Draft Wiki pages (Status)
Postby Kunda1 » Thu Jan 16, 2020 7:24 pm
Draft AddConstruction - https://www.freecadweb.org/wiki/Draft_AddConstruction (missing screenshot, missing sections)
Draft AddPoint - https://www.freecadweb.org/wiki/Draft_AddPoint (missing screenshot, missing sections)
Draft AddToGroup - https://www.freecadweb.org/wiki/Draft_AddToGroup
Draft Angle - https://www.freecadweb.org/wiki/Draft_Angle
Draft API - https://www.freecadweb.org/wiki/Draft_API
Draft Apply - https://www.freecadweb.org/wiki/Draft_Apply
Draft Arc - https://www.freecadweb.org/wiki/Draft_Arc
Draft Arc 3Points - https://www.freecadweb.org/wiki/Draft_Arc_3Points
Draft Array - https://www.freecadweb.org/wiki/Draft_Array
Draft AutoGroup - https://www.freecadweb.org/wiki/Draft_AutoGroup
Draft BezCurve - https://www.freecadweb.org/wiki/Draft_BezCurve
Draft BSpline - https://www.freecadweb.org/wiki/Draft_BSpline
Draft Center - https://www.freecadweb.org/wiki/Draft_Center
Draft Circle - https://www.freecadweb.org/wiki/Draft_Circle
Draft Clone - https://www.freecadweb.org/wiki/Draft_Clone
Draft CloseLine - https://www.freecadweb.org/wiki/Draft_CloseLine
Draft Constrain - https://www.freecadweb.org/wiki/Draft_Constrain
Draft Coordinates - https://www.freecadweb.org/wiki/Draft_Coordinates
Draft CubicBezCurve - https://www.freecadweb.org/wiki/Draft_CubicBezCurve
Draft DAT - https://www.freecadweb.org/wiki/Draft_DAT
Draft DelPoint - https://www.freecadweb.org/wiki/Draft_DelPoint
Draft Dimension - https://www.freecadweb.org/wiki/Draft_Dimension
Draft Dimensions - https://www.freecadweb.org/wiki/Draft_Dimensions
Draft Downgrade - https://www.freecadweb.org/wiki/Draft_Downgrade
Draft Draft2Sketch - https://www.freecadweb.org/wiki/Draft_Draft2Sketch
Draft Drawing - https://www.freecadweb.org/wiki/Draft_Drawing
Draft DXF - https://www.freecadweb.org/wiki/Draft_DXF
Draft Edit - https://www.freecadweb.org/wiki/Draft_Edit
Draft Ellipse - https://www.freecadweb.org/wiki/Draft_Ellipse
Draft Endpoint - https://www.freecadweb.org/wiki/Draft_Endpoint
Draft Extension - https://www.freecadweb.org/wiki/Draft_Extension
Draft Facebinder - https://www.freecadweb.org/wiki/Draft_Facebinder
Draft Fillet - https://www.freecadweb.org/wiki/Draft_Fillet
Draft FinishLine - https://www.freecadweb.org/wiki/Draft_FinishLine
Draft FlipDimension - https://www.freecadweb.org/wiki/Draft_FlipDimension
Draft Grid - https://www.freecadweb.org/wiki/Draft_Grid
Draft Heal - https://www.freecadweb.org/wiki/Draft_Heal
Draft Intersection - https://www.freecadweb.org/wiki/Draft_Intersection
Draft Join - https://www.freecadweb.org/wiki/Draft_Join
Draft Label - https://www.freecadweb.org/wiki/Draft_Label
Draft Layer - https://www.freecadweb.org/wiki/Draft_Layer
Draft Line - https://www.freecadweb.org/wiki/Draft_Line
Draft Linestyle - https://www.freecadweb.org/wiki/Draft_Linestyle
Draft LinkArray - https://www.freecadweb.org/wiki/Draft_LinkArray
Draft Midpoint - https://www.freecadweb.org/wiki/Draft_Midpoint
Draft Mirror - https://www.freecadweb.org/wiki/Draft_Mirror
Draft Module - https://www.freecadweb.org/wiki/Draft_Module
Draft Move - https://www.freecadweb.org/wiki/Draft_Move
Draft Near - https://www.freecadweb.org/wiki/Draft_Near
Draft OCA - https://www.freecadweb.org/wiki/Draft_OCA
Draft Offset - https://www.freecadweb.org/wiki/Draft_Offset
Draft Ortho - https://www.freecadweb.org/wiki/Draft_Ortho
Draft Parallel - https://www.freecadweb.org/wiki/Draft_Parallel
Draft PathArray - https://www.freecadweb.org/wiki/Draft_PathArray
Draft PathLinkArray - https://www.freecadweb.org/wiki/Draft_PathLinkArray
Draft Perpendicular - https://www.freecadweb.org/wiki/Draft_Perpendicular
Draft Point - https://www.freecadweb.org/wiki/Draft_Point
Draft PointArray - https://www.freecadweb.org/wiki/Draft_PointArray
Draft PolarArray - https://www.freecadweb.org/wiki/Draft_PolarArray
Draft Polygon - https://www.freecadweb.org/wiki/Draft_Polygon
Draft Polyline - https://www.freecadweb.org/wiki/Draft_Polyline
Draft Preferences - https://www.freecadweb.org/wiki/Draft_Preferences
