GSoC Proposal: Extended functionality of Rebar Addon
Suraj Dadral
Re: GSoC Proposal: Extended functionality of Rebar Addon
Postby Suraj Dadral » Mon Mar 30, 2020 5:26 pm
bernd wrote:
Mon Mar 30, 2020 4:28 pm
The mark will be created automaticlly a new rebar is instanciated. If this exact rebar shape is somewhere (in the group of rebars created for a specific rebar cut list) the mark will be taken from there. If the user does not want it he can imediately overwrites it, or later overwrites it.
That means assigning mark and editing will be done outside the workflow discussed here?
I just need to upgrade rebar addon to use mark after implementation of mark at base rebar object?
Thanks,
bernd
Postby bernd » Mon Mar 30, 2020 5:42 pm
just realized, if rebars are not parametric, there is no structural element at all. Even in this case (which is standard in switzerland 3D rebar modeling, the rebar fits exactly in the concrete model but it does not parametrically depend on it) the rebar shape cut list should be possible.
amrit3701
Postby amrit3701 » Mon Mar 30, 2020 8:29 pm
I suggest we should put parametric rebars at top priority. I think dimensioning to non-parametric rebars (Custom rebar: tool) would not be an easy task as the user can create any shape rebar.
Suraj Dadral
Postby Suraj Dadral » Mon Mar 30, 2020 9:56 pm
Updated workflow mockups:
Workflow for BOM:
Workflow for bar shape cut list:
Workflow for bar bending schedule:
Workflow for automated drawing of reinforcement:
Please review and give your suggestions.
Thanks,
amrit3701
Postby amrit3701 » Tue Mar 31, 2020 9:20 am
Workflow for BOM:
Looks good.
Suraj Dadral
Postby Suraj Dadral » Tue Mar 31, 2020 9:52 am
I also think the same.
We can add new rebar types in future and then implement their bar cut schedule etc.
Thanks,
Suraj Dadral
Postby Suraj Dadral » Tue Mar 31, 2020 9:59 am
Looks good.
Thanks @amrit3701,
I also submitted the final pdf for proposal.
Now, I think I can start coding for Bill Of Material.
I will post updates here.
Thanks,
bernd
Postby bernd » Tue Mar 31, 2020 10:45 am
Great!
I made progress in updateing my rebar code. I will hopfully make it public in the next few days.
Suraj Dadral
Postby Suraj Dadral » Wed Apr 01, 2020 1:10 pm
That's Great.
I also created a function to create BOM spreadsheet.
import FreeCAD
COLUMN_HEADERS = [
    "Member",
    "Mark",
    "No. Of Rebars",
    "Diameter in mm",
    "Length in m/piece",
    "Total Length in m",
COLUMN_DIA_HEADERS = [8, 10, 12, 16, 20]
def addSheetHeaders(spreadsheet):
    # Format cells
    spreadsheet.mergeCells("A1:A2")
    spreadsheet.mergeCells("B1:B2")
    spreadsheet.mergeCells("C1:C2")
    spreadsheet.mergeCells("D1:D2")
    spreadsheet.mergeCells("E1:E2")
        "F1:" + chr(ord("F") + len(COLUMN_DIA_HEADERS) - 1) + "1"
    spreadsheet.setAlignment("F1:J2", "vcenter", "keep")
    spreadsheet.setAlignment("F1:J2", "center", "keep")
    # Add column headers
    spreadsheet.set("A1", COLUMN_HEADERS[0])
    spreadsheet.set("B1", COLUMN_HEADERS[1])
    spreadsheet.set("C1", COLUMN_HEADERS[2])
    spreadsheet.set("D1", COLUMN_HEADERS[3])
    spreadsheet.set("E1", COLUMN_HEADERS[4])
    spreadsheet.set("F1", COLUMN_HEADERS[5])
    for i, dia in enumerate(COLUMN_DIA_HEADERS):
        spreadsheet.set(chr(ord("F") + i) + "2", "#" + str(dia))
def makeBillOfMaterial():
    # Create new spreadsheet object
    bill_of_material = FreeCAD.ActiveDocument.addObject(
        "Spreadsheet::Sheet", "RebarBillOfMaterial"
    addSheetHeaders(bill_of_material)
    # Get Part::FeaturePython objects list
    objects_list = FreeCAD.ActiveDocument.findObjects("Part::FeaturePython")
    # Create rebars list and dictionary with membersas key with corresponding
    # rebars list as value
    rebars_list = []
    members_rebars_dict = {}
    for item in objects_list:
        if hasattr(item, "IfcType"):
            if item.IfcType == "Reinforcing Bar":
                rebars_list.append(item)
                base_obj = item.Base
                if not base_obj:
                    member = "Unknown"
                else:
                    member = base_obj.Support[0][0].Label
                if member not in members_rebars_dict:
                    members_rebars_dict[member] = []
                else:
                    members_rebars_dict[member].append(item)
    # Add data to spreadsheet
    row = 3
    for member in members_rebars_dict:
        bill_of_material.set("A" + str(row), member)
        for rebars in members_rebars_dict[member]:
            bill_of_material.set("C" + str(row), str(rebars.Amount))
            bill_of_material.set("D" + str(row), str(rebars.Diameter))
            bill_of_material.set("E" + str(row), str(rebars.Length))
                chr(ord("F") + COLUMN_DIA_HEADERS.index(rebars.Diameter.Value))
                + str(row),
                str(rebars.TotalLength),
            row += 1
        row += 1
    bill_of_material.setDisplayUnit("E3:E" + str(row), "m")
        "F3:" + chr(ord("F") + len(COLUMN_DIA_HEADERS) - 1) + str(row), "m"
    FreeCAD.ActiveDocument.recompute()
    print("WIP")
How to use:
1. Open model for which we need to calculate BOM for reinforcement.
2. Copy and paste above code into freecad python console.
3. Type `makeBillOfMaterial()` in freecad python console.
Sample model can be found in attachment and here is screenshot of its BOM spreadsheet.
BOM contains columns which are present in BOM file shared by @bernd or in image shared by @hardeep
The length present in BOM is automatically calculated by below function which is already present in ArchRebar.py file of base rebar implementation. Now, do we need to calculate length of rebar shape as @bernd suggested here that it may be tricky task to calculate length of rebar shape?
def getLengthOfRebar(rebar):
    """ getLengthOfRebar(RebarObject): Calculates the length of the rebar."""
    base = rebar.Base
    # When rebar is derived from DWire
    if hasattr(base, "Length"):
        return base.Length
    # When rebar is derived from Sketch
    elif base.isDerivedFrom("Sketcher::SketchObject"):
        length = 0
        for geo in base.Geometry:
            length += geo.length()
        return length
    else:
        FreeCAD.Console.PrintError("Cannot calculate rebar length from its base object\n")
        return None
Thanks,
Suraj.FCStd
(171.29 KiB) Downloaded 10 times
Suraj Dadral
Postby Suraj Dadral » Wed Apr 01, 2020 4:40 pm
In above, I forgot to add total length of rebars at end of BOM.
So, updated code can be found here: https://github.com/SurajDadral/FreeCAD- ... t/tree/BOM
And updated output is:
Suggestions are always welcome.
Thanks,
