GSoC Proposal: Extended functionality of Rebar Addon
ebrahim raeyat
Re: GSoC Proposal: Extended functionality of Rebar Addon
Postby ebrahim raeyat » Thu Aug 06, 2020 8:34 am
Suraj Dadral wrote:
Thu Aug 06, 2020 12:06 am
Suggestions are always welcome. :)
thanks @Suraj Dadral. very thanks. it works well. one note:
in column and beam, it is not common to declare span between rebar except for Stirrups. in slab it is common to tell spans.
amrit3701
Postby amrit3701 » Thu Aug 06, 2020 8:56 am
Hello @All
The documentation pages for reinforcement drawing and dimensioning are ready:
Reinforcement Drawing: Arch_Rebar_Drawing
Reinforcement Dimensioning: Arch_Rebar_Dimensioning
Reinforcement Drawing and Dimensioning: Arch_Rebar_Drawing_Dimensioning
Looks good. Nice job!
Suraj Dadral
Postby Suraj Dadral » Thu Aug 06, 2020 1:20 pm
Hi @ebrahim raeyat
Thanks for introducing to the process. :)
As we are not handling dimensioning based on structure type, so this thing needs to be adjusted by user, which is possible while creating drawing and dimensioning and can also be altered after creating drawing and dimensioning.
In future, we can also have special wrapper functions for different structure types if need arises.
Thanks,
ebrahim raeyat
Postby ebrahim raeyat » Thu Aug 06, 2020 8:11 pm
Hi @ebrahim raeyat
Thanks,
thanks, you are right.
balrobs
Postby balrobs » Fri Aug 07, 2020 8:37 am
+1
Hi @Suraj,
BTW, it would be great if users could not only specify the span but also the spacing of the rebars in dimensioning text. Something like "%S/(%M-1)". Would this be possible? I think a lot of users would love this feature.
Thanks and regards!
Suraj Dadral
Postby Suraj Dadral » Sun Aug 09, 2020 10:11 pm
Hi @Suraj,
Hi @balrobs
We can add new placeholder like %s for spacing in rebars.
I will implement it soon. For now, created issue here to track this.
Thanks,
Suraj Dadral
Postby Suraj Dadral » Sun Aug 09, 2020 10:32 pm
Hi @All
Here is update:
1. Create function getRebarShapeSVG() to get rebar shape svg with its dimension.
Sample output:
test_rebar_shape.svg
(1.73 KiB) Downloaded 8 times
2. Create function getRebarShapeCutList() to get rebar shape cut list svg.
Sample Output:
(12.91 KiB) Downloaded 10 times
How to use:
You can get the latest code from here.
import importlib
from xml.etree import ElementTree
import Draft
from RebarShapeCutList import RebarShapeCutListfunc
importlib.reload(RebarShapeCutListfunc)
base_rebars = Draft.get_objects_of_type(
    FreeCAD.ActiveDocument.Objects, "RebarShape"
arch_rebars = Draft.get_objects_of_type(FreeCAD.ActiveDocument.Objects, "Rebar")
rebars = []
rebars.extend(base_rebars)
rebars.extend(arch_rebars)
rebar_shapes_svg = []
for rebar in rebars:
    rebar_shapes_svg.append(
        RebarShapeCutListfunc.getRebarShapeSVG(rebar, scale=0.1)
print(ElementTree.tostring(rebar_shapes_svg[0], encoding="unicode"))
rebar_shape_cut_list = RebarShapeCutListfunc.getRebarShapeCutList()
output_file = "/home/blank/GSoC20/test_rebar_shape.svg"
with open(output_file, "w") as f:
    f.write(ElementTree.tostring(rebar_shape_cut_list, encoding="unicode"))
- The above functions will work for ArchRebar and Rebar2 objects.
- The length of each edge is calculated as there would be no curves as suggested by @bernd here.
Do we also need to add bent angles in the rebar shape cut list, or will we do it in the bar bending schedule?
Please review and give your suggestions.
Thanks,
ebrahim raeyat
Postby ebrahim raeyat » Sun Aug 09, 2020 11:53 pm
Thanks,
Very thanks for your effort, works fine for me. one not:
in my stirrup I gave float point like 357.01 in mm.
amrit3701
Postby amrit3701 » Mon Aug 10, 2020 4:43 pm
Bent angle is part to specify rebar shape. So, I think it should be present in rebar share cut list. But we can skip 90 angle because user can interpret it from rebar shape. Maybe bernd, balrobs and ebrahim tell us better here. :)
balrobs
Postby balrobs » Mon Aug 10, 2020 5:39 pm
I agree with you @amrit3701, whenever we draw the shape of a rebar and its dimensions, we should specify not only the length of the bended part but also either deltaX and deltaY or its bending angle if not equal to 90°.
BTW maybe at this point it might be useful to think about what the rebar shape cut list and the bar bending schedule we want to generate should look like. I believe that standards in this regard differ from country to country.
Kind regards
