New icons for different types of objects
vocx
Post by vocx »
In pull request #3070 I propose an icon for "line" objects, another icon for "regular" shapes, and another icon for "curved" objects. In addition, I propose an icon for "radius or diameter dimensions". In pull requests #3051 and #3058 an icon for "angular dimensions" was already introduced.
My idea is that when you have many such items in the tree view you can glance at it, and find the object that you want more easily, particularly if you change their name (label).
Most Draft objects are instances of the Part_Part2DObject. This has a default icon but you will probably not see it often because this object is never used by itself. You will only see it if something breaks and the document isn't able to load the objects' view provider classes.
The Part_Part2DObjectPython is the Python version of this object; it is normally used with Proxy classes derived from _DraftObject and _ViewProviderDraft, of which the latter assigns the default Draft icon.
import Draft
App.ActiveDocument.addObject("Part::Part2DObject")
obj = App.ActiveDocument.addObject("Part::Part2DObjectPython")
Draft._DraftObject(obj)
Draft._ViewProviderDraft(obj.ViewObject)
Separately, in pull request #3060 I converted all existing icons to have 96 dpi pixel density, and to be "Plain SVG" instead of "Inskcape SVG". Inkscape introduces some non-standard tags, so we prefer to have Plain SVGs to avoid any sort of issues, such as the ones reported with TechDraw.
carlopav
Re: New icons for different types of objects
Post by carlopav »
Wow, this are the kind of small things that improve usability a lot!
vocx wrote: Mon Feb 17, 2020 4:46 am You will only see it if something breaks and the document isn't able to load the objects' view provider classes.
You will see it also if the preference of using part primitives when available is toggled!
vocx
Post by vocx »
carlopav wrote: Mon Feb 17, 2020 6:56 am ...
Mmm... I'm not sure I understand what you mean.
carlopav
Post by carlopav »
nothing important, really: you can use Draft to create directly Part2dShapes (by toggling the option in Draft preferences). Doing so, the Part2dIcon will be displayed.
vocx
Post by vocx »
carlopav wrote: Mon Feb 17, 2020 11:52 am nothing important, really: you can use Draft to create directly Part2dShapes (by toggling the option in Draft preferences). Doing so, the Part2dIcon will be displayed.
"Part2dShapes"? Which is the "Part2dIcon"?
The Draft Preferences have the option of creating "Part Primitives when available". Is this what you mean? How does that relate to the icon of Part_Part2DObject? I'm still lost.
LOL. No offense, but I really want to understand what you mean here. I'm intrigued.
carlopav
Post by carlopav »
Lol.. this was just something stupid... Part icons are shown also if you draw part primitives with draft (it's obvious of course)... Just this