Draft Rectangle - https://www.freecadweb.org/wiki/Draft_Rectangle
Draft Rotate - https://www.freecadweb.org/wiki/Draft_Rotate
Draft Scale - https://www.freecadweb.org/wiki/Draft_Scale
Draft SelectGroup - https://www.freecadweb.org/wiki/Draft_SelectGroup
Draft SelectPlane - https://www.freecadweb.org/wiki/Draft_SelectPlane
Draft SetWorkingPlaneProxy - https://www.freecadweb.org/wiki/Draft_S ... PlaneProxy
Draft Shape2DView - https://www.freecadweb.org/wiki/Draft_Shape2DView
Draft ShapeString - https://www.freecadweb.org/wiki/Draft_ShapeString
Draft ShowSnapBar - https://www.freecadweb.org/wiki/Draft_ShowSnapBar
Draft Slope - https://www.freecadweb.org/wiki/Draft_Slope
Draft Snap - https://www.freecadweb.org/wiki/Draft_Snap
Draft Special - https://www.freecadweb.org/wiki/Draft_Special
Draft Split - https://www.freecadweb.org/wiki/Draft_Split
Draft Stretch - https://www.freecadweb.org/wiki/Draft_Stretch
Draft SubelementHighlight - https://www.freecadweb.org/wiki/Draft_S ... tHighlight
Draft SVG - https://www.freecadweb.org/wiki/Draft_SVG
Draft Text - https://www.freecadweb.org/wiki/Draft_Text
Draft ToggleConstructionMode - https://www.freecadweb.org/wiki/Draft_T ... uctionMode
Draft ToggleContinueMode - https://www.freecadweb.org/wiki/Draft_T ... ntinueMode
Draft ToggleDisplayMode - https://www.freecadweb.org/wiki/Draft_ToggleDisplayMode
Draft ToggleGrid - https://www.freecadweb.org/wiki/Draft_ToggleGrid
Draft ToggleSnap - https://www.freecadweb.org/wiki/Draft_ToggleSnap
Draft Tray - https://www.freecadweb.org/wiki/Draft_Tray
Draft Trimex - https://www.freecadweb.org/wiki/Draft_Trimex
Draft tutorial - https://www.freecadweb.org/wiki/Draft_tutorial
Draft UndoLine - https://www.freecadweb.org/wiki/Draft_UndoLine
Draft Upgrade - https://www.freecadweb.org/wiki/Draft_Upgrade
Draft VisGroup - https://www.freecadweb.org/wiki/Draft_VisGroup
Draft Wire - https://www.freecadweb.org/wiki/Draft_Wire
Draft WireToBSpline - https://www.freecadweb.org/wiki/Draft_WireToBSpline
Draft WorkingPlane - https://www.freecadweb.org/wiki/Draft_WorkingPlane
DXF - https://www.freecadweb.org/wiki/DXF
Related Threads
Arch Wiki Pages - https://forum.freecadweb.org/viewtopic.php?f=23&t=42500
Draft Wiki Pages - https://forum.freecadweb.org/viewtopic.php?f=23&t=42501
FEM Wiki Pages - https://forum.freecadweb.org/viewtopic.php?f=18&t=20823
Path Wiki Pages - https://forum.freecadweb.org/viewtopic.php?f=15&t=42498
Sketcher Wiki Pages - https://forum.freecadweb.org/viewtopic. ... 2&p=360968
carlopav
Re: Draft Wiki pages (Status)
Postby carlopav » Wed Jan 22, 2020 10:46 am
Hello! I need some hints on how to modify draft Edit page. I logged in in the wiki, but I can't find how to modify the page... I feel a bit stupid :roll: :roll:
vocx
Postby vocx » Wed Jan 22, 2020 4:42 pm
Upper right, there is an "Edit" button, between "Read" and "View history". The basic interface is pretty similar to Wikipedia.
Also, each section has an "Edit" link to open the editor.
Also read the huge WikiPages information. (This needs to be split into more manageable pages, by the way.)
carlopav
Postby carlopav » Wed Jan 22, 2020 6:16 pm
ping
Clicking on view source of Draft Edit page, it advise that i dont have the permission to edit the page because
The action you have requested is limited to users in one of the groups: admin, editor.
Roy_043
Postby Roy_043 » Wed Jan 22, 2020 6:59 pm
Postby Kunda1 » Thu Jan 23, 2020 1:26 pm
You can now edit the wiki. Sorry it took so long. We don't have the most practical wiki backend, it's something we should improve. Add it to the list, :lol:
carlopav
Postby carlopav » Thu Jan 23, 2020 7:58 pm
Thanks!
david69
Postby david69 » Mon Feb 17, 2020 12:44 pm
recently, the version 0.19 has introduced a split in the tool menu for draft workbench.
in all wiki pages of Draft, the description of the menu location is given for the legacy workbench.
how do you plan to manage the two different menu location in the wiki?
vocx
Postby vocx » Mon Feb 17, 2020 5:17 pm
We will change the wiki. It's not a big problem.
