Annotation styles for Draft
carlopav
Post by carlopav »
I was thinking about annotations: the properties for label, text, dimensions, are set in preferences, but many times while drafting the user needs to switch froma a text style to another.
So I was thinking about creating a dimension style property, something like Assembly 4 variables, where we can store the dimension style properties. When user duble click it, it set's the annotation parameters according to stored values, so next created annotation will match its properties.
What do you think?
fc_tofu
Re: Annotation styles for Draft
Post by fc_tofu »
carlopav wrote: Tue Mar 10, 2020 3:36 pm I was thinking about annotations: the properties for label, text, dimensions, are set in preferences, but many times while drafting the user needs to switch froma a text style to another.
What do you think?
Generally, I think we need something like Blender "Startup File" or Rhino "Document Properties" in template.
Some settings are better to be saved in project file (user doc) than in app pref (FreeCAD way).
And startup file/template is the place to store default values of doc-related settings.
Roy_043
Post by Roy_043 »
carlopav wrote: Tue Mar 10, 2020 3:36 pm so next created annotation will match its properties.
I think there should be a permanent link between the style and the annotation object. Changing the style should update all objects created with that style.
You could consider something similar to a Draft_VisGroup, where the group controls the properties of the nested elements. This could maybe even become a more generic thing: Std_PropGroup?
carlopav
Post by carlopav »
@fc_tofu
I was thinking about an object exactly because I think annotation style should be saved inside the document.
@roy
I agree we could have a style property in annotations object. But I don't like the style to be a container. We can eventually imagine a command to apply the changed style to all the linked dimensions without having to see them grouped in the tree... Isn't it?
Roy_043
Post by Roy_043 »
I agree, not having to group the elements would be more flexible.
carlopav
Post by carlopav »
Perhaps could be something like this:
def makeDimensionStyle(existing_dimension = None):
    if not FreeCAD.ActiveDocument:
        FreeCAD.Console.PrintError("No active document. Aborting\n")
        return
    obj = FreeCAD.ActiveDocument.addObject("App::FeaturePython","DimensionStyle")
    ViewProviderDraftDimensionStyle(obj.ViewObject, existing_dimension)
    if gui:
        formatObject(obj)
        select(obj)
    return obj
class ViewProviderDraftDimensionStyle(_ViewProviderDraft):
    def __init__(self, obj, existing_dimension = None):
        param = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Draft")
        annotation_scale = param.GetFloat("DraftAnnotationScale", 1.0)
        # annotation properties
        obj.addProperty("App::PropertyFloat","ScaleMultiplier",
                        "Annotation",QT_TRANSLATE_NOOP("App::Property",
                        "Dimension size overall multiplier")
                        ).ScaleMultiplier = 1 / annotation_scale
        # text properties
        obj.addProperty("App::PropertyFont","FontName",
                        "Text",QT_TRANSLATE_NOOP("App::Property","Font name")
                        ).FontName = getParam("textfont","")
        obj.addProperty("App::PropertyLength","FontSize",
                        "Text",QT_TRANSLATE_NOOP("App::Property","Font size")
                        ).FontSize = getParam("textheight",0.20)
        obj.addProperty("App::PropertyLength","TextSpacing",
                        "The spacing between the text and the dimension line")
                        ).TextSpacing = getParam("dimspacing",0.05)
        obj.addProperty("App::PropertyBool","FlipText",
                        "Rotate the dimension text 180 degrees")
        obj.addProperty("App::PropertyVectorDistance","TextPosition",
                        "The position of the text. Leave (0,0,0) for automatic position")
        obj.addProperty("App::PropertyString","Override",
                        "Text override. Use $dim to insert the dimension length")
        # units properties
