GSoC Proposal: Extended functionality of Rebar Addon
Suraj Dadral
Re: GSoC Proposal: Extended functionality of Rebar Addon
Postby Suraj Dadral » Tue Jul 07, 2020 3:19 pm
balrobs wrote:
Tue Jul 07, 2020 1:16 pm
Hi Suraj,
I've tried to test your code but entcountered some problems. After installing your update I created a sample column and tried to launch your commands
in order to create some ReinforcementDrawing.
In the object-tree the single pages (Front, Rear, Left, Right, Top and Bottom) are created but unfortunately don't contain any reinforcement.
What could be the problem here?
Hi @balrobs,
Thanks for investing your time to test. I found the problem.
In config.py file, to get the default template file, I used this code:
# Default Template File for Drawing
TEMPLATE_FILE = FreeCAD.ParamGet(
    "User parameter:BaseApp/Preferences/Mod/TechDraw/Files"
).GetString("TemplateFile")
This is working on my Linux system. But, when I tried it in windows system, then these preference values are not present there.
And due to missing template, the template width and height are having value 0, and thus scaling factor is calculated wrong.
To fix this issue, I copied one template file from TechDraw templates into repository to use as default template.
User can change default template value in config.py file to use any other template file.
commit: https://github.com/SurajDadral/FreeCAD- ... cfe8f8ac0b
Thanks,
balrobs
Postby balrobs » Wed Jul 08, 2020 6:45 am
Hi @Suraj,
I testet your code on my windows-machine and now I'm able to produce ReinforcementViews for my Test-Column. Wow!
Column.FCStd
(89.82 KiB) Downloaded 13 times
After that I created a reinforment plan for my column with a proprietary 2D Cad-software as I'm used to do, just to gave an idea what a column reinforcement plan might look like for me ...
This work brought to my mind several aspects:
- I think it's quite hard to automate the labeling process and get a satisfactory result right away. So additional tools for manipulating and/or adding rebar-labels will become very important.
- It is necessary to provide also the mark-number for the reinforcing bars in the views so that a better understanding can take place.
- Maybe @Bernd 's reinforcement classification (ReinforcementCustom, ReinforcementIndividual, ReinforcementLinear, ReinforcementLattice, ReinforcementGeneric) could be useful for the automated labeling process. This because different types of reinforcements could ask for different types of labels/dimensions.
- Last but not least, we could consider the possibility for future versions of not drawing all but only a few rebars when they are repeatedly laid. For members with a lot of reinforcement (e.g. slabs), this could IMO greatly improve the clarity.
Cheers balrobs!
Suraj Dadral
Postby Suraj Dadral » Wed Jul 08, 2020 2:44 pm
Hello everyone,
An update:
Make reinforcement drawing view object parametric
- Change object name from ReinforcementDrawingContent to ReinforcementDrawingView
- Add structure and Rebars parameter to ReinforcementDrawingView object,
which keeps generated svg content in sync with rebars in model
- Some code improvements
commit: https://github.com/SurajDadral/FreeCAD- ... 10431ec862
Test it using:
from ReinforcementDrawing import make_reinforcement_drawing
make_reinforcement_drawing.makeStructuresReinforcementDrawing(view="Front")
make_reinforcement_drawing.makeStructuresReinforcementDrawing(view="Rear")
make_reinforcement_drawing.makeStructuresReinforcementDrawing(view="Left")
make_reinforcement_drawing.makeStructuresReinforcementDrawing(view="Right")
make_reinforcement_drawing.makeStructuresReinforcementDrawing(view="Top")
make_reinforcement_drawing.makeStructuresReinforcementDrawing(view="Bottom")
Thanks,
Suraj Dadral
Postby Suraj Dadral » Wed Jul 08, 2020 2:49 pm
Hi @Suraj,
Nice!
We definitely need these examples to improve our drawing and dimensioning.
Yes, and we may not need to develop some additional tool for that as to add new labels/dimensions manually, user can use TechDraw workbench as we are storing generated drawing in scripted TechDraw object.
But for manipulating automatically generated dimensions, we need to take care during its implementation.
Yes, the mark number is important. But, for now, we are generating automated drawing and dimensioning for primitive shapes (StraightRebar, Stirrup, etc.) generated using Reinforcement Workbench.
We will be able to support rebar2 objects, when the primitive shapes will be generated using rebar2 objects through Reinforcement Workbench.
