Well, let's be precise: the base is 2mx5m, the wall is centered and has a width of 200mm, so the overall dimensions in plan are 2.2X5.2m.
Create walls from Sketch?
Re: Create walls from Sketch?
- wall-example.png (30.24 KiB) Viewed 1329 times
I use AppImage on Fedora, just download that latest 0.19 release or latest 0.20 weekly build and run it, no need to alter your OS provided installation.
Good luck
Actually, there are only 50 commits between 0.19.1 and git commit 08c3a6b3e709 in src/Mod/Arch and I have found the porblem. It wasn't hard because I created it myself, trying to solve another one. I don't know yet how to fix both, but at least they are diagnosed. Thank you for your help.
Thanks .hunting and fixing the bugs
- ragohix769
Why?
I'd like too to use Sketcher to model the planfoor and then create the walls, but I have some trouble to have different thickness of the wall with sketch and to have loops closed; do you use different sketches or just one master sketch?
It's there any thread or official method/tutorial to design a Floorplan with Sketcher?
[EDIT] ok nevermind, I found this thread to study :
https://forum.freecadweb.org/viewtopic.php?f=23&t=51653
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same
Currently having 3 lines connected to 1 point may have unexpected ArchWall result at the moment due to the underlying mechanism.ragohix769 wrote: ↑Sat Jun 26, 2021 10:16 amWhy?
I'd like too to use Sketcher to model the planfoor and then create the walls, but I have some trouble to have different thinkness of the wall with sketch and to have loops closed; do you use different sketches or just one master sketch?
Having different wall Thickness (and Align) for each edge / Wall Segment of a 'complex' Sketch is bit tricky. Have a look at ArchSketch + ArchWall ( Multiple Width / Individual Align ) = Building Layout Object if you want to try.
Good luck
- ragohix769
I've seen; I'm trying too to find some solid worflow using sketches for floorplan and make then walls, but as you said it's a bit tricky (at least not solid at all).paullee wrote: ↑Sat Jun 26, 2021 4:42 pm
I get used to Sketches through building a few models, and using it extensively, with the help of a few features of an experimental add-on.ragohix769 wrote: ↑Sun Jun 27, 2021 11:17 am I've seen; I'm trying too to find some solid worflow using sketches for floorplan and make then walls, but as you said it's a bit tricky (at least not solid at all).
Maybe you can separately post your model and problems to see if other have a better workflow.
Good luck