        obj.addProperty("App::PropertyInteger","Decimals",
                        "Units",QT_TRANSLATE_NOOP("App::Property",
                        "The number of decimals to show")
                        ).Decimals = getParam("dimPrecision",2)
        obj.addProperty("App::PropertyBool","ShowUnit",
                        "Show the unit suffix")
                        ).ShowUnit = getParam("showUnit",True)
        obj.addProperty("App::PropertyString","UnitOverride",
                        "A unit to express the measurement. Leave blank for system default")
        # graphics properties
        obj.addProperty("App::PropertyFloat","LineWidth",
                        "Graphics",QT_TRANSLATE_NOOP("App::Property","Line width")
        obj.addProperty("App::PropertyColor","LineColor",
                        "Graphics",QT_TRANSLATE_NOOP("App::Property","Line color")
        obj.addProperty("App::PropertyLength","ArrowSize",
                        "Graphics",QT_TRANSLATE_NOOP("App::Property","Arrow size")
                        ).ArrowSize = getParam("arrowsize",0.1)
        obj.addProperty("App::PropertyEnumeration","ArrowType",
                        "Graphics",QT_TRANSLATE_NOOP("App::Property","Arrow type")
                        ).ArrowType = arrowtypes
        obj.ArrowType = arrowtypes[getParam("dimsymbol",0)]
        obj.addProperty("App::PropertyBool","FlipArrows",
                        "Rotate the dimension arrows 180 degrees")
        obj.addProperty("App::PropertyDistance","DimOvershoot",
                        "The distance the dimension line is extended past the extension lines")
                        ).DimOvershoot = getParam("dimovershoot",0)
        obj.addProperty("App::PropertyDistance","ExtLines",
                        "Length of the extension lines")
                        ).ExtLines = getParam("extlines",0.3)
        obj.addProperty("App::PropertyDistance","ExtOvershoot",
                        "Length of the extension line above the dimension line")
                        ).ExtOvershoot = getParam("extovershoot",0)
        obj.addProperty("App::PropertyBool","ShowLine",
                        "Shows the dimension line and arrows")
                        ).ShowLine = True
        if existing_dimension:
            vobj = existing_dimension.ViewObject
            obj.ScaleMultiplier = vobj.ScaleMultiplier
            obj.FontSize = vobj.FontSize
            obj.TextSpacing = vobj.TextSpacing
            obj.FontName = vobj.FontName
            obj.ArrowSize = vobj.ArrowSize
            obj.ArrowType = vobj.ArrowType
            obj.ExtLines = vobj.ExtLines
            obj.DimOvershoot = vobj.DimOvershoot
            obj.ExtOvershoot = vobj.ExtOvershoot
            obj.Decimals = vobj.Decimals
            obj.ShowUnit = vobj.ShowUnit
            obj.ShowLine = vobj.ShowLine
        _ViewProviderDraft.__init__(self,obj)
    def doubleClicked(self,vobj):
        print("set current style")
    def setupContextMenu(self,vobj,menu):
        from PySide import QtCore,QtGui
        action1 = QtGui.QAction(QtGui.QIcon(":/icons/Draft_Edit.svg"),"Set current",menu)
        QtCore.QObject.connect(action1,QtCore.SIGNAL("triggered()"),self.set_current)
        menu.addAction(action1)
        action2 = QtGui.QAction(QtGui.QIcon(":/icons/Draft_Edit.svg"),"Apply",menu)
        QtCore.QObject.connect(action2,QtCore.SIGNAL("triggered()"),self.apply_to_related_dimensions)
        menu.addAction(action2)
        action3 = QtGui.QAction(QtGui.QIcon(":/icons/Draft_Edit.svg"),"Apply and override",menu)
        QtCore.QObject.connect(action3,QtCore.SIGNAL("triggered()"),self.override_related_dimensions)
        menu.addAction(action3)
    def set_current(self):
        Sets the current dimension style as default for new created dimensions
        pass
    def apply_to_related_dimensions(self):
        Apply the style to the related dimensions
        pass
    def override_related_dimensions(self):
        Apply the style to the related dimensions and override eventually changed settings
        pass
carlopav
Post by carlopav »
I made a short recognitions of Draft parameters regarding annotations:
        vobj properties         type                        parameter               type
