New Feature: Notch Connector
christi
Postby christi » Sat Feb 29, 2020 3:56 pm
I have written a new tool "Notch Connector". It cuts notches into the overlapping part of two bars
Currently it is in the Curved Shapes workbench, but it does not really fit in there. Maybe the Arch workbench is a better place.
Does anybody want to copy this to another workbench. ? I will then delete it from Curved Shapes.
Reason: Prefixed title for more clarity
Re: New Feature: Notch Connector
Postby Kunda1 » Sat Feb 29, 2020 4:33 pm
This is very cool, as I mentioned in the other thread. Do you mind adding the URL directly to the part of the code in your workbench so devs can access this conveniently?
Postby Kunda1 » Sat Feb 29, 2020 11:47 pm
CurveShapes_NotchConnector.svg
NotchConnector logo (very cool logo)
(22.43 KiB) Downloaded 6 times
Code: https://github.com/chbergmann/CurvedSha ... nnector.py
:bell:
There is a dependency on CurvedShapes though?
see https://github.com/chbergmann/CurvedSha ... tor.py#L13
christi
Postby christi » Sun Mar 01, 2020 6:15 pm
I could do the merging into another workbench. Which one is the best one for this ?
fc_tofu
Postby fc_tofu » Sun Mar 01, 2020 8:31 pm
I am not familiar with boolean tools, but there are some under PartWB.
BTW, Icon style need refinement to keep consistent with PartWB tools.
Postby Kunda1 » Sun Mar 01, 2020 9:03 pm
carlopav
Postby carlopav » Sun Mar 01, 2020 9:16 pm
Part is a peculiar wb, It can probably be considered the core of FreeCAD. It is used all around other FreeCAD wbs to generate object shapes. It's really stable due to wmayer conservative policy. I suggest thinking about other workbenches where to insert this tool ;)
vocx
Postby vocx » Mon Mar 02, 2020 6:57 am
https://github.com/vocx-fc/FreeCAD/tree/Notch
I've put it temporarily in the Draft Workbench, src/Mod/Draft, just because I am refactoring commands with a certain style.
So the notch command is three files, a function to create it and an object class in draftobjects/, a GUI command in draftguitools/, and a view provider in draftviewproviders/.
I think this tool makes more sense in some sort of assembly workbench, or woodworking workbench.
I also don't quite understand why it creates two NotchConnector objects. I didn't test enough, I just wanted to test the structure by placing different parts of the code in different directories.
Postby Kunda1 » Mon Mar 02, 2020 8:47 pm
Thanks @vocx
yorik
Site Admin
Postby yorik » Tue Mar 03, 2020 2:27 pm
I think at some point it could indeed go into Part. There are a few other Python tools in Part too. The only thing I guess is that it needs to be very well compacted into its own, independent, as small as possible set of files...