So, for Mark number in Arch Rebar objects, we may either add mark property to Rebar objects OR generate Mark number automatically for them as we did in case of Bill Of Material.
Interesting, but looks like this is possible with current implementation also. You can call function "makeReinforcementDrawing()" with few rebars as rebars list.
def makeReinforcementDrawing(
    structure,
    rebars_list,
    view,
    font_family,
    font_size,
    drawing_left_offset,
    drawing_top_offset,
    drawing_min_right_offset,
    drawing_min_bottom_offset,
    drawing_max_width,
    drawing_max_height,
    template_file,
    """makeReinforcementDrawing(Structure, RebarsList, View, FontFamily,
    FontSize, DrawingLeftOffset, DrawingTopOffset, DrawingMinRightOffset,
    DrawingMinBottomOffset, DrawingMaxWidth, DrawingMaxHeight, TemplateFile):
    Generates Reinforcement Drawing SVG view for structure.
    view can be "Front", "Rear", "Left", "Right", "Top" or "Bottom".
    Returns reinforcement drawing view svg.
Thanks,
hardeeprai
Postby hardeeprai » Thu Jul 09, 2020 4:06 am
... future versions of not drawing all but only a few rebars when they are repeatedly laid. For members with a lot of reinforcement (e.g. slabs), this could IMO greatly improve the clarity.
That is he standard way of preparing 2D drawings.
Still current is needed (with improvements).
These may be treated as different views (there may may views, not only two views), and user may select any view as per his requirements.
H.S.Rai
bernd
Postby bernd » Thu Jul 09, 2020 10:24 am
May I ask ... Which software did you use? Was it 2D or 3D reinforcement in this software?
amrit3701
Postby amrit3701 » Thu Jul 09, 2020 11:15 am
    structure,
    rebars_list,
    view,
    font_family,
    font_size,
    drawing_top_offset,
    drawing_max_width,
    drawing_max_height,
    template_file,
Hi @Suraj,
I also able to produced drawing and it is amazing. :D Great works. With the new approach of drawing creation, I think now you have full control of rebars (position, visibility and etc).
After playing with this here are a few suggestions.
  1. As you are producing each view on a single page and automatically calculated scale is fine but when I moved all views to a single page, I unable to set scale. So, there should be some way to set the user custom scale factor.
  2. Same for the position of views, when I move all views in single drawing page and recompute, all view are displaced to the default position.
  3. User must have the option to fill or not fill the structure with colour.
  4. User can set style (stroke width, colour) of rebar, dimension and structure element so that it should be easily differentiated.
I think drawing only must have rebar distribution, rebar labels and structure dimensions. From rebar labels, the user can see each rebar dimensions from rebar cut list.
Screenshot 2020-07-09 at 4.41.06 PM.png (152.04 KiB) Viewed 273 times
test_drawing.FCStd
(137.15 KiB) Downloaded 2 times
Thanks,
balrobs
Postby balrobs » Thu Jul 09, 2020 1:22 pm
Hi @Bernd,
It's a 2D reinforcement software which treats individual reinforcements in the different views according to your RebarShape / RebarDistribution concept and binds logicaly different rebars-rapresentations with same mark-number.
Cheers balrobs
bernd
Postby bernd » Thu Jul 09, 2020 2:36 pm
@balbros: thanks
in the regard of the views ... it should be possible not to show all rebars. See attached side view of a wall. A column would be similar.
Suraj Dadral
Postby Suraj Dadral » Thu Jul 09, 2020 9:58 pm
Hi @Suraj,
Hi @amrit3701,
Its done as per commit: https://github.com/SurajDadral/FreeCAD- ... e0a6de1aba
To set custom scale, you need to set ScaleType property to "Custom" and then you will be able to use custom scaling.
[*] Same for the position of views, when I move all views in single drawing page and recompute, all view are displaced to the default position.
Till now, we are calculating position of rebars by utilizing constraints like LeftOffset, TopOffset, etc. to automatically position drawing on Template.
But, if user wants to set its position manually, then he first need to set property PositionType to "Custom" and then he will be able to set drawing view position by using obj.X and obj.Y attributes or by dragging view in ui.
[*] User must have the option to fill or not fill the structure with colour.
[*] User can set style (stroke width, colour) of rebar, dimension and structure element so that it should be easily differentiated.
[/list]
For dimensions, I will do it when I will start working on dimensioning.
+1
Now, I will start working on it.
After doing above suggested changes, sample outputs:
Thanks,