        vobj.ScaleMultiplier"   App::PropertyFloat          "DraftAnnotationScale"  Float
        vobj.FontName           App::PropertyFont           "textfont"              Text
        vobj.FontSize           App::PropertyLength         "textheight"            Float
        vobj.TextSpacing        App::PropertyLength         "dimspacing"            Float
        vobj.Decimals           App::PropertyInteger        "dimPrecision"          Integer
        vobj.ShowUnit           App::PropertyBool
        vobj.UnitOverride       App::PropertyString
        vobj.LineWidth          App::PropertyFloat
        vobj.LineColor          App::PropertyColor
        vobj.ArrowSize          App::PropertyLength         "arrowsize"             Float
        vobj.ArrowType          App::PropertyEnumeration    "dimsymbol"             Integer
        vobj.FlipArrows         App::PropertyBool
        vobj.DimOvershoot       App::PropertyDistance       "dimovershoot"          Float
        vobj.ExtLines           App::PropertyDistance       "extlines"              Float
        vobj.ExtOvershoot       App::PropertyDistance       "extovershoot"          Float
        vobj.ShowLine           App::PropertyBool
Several properties are not stored in preferences, and would be useful:
ShowLine, ShowUnit, LineWidth, LineColor
What about placing new dimension parameters in a dedicated folder "User parameter:BaseApp/Preferences/Mod/Draft/Annotations"?
carlopav
Post by carlopav »
a small mockup:
EDIT: this is the draft commit https://github.com/FreeCAD/FreeCAD/comm ... df229168dc
EDIT2: this would be the first step: the second would be to add a string property to the dimension object to link it to the DimensionStyle Label?
vocx
Post by vocx »
carlopav wrote: Thu Mar 12, 2020 9:37 pm ...
Tons of comments from me in that commit.
By the way, I now think we need an extra directory to put the "make_functions".
draftmake/  # all those functions to make objects
draftobjects/  # the proxy classes that really define the properties of the objects
draftviewproviders/  # the corresponding view provider classes for the above objects
draftguitools/  # the GuiCommands (buttons, menus)
drafttaskpanels/  # the task panel code for the GuiCommands
The idea is that a make_function imports the appropriate classes from draftobjects/ and draftviewproviders/.
# Inside draftmake/make_someobject.py
import FreeCAD as App
from draftobjects.someobject import SomeObject
from draftviewproviders.view_someobject import ViewProviderSomeObject
def make_some_object(arg1, arg2, ...):
    obj = App.ActiveDocument.addObject("App::FeaturePython", "SomeObject")
    SomeObject(obj)
    if App.GuiUp:
        ViewProviderSomeObject(obj.ViewObject)
I think this is what makes the most sense, and would result in neatly organized code.
I will try to do this for the new array commands, but that will take some time because there are still many pull requests pending.
carlopav
Post by carlopav »
Wow, thanks so much for reviewing. I agree to every comment, some changes were already planned but I wanted to setup a prototype before refining the code.
So, code apart, you would agree on a style object for annotations to be guarded in the document?
And what about adding more parameters to handle also dimensions color, lineweight and preferred unit?
EDIT: I was thinkig about a style group, something like the (high detested :twisted: ) new layer object to keep all the properties tidy:
Draft Styles
	|---- Objects
	|	|---- Construction
	|	|---- Section
	|	|---- View
	|	|---- Hidden
	|---- Annotation Styles
		|---- Dimensions Styles
		|	|---- DimensionsStyles1
		|	|---- DimensionsStyles2
		|	|---- DimensionsStyles3
		|---- Label Styles
		|	|---- Room Labels
		|---- Text Styles
			|---- Bold
			|---- Romans
EDIT:
vocx wrote: Fri Mar 13, 2020 6:22 am By the way, I now think we need an extra directory to put the "make_functions".
+1, since we are splitting, let's split to the end
EDIT3: https://github.com/carlopav/FreeCAD/com ... ed276e2b24 this is the updated commit with the cleanup. I still want to add the changes to the dimension object to be able to point to the style, and then we can think about merging it into the PR of Draft Annotation Scales.
