Draft Workbench: Problem editing Polylines - possible Bug
bede
Postby bede » Thu Mar 19, 2020 6:04 pm
I think I encountered a bug. Can anyone please check and confirm?
Version that worked fine: 0.19 Rev 19955 (2020-03-08)
Version with the suspected bug: 0.19 Rev 20052 (2020-03-14), problem appears on both Linux and Windows binaries
Procedure to reproduce:
- Start FreeCAD 0.19 Rev 20052, create new document and switch to Draft workbench.
- From the menu, select "Drafting -> Polyline".
- Draw a polyline with at least 3 points and finish the task (by pressing "A" key) --> new object "Wire" in the model tree view appears.
- Select the Wire object and then from the menu, select "Edit -> Toggle Edit Mode" --> Task view opens.
In the task view, the "Edit" group only shows one button labeled "Close (O)", whereas when doing the same in the older version, I get four buttons: plus-symbol, minus-symbol, finish and close.
PrzemoF
Re: Draft Workbench: Problem editing Polylines - possible Bug
Postby PrzemoF » Thu Mar 19, 2020 6:21 pm
Welcome to the forum!
I couldn't even get that far. I got extreme rubber band problem. Action on the screen was delayed by a few seconds comparing to my input :o
Cay anyone with mouse confirm it? I use a wacom tablet.
OS: Fedora 31 (Workstation Edition) (GNOME/gnome-xorg)
Version: 0.19.pre_20143 (Git)
Build type: Unknown
Python version: 3.7.6
Qt version: 5.13.2
Coin version: 3.1.3
OCC version: 6.9.1.oce-0.18
Locale: Polish/Poland (pl_PL)
bitacovir
Postby bitacovir » Thu Mar 19, 2020 6:49 pm
Yes. I confirm.
OS: Windows 10 (10.0)
Version: 0.19.20052 (Git)
Hash: 6291921e9abe737e4440ff5814ca58547defadef
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
carlopav
Postby carlopav » Thu Mar 19, 2020 6:57 pm
Yes, that's a new feature: since you can edit more objects, the options are no more general, but customized to the edited object!
See the tooltip.
Press "E" or Alt+Click on the desired node or segment to display allowed editing options.
bede
Postby bede » Thu Mar 19, 2020 7:10 pm
Thank you all. Didn't know that new feature. I just tried it out and already like it.
So, now that's an example why we should really stick to the bug submission guideline ;).
carlopav
Postby carlopav » Thu Mar 19, 2020 7:23 pm
Glad you like it!
I plan to add more custom options for objects, it already has for line/polyline/spline, for bezcurves and for arcs and circles.
bitacovir
Postby bitacovir » Thu Mar 19, 2020 7:53 pm
Glad you like it!
Good work. Thanks for the feature. Maybe could you add the sentence in the task panel? So it is more evident the instructions for users. I did not noticed the tooltip.
::bitacovir::
My old Blog
carlopav
Postby carlopav » Thu Mar 19, 2020 9:13 pm
Sure we can do it!
