[ Fixed ] [ Bug ] Draft problem with coordinate input
carlopav
Re: [ Bug ] Draft problem with coordinate input
Postby carlopav » Fri Mar 13, 2020 5:37 pm
Kunda1 wrote:
Fri Mar 13, 2020 4:53 pm
You can't in gitkraken, but you can Invoke a terminal via the gitkraken alt+t shortcut. It will open a terminal who's current working directory will be the directory that you've cloned the repo into. Then just copy/paste the above code vocx provided.
You ROCK!
Postby Kunda1 » Fri Mar 13, 2020 5:41 pm
You ROCK!
vocx
Postby vocx » Fri Mar 13, 2020 10:14 pm
It will open a terminal who's current working directory ...
Edit: spelling
whose
vocx
Postby vocx » Sat Mar 14, 2020 2:08 am
You ROCK!
Don't use GitKraken, throw away all your graphical interfaces and do it like me, only command line. I use a typewriter powered by hamsters running on a wheel.
Being serious, you don't need much more than gitk, it's already installed with git.
Anyway, I suggest you watch this video, Git Tutorial for Beginners: Command-Line Fundamentals, by Corey Schafer. This guy has many programming tutorials on many topics. He explains things very well, with good practical examples, and has a good voice and pace.
carlopav
Postby carlopav » Sat Mar 14, 2020 7:29 am
Nice channel indeed, give me some time, one year ago i couldn't distinguish the difference between "=" and "==" :roll:
carlopav
Postby carlopav » Mon Mar 16, 2020 9:37 am
Roy_043 wrote: ping
FreeCAD_0.19.20036_x64_LP_12.1.2_PY3QT5-WinVS2015 contains the fix if you want to try it!
Roy_043
Postby Roy_043 » Mon Mar 16, 2020 10:09 am
Roy_043 wrote: ping
The issue has been fixed. Thanks again!
carlopav
Re: [ Fixed ] [ Bug ] Draft problem with coordinate input
Postby carlopav » Mon Mar 16, 2020 10:59 am
good, mark as solved! by the way, do you use the option set focus on lenght instead that on x coordinate?
Roy_043
Postby Roy_043 » Mon Mar 16, 2020 2:29 pm
I haven never done this, but will give it a try.
carlopav
Postby carlopav » Mon Mar 30, 2020 3:41 pm
I think we have the same issue with all other tools: Offset, TrimEx, etc...
