[ Fixed ] [ Bug ] Draft problem with coordinate input
carlopav
Re: [ Bug ] Draft problem with coordinate input
Postby carlopav » Fri Feb 14, 2020 5:21 pm
fc_tofu wrote:
Fri Feb 14, 2020 4:28 pm
Other issues I thought as limitation of FC coordinate, pls give some consideration.
1. DraftWB, if you enter a unitless number, FC treat it as "mm", not prefered-unit-system, ie, MKS (Preferences>General>Unit>Unit system).
2. Most workbenches (PartWB/PartDesignWB/Sketcher/TechDraw), donnot take prefered-unit-system as a matter. They alway use "mm", or adatpive unit in some cases.
3. FC saves prefered-unit-system in Preferences ("user.cfg"), which is not as convinient as file properties (.FCStd), IMHO.
thanks fc_tofu, I agree with what you point out, but that's beyond my possibilities ATM. Consider that with this PR it will be more difficult to delete the units in the inputfields since just the numerical part will be selected by default.
fc_tofu
Postby fc_tofu » Sat Feb 15, 2020 1:59 pm
ok, thank you.
Whith your fix applied on my machine, normal input unit can avoid focus as this fix's intention. But, with x/y/z constraint, unit focus issue still exist.
version: FreeCAD_0.19.19510_x64_LP_12.1.2_PY3QT5-WinVS2015
os: win10x64
carlopav
Postby carlopav » Thu Mar 12, 2020 1:36 pm
Roy_043 wrote:
Thu Feb 06, 2020 8:36 am
ping
PR has been merged now by Yorik, can you please check next build and report if it's ok for you?
vocx
Postby vocx » Thu Mar 12, 2020 5:48 pm
I also wanted to mention this.
Please check that your code was merged correctly. Some of my pull requests were merged as well, but there are others pending.
I have to rebase a few of my requests because now they conflict with DraftTools, DraftEdit, and DraftGui. I have to check this so that I don't accidentally override your changes.
carlopav
Postby carlopav » Thu Mar 12, 2020 6:27 pm
Seems so. ATM the upstream code seems ok with my changes on DraftGui, init_tools and DraftEdit.
Roy_043
Postby Roy_043 » Fri Mar 13, 2020 9:01 am
ping
Thanks for your work.
What release number should I be looking for?
FreeCAD_0.19.?????_x64_LP_12.1.2_PY3QT5-WinVS2015.7z
carlopav
Postby carlopav » Fri Mar 13, 2020 9:23 am
:oops: I dont know...
vocx
Postby vocx » Fri Mar 13, 2020 4:12 pm
Carlo's latest commit was git commit 8fd55eb6. See https://github.com/FreeCAD/FreeCAD/commits/8fd55eb6.
git rev-list --count 8fd55eb6
20013
So you could test any release after 0.19.20013.
carlopav
Postby carlopav » Fri Mar 13, 2020 4:21 pm
thx, don't know how to get it from gitKraken...
Postby Kunda1 » Fri Mar 13, 2020 4:53 pm
You can't in gitkraken, but you can Invoke a terminal via the gitkraken alt+t shortcut. It will open a terminal who's current working directory will be the directory that you've cloned the repo into. Then just copy/paste the above code vocx provided.
Edit: spelling
