevice.WriteOnly)
im.save(b,"XPM")
self.icondata = ba.data().decode("latin1")
def canDragObject(self,obj):
return True
def canDragObjects(self):
return True
def dragObject(self,vobj,otherobj):
if hasattr(vobj.Object,"Group"):
if otherobj in vobj.Object.Group:
g = vobj.Object.Group
g.remove(otherobj)
vobj.Object.Group = g
def canDropObject(self,obj):
if hasattr(obj,"Proxy") and isinstance(obj.Proxy,Layer): # for now, prevent stacking layers
return False
return True
def canDropObjects(self):
return True
def dropObject(self,vobj,otherobj):
if not otherobj in vobj.Object.Group:
if not(hasattr(otherobj,"Proxy") and isinstance(otherobj.Proxy,Layer)): # for now, prevent stacking layers
g.append(otherobj)
# remove from all other layers (not automatic)
for parent in otherobj.InList:
if hasattr(parent,"Proxy") and isinstance(parent.Proxy,Layer):
if otherobj in parent.Group:
if parent != vobj.Object:
g = parent.Group
g.remove(otherobj)
parent.Group = g
def setupContextMenu(self,vobj,menu):
import Draft_rc
action1 = QtGui.QAction(QtGui.QIcon(":/icons/button_right.svg"),translate("draft","Activate this layer"),menu)
action1.triggered.connect(self.activate)
menu.addAction(action1)
action2 = QtGui.QAction(QtGui.QIcon(":/icons/Draft_SelectGroup.svg"),translate("draft","Select contents"),menu)
action2.triggered.connect(self.selectcontents)
menu.addAction(action2)
def activate(self):
if hasattr(self,"Object"):
FreeCADGui.Selection.clearSelection()
FreeCADGui.Selection.addSelection(self.Object)
FreeCADGui.runCommand("Draft_AutoGroup")
def selectcontents(self):
for o in self.Object.Group:
FreeCADGui.Selection.addSelection(o)
class LayerContainer:
"""The Layer Container"""
self.Type = "LayerContainer"
obj.Proxy = self
g = obj.Group
g.sort(key=lambda o: o.Label)
obj.Group = g
if hasattr(self,"Type"):
return self.Type
if state:
self.Type = state
class ViewProviderLayerContainer:
"""A View Provider for the Layer Container"""
vobj.Proxy = self
def getIcon(self):
import Draft_rc
import Draft_rc
action1 = QtGui.QAction(QtGui.QIcon(":/icons/Draft_Layer.svg"),"Merge duplicates",menu)
action1.triggered.connect(self.mergeByName)
def mergeByName(self):
layers = [o for o in self.Object.Group if (hasattr(o,"Proxy") and isinstance(o.Proxy,Layer))]
todelete = []
for layer in layers:
if layer.Label[-1].isdigit() and layer.Label[-2].isdigit() and layer.Label[-3].isdigit():
orig = None
for ol in layer:
if ol.Label == layer.Label[:-3].strip():
orig = ol
break
if orig:
for par in layer.InList:
for prop in par.PropertiesList:
if getattr(par,prop) == layer:
FreeCAD.Console.PrintMessage("Changed property '"+prop+"' of object "+par.Label+" from "+layer.Label+" to "+orig.Label+"\n")
setattr(par,prop,orig)
todelete.append(layer)
for tod in todelete:
if not tod.InList:
FreeCAD.Console.PrintMessage("Merging duplicate layer "+tod.Label+"\n")
FreeCAD.ActiveDocument.removeObject(tod.Name)
elif (len(tod.InList) == 1) and (tod.InList[0].isDerivedFrom("App::DocumentObjectGroup")):
else:
FreeCAD.Console.PrintMessage("Unable to delete layer "+tod.Label+": InList not empty\n")
return None
return None
if FreeCAD.GuiUp:
import FreeCADGui
FreeCADGui.addCommand('Draft_Layer',CommandLayer())
- DraftLayer.py
- (15.12 KiB) Downloaded 31 times
Great! I warn you, it's addictive
FYI, Usually is easier for Yorik to review if a PR is opened with the proposed changes
- petit_chat_noir
I've made a PR.
@carlopav : I think I'm already addict !
Ahah. If u are aware about that, then it's ok!
Good! PR: https://github.com/FreeCAD/FreeCAD/pull/2726
Pull request #2726petit_chat_noir wrote: ↑Tue Nov 19, 2019 10:01 pm I've made a PR.
I strongly suggest you split your single pull request into two pull requests, because you are introducing two separate things. One is the new Arch_CutLine in the Arch Workbench, and the other is a change to the Draft Layer behavior in the Draft Workbench.
Ideally, you should create two separate branches, for example, Jerome:draftlayer and Jerome:cutline, and then create pull requests for each.
Also, don't forget to write a good description. Just a single sentence "Separate line and shape colors override" isn't very helpful; it also only mentions one thing, not the other. Also, provide a link in the description to the forum threads where the changes, or upgrades, or new tools are described and discussed. Also, the new icon for Arch_CutLine looks a bit "crowded"; in my opinion, you should make it simpler. See Artwork Guidelines, and see Artwork for all icons, from which you can take inspiration.
And finally, don't forget to update the documentation. As your intention is to add new functionality to Draft Layer, you should edit the wiki page with information on these new properties. Similarly, you should create a new page for Arch_CutLine.
- petit_chat_noir
Arf, all I wanted to avoid. Sorry it's a manipulation errorvocx wrote: ↑Tue Nov 19, 2019 11:35 pm I strongly suggest you split your single pull request into two pull requests, because you are introducing two separate things. One is the new Arch_CutLine in the Arch Workbench, and the other is a change to the Draft Layer behavior in the Draft Workbench.
ahah, I'm not an artist , you can make the icon if you want
Cut Line is not integrated in master at all, so documentation is not necessary for the moment.
You are submitting a pull request right now. So, the documentation has to be prepared at the same time.petit_chat_noir wrote: ↑Wed Nov 20, 2019 8:00 am ...
The pull request message indicates this as well.
And please remember to update the Wiki with the features added or changed once this PR is merged.
**Note**: If you don't have wiki access, then please mention your contribution on the 0.19 Changelog Forum Thread.
