House and Woodwork
ckl6767
House and Woodwork
Postby ckl6767 » Sat Dec 14, 2019 11:03 pm
Hello All
The project may seem a bit ambitious for a beginner.. :o
The objective here is to model my whole house with the WB-Arch. (WB-BIM)
The purpose would also to draw the Woodwork (a little complex here) so for example to cut the Woodwork on the ground. :shock:
... I am going to take myself as a Carpenter ;)
The principle used to design the house, is based on "Wall sketches".
The "Wall sketches" being built on the "Basic sketch" thanks to Pillars (Purple) :: (Pillar Mapped "NormalToEdge" to "Base sketch edges")
And, "Wall sketches" mapped 0XY, on "Basic sketch" + "Pillars"
Capture (1).PNG (82.93 KiB) Viewed 660 times
All objects, than also mapped 0XY to "Wall sketches"
i.e : Windows sketches
The advantage of this approach, is to set the Windows on the exact position. (A topic that I had already highlighted here in the forum)
The project is progressing slowly, because complex.... :geek:
Also I'm trying to be as close as possible to a house construction approach.
And the result is not bad for now :P
At that point I'm facing 1 issue.
1) I have to create a hole in the "Slab First Foor", (see green below) for the stairs.
Can you advice how to fix ?
To create the Slab, I used: "Arch Structure tool"
2) The second question is more general.
Please if you should emphasis a "drawing approach error", please let me know.
Many Thanks
Christian
home.FCStd
(316.73 KiB) Downloaded 9 times
paullee
Re: House and Woodwork
Postby paullee » Sun Dec 15, 2019 1:04 am
Looks great ! :)
1. Slab Opening
- Simply add in the slab sketch the opening profile, say a rectangle
- In the Slab First Slab, find Face Maker in Data tab, and choose Cheese or Bulleye (I am not sure the exact difference), recompute and you have the opening
- see home_2019-12-15.fcstd
2. Drawing approach error ?
- Not sure your meaning
- Generally, mapping the windows to 'Edge Sketch' + ' Edge Pillars' seems too complicated and maybe error prone, though works
> you should be aware editing the base sketch, ground floor Wall001's Sketch, especially deleting an edge (or just turn 1 into construction mode), break the model
> see home_2019-12-15_ Turn Edge To Construction.fcstd
Screenshot from 2019-12-15 08-52-45.png (302.46 KiB) Viewed 643 times
Screenshot from 2019-12-15 08-53-38.png (237.48 KiB) Viewed 643 times
Screenshot from 2019-12-15 08-59-42.png (247.48 KiB) Viewed 643 times
Screenshot from 2019-12-15 09-00-18.png (245.83 KiB) Viewed 643 times
paullee
Postby paullee » Sun Dec 15, 2019 1:07 am
Model files attached
home_2019-12-15_ Turn Edge To Construction.FCStd
(319.81 KiB) Downloaded 9 times
home_2019-12-15.FCStd
(319.87 KiB) Downloaded 8 times
ckl6767
House and Woodwork
Postby ckl6767 » Sun Dec 15, 2019 2:56 pm
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18831 (Git)
Hash: f533e3bf876dc276928099e40e0eb9b177c10d44
Python version: 3.7.3
Qt version: 5.12.5
Locale: French/France (fr_FR)
Thanks Paullee for the Slab opening trick, it is working perfectly. :D
Yes, I have seen. :shock:
However the great advantage of this approach here, is to be able to modify the positions and lengths of the dimension entered in the sketches
(perhaps I have missed something, but I don't see another approach with so much flexibility)
On the other hand, my model is completely unstable, even respecting the rule :
"No sketch has to be mapped on a WALL"
For example:
I wanted to map the front window door through
  • Ground Floor Wall
  • Slab
  • First floor base wall
I didn't success, because the result was not as expected..
So by inadvertence I removed the attachment from the front window (Host Parameter) to the main Wall
AND the main slab goes up.
Is this linked to
  • The approach I used ?
  • The version of Freecad (0.19.18831) which is Bugged ?
  • Maybe WB_Arch is still not finalized ?
home.FCStd
(317.41 KiB) Downloaded 9 times
paullee
Postby paullee » Sun Dec 15, 2019 9:36 pm
I see the advantage of using Sketch so trying to improve this workflow - see my other post just updated.
The problem is you map the G/F Slab Sketch base to Face of Wall - when you remove a window from it, the TopoName of Wall rearrange and you have the G/F Sketch mapped to unexpected location.
I would assign one of the sketch as Master e.g. your G/F WALL Sketch. Now, you can Map you G/F SLAB Sketch to G/F WALL Sketch (by Object XY)
Ok, REMOVED your window, G/F slab does not move.
(However, your 1/F slab become error, fix it with similar approach)
Screenshot from 2019-12-16 05-27-13.png (186.96 KiB) Viewed 516 times
Screenshot from 2019-12-16 05-28-35.png (174.56 KiB) Viewed 516 times
Screenshot from 2019-12-16 05-29-48.png (211.13 KiB) Viewed 516 times
home_cl6767_ 2019-12-16_ r.FCStd
(338.54 KiB) Downloaded 7 times
ckl6767
Postby ckl6767 » Mon Dec 16, 2019 10:58 am
Understood.
Meaning that, as long as the issue with "TopoName of Wall rearrange" is not fixed :
It is forbidden to "reference" any "Sketches" to a Wall !!
* Face of Wall
* Line of Wall
Or have we to go a step further and extend this rule to any "WB-Arch" and "WB-Bim" 3D object" ??
Conclusion
Sketches have not to be referenced to any "WB-Arch" and "WB-Bim" 3D object
Do yo confirm this rule ?
For sure this restriction doesn't exist for the workbenches : Part, Part Design, Draft,..
paullee
Postby paullee » Mon Dec 16, 2019 12:40 pm
Whilst it is 'not forbidden' , recommed not to do so as you see how fragile the model would become :)
And I am afraid, all Part related objects suffered from the 'topological naming problem'
ckl6767
Postby ckl6767 » Mon Dec 16, 2019 1:16 pm
OK, will be taken into account.
Hopping that this issue will be fixed in the future.. ;)
Now just a really strange behavior on my side.
By cleaning my model, in order to over pass the 'topological naming problem'
I faced a : "cyclic dependency detected" issue
Step by step I removed the items, but couldn't fix the issue.
At the end, I have only the "base sketch", Without any constraints, and still have : "cyclic dependency" .. issue
I'm really stuck here..
Could anybody help to understand why I'm having this issue, and how to fix it.
Many thanks in advance
cyclic dependency issue.FCStd
(4.02 KiB) Downloaded 6 times
Postby chrisb » Mon Dec 16, 2019 3:50 pm
The sketch is probably somehow mapped to itself. Remap it to the correct plane. How to do that, see https://forum.freecadweb.org/viewtopic. ... 15#p354215.
bernd
Postby bernd » Mon Dec 16, 2019 3:55 pm
What is the recommended way? What I do is use sketches anyway and make wires from the sketch and use this wires to make the Arch objects. With this I am able to use one sketch but different wall thicknesses for different walls.
