Create walls from Sketch?
I'm quite new to FreeCAD. I've been using it on an off for small things. Every time i learn more and every time i'm more impressed by this tool! Every update is great!
I now want to use FreeCAD to draw some details of the house we live in. I'm using the stable version of the software with the BIM workbench.
I've created a sketch, and would like to create walls from all the lines drawn. However, it only partially creates walls. I'm not sure if this is a bug, or if i'm doing something wrong.
The reason i'd like to use the Sketch is that i like drawing in that. It's easy to create good constraints. The line tools in the Arch workbench are a bit more difficult IMHO (i might not be getting them right though!)
Attacheds are a picture of the Sketch, and also of how it looks in the arch workbench, and then also a pic of what happens when i try to create walls.
I'm here to learn, so feel free to tell me that i'm not doing this right!
- Sketch2.PNG (167.28 KiB) Viewed 3245 times
- Sketch1.PNG (183.86 KiB) Viewed 3245 times
- 3dwalls.PNG (167.98 KiB) Viewed 3245 times
Re: Create walls from Sketch?
Ok, so i couldn't wait and figured out how the snap works so i've drawn draft lines using the snap tool. I've then selected a few lines and created walls.
The walls are not all the same thickness, so i've selected those groups. I've then also joined them together where possible.
Now, because i used snap, there's not always the correct measurements. What's the best way of updating this. Changing the line coordinates? This is why i like the sketches more, as you can go back to them and change them. I think you can do the same with the lines, but it's less practical - maybe i'm missing something?
How will this all impact the existing walls? I've used alignments on the walls to make them align correctly. not sure if this is the best thing to do?
What if i then make a modification. One thing that i need to do is create a bay window at the front of the house. How do i do this if i already created a wall?
- House3.FCStd
- (81.75 KiB) Downloaded 50 times
I use sketch also and trying to develop some tools to assist._cyclops_ wrote: ↑Tue Mar 10, 2020 9:39 pm I've created a sketch, and would like to create walls from all the lines drawn. However, it only partially creates walls. I'm not sure if this is a bug, or if i'm doing something wrong.
Before I could return to my pc to see your file, I guess you have 3 lines connected at 1 point in your sketch. Just do not do that. Will explain more when I have a gap.
Btw, if you use 0.19_pre, there should be a few bug fix and new features relevant.
Window issues later.
BTW, I use mainly Sketch to build the Villa Savoye model, in User Showcase forum, maybe not good for new user. And you can search Regis Youtube for more tutorial in the meantime.
OK, you upload the model with Draft Line as base of Wall.
Maybe you upload you model with Sketch so peoples here can have a look.
As for windows, maybe you make a hand sketch of its appearance. It is not typical Arch Window can do right?
Thanks for helping!
Yes, i moved to the draft lines and started working with that. I didn't save the sketch, so i can't upload it.
I've currently setup rough sizes, but will have to resize some of the items. Because the walls are already joined, can i still just change the underlying line and will that than work? Is that the right way to do it?
I will also give 19_pre a try!
As for the bay windows, i've attached a photo. I guess that explains it
- BayWindow.jpg (223.41 KiB) Viewed 3151 times
Just tried 19._pre and did a sketch. Not exactly the same as i had, but close enough and this works.
i'd really appreciate it if somebody could still answer my previous question around the walls and editing them. I've seen that you can just change the sketch when you use that as the basis of the wall. If that's the way to go, then i'm really happy!
I've answered my own question. If you change the sketch later on, then the walls made from that sketch are updated accordingly!_cyclops_ wrote: ↑Wed Mar 11, 2020 10:00 pm Just tried 19._pre and did a sketch. Not exactly the same as i had, but close enough and this works.
Apparently I've got the same problem, which is strange because, I've created at least one wall from a sketch before without any issues. What's noteworthy is that: with Align set to Left or Right Offset can't be positive. If set above zero an error occurs:
OS: Debian GNU/Linux 10 (buster)
Version: 0.19.15082 (Git)
Branch: debian
Hash: d2b4ed02c8198a1b0d9117ff681e9186d3197f32
Python version: 3.7.3
Qt version: 5.11.3
Locale: Polish/Poland (pl_PL)
11:40:06 Traceback (most recent call last):
File "/usr/share/freecad/Mod/Arch/ArchWall.py", line 788, in execute
extdata = self.getExtrusionData(obj)
File "/usr/share/freecad/Mod/Arch/ArchWall.py", line 1474, in getExtrusionData
f = Part.Face(sh)
<class 'Part.OCCError'>: Argument list signature is incorrect.
Supported signatures:
(face)
(wire)
(face, wire)
(surface, wire)
(list_of_wires)
(wire, facemaker_class_name)
(list_of_wires, facemaker_class_name)
(surface, list_of_wires)
Branch: debian
Qt version: 5.11.3
- sketchy_wall.FCStd
- (9.52 KiB) Downloaded 40 times
I am not sure what the original problem is. But you are using an early V0.19 dev version that is almost 10,000 commits behind. Please upgrade first.
When I open the file and recompute the wall, everything looks fine. And I do not experience the issue with the Offset value you mention.
I am using a version that comes with my OS and I prefer to stick with it for now.
You mean the wall is a cube 2 m by 5 m without top and bottom, right?When I open the file and recompute the wall, everything looks fine.
It's good to know it has been fixed. Thank you for verification.And I do not experience the issue with the Offset value you mention.
