Thanks for taking the time to verify this! (I looked at your code and it seems really clear to me, well done!)
alafr wrote: ↑Wed Apr 15, 2020 10:48 am
However, if the Draft Move command is used to move the Part, the part's placement and the structures' placements are modified, so the total apparent movement is incorrectly doubled. A similar problem happens when I tried moving Structures inside an Arch Building Part. -> it's probably a bug in the Draft Move command?
I think this is related to "MoveWithHost" and "MoveBase" Properties. Draft move tryies to move related object... but it's something that to me we shoud get rid of at some point (but this is just my opinion).
paullee wrote: ↑Tue Apr 28, 2020 8:07 pm
1. Your features have not been merged ?
Not yet, there is still a bug with Structure Nodes that i have to fix...
2. I just test Arch Frame and seem there are much common features there, haven't figured out exactly the usecases ...
I didn't know about Arch Frame. There are indeed a lot of similarities, and except the presences of nodes in the Structures, they appear to share the same usecases.
The property names are completely different (Frame Base = Structure Tool, Frame Profile = Structure Base...), i think this inconsistency is an issue in the Arch Workbench and it will be difficult to solve it without breaking existing objects.
alafr wrote: ↑Sat May 02, 2020 2:02 pm
Thanks, trying to see if ArchStructure can do something like Frame, before that, hope your development will be ready and merged soon
I may observe that those inconsistencies can and should be solved, it's not so complicated to change a property name and provide some backward compatibility code (onDocumentRestored object method can be successfully used to migrate old properties to new ones). Of course this is a delicate topic, and should be planned well...
