GSoC Proposal: Extended functionality of Rebar Addon
Suraj Dadral
Re: GSoC Proposal: Extended functionality of Rebar Addon
Postby Suraj Dadral » Sun Sep 27, 2020 8:23 pm
bernd wrote:
Tue Sep 15, 2020 2:01 pm
find abs files for the 4 examples of rebar2 in rebar2 repo https://github.com/berndhahnebach/rebar ... r/examples
Thanks @bernd
This will be very helpful in implementation of BVBS export, which will be started soon.
And now all work done during GSoC2020 is merged into master branch of "FreeCAD-Reinforcement" repository. :)
Thanks,
Suraj Dadral
Postby Suraj Dadral » Sun Sep 27, 2020 8:27 pm
balrobs wrote:
Tue Sep 15, 2020 10:03 am
Congratulations @Suraj! Thanks for your efforts and the great job done here.
You took the rebar-addon a BIG step further!!
Thanks @balrobs
This would not be possible without the Great suggestions and helping hands by FreeCAD-Community. :D
balrobs
Postby balrobs » Tue Oct 06, 2020 1:39 pm
Hi @Suraj,
Should you ever need an icon for the BVBS export here is my proposal :D
Cheers
bvbs.svg
(15.32 KiB) Downloaded 6 times
Suraj Dadral
Postby Suraj Dadral » Sat Oct 31, 2020 5:11 pm
balrobs wrote:
Mon Sep 07, 2020 9:53 am
One question ... wouldn't it make sense to add the <Reinforcement Drawing>, <Reinforcement Dimensioning> and <Reinforcement Drawing Dimensioning> icons to the reinforcement toolbar?
I think this isn't much work and even if there is not yet a dialog for the user to select all possible options, it would be sufficient to run the standard script for now. I think that otherwise many inexperienced Freecad users, for whom the Python console is a hurdle, will not use this great functionality.
Hi @balrobs
The above suggestion is implemented as per commits: commit1, commit2
Now, Reinforcement icons list looks like (last icon for Reinforcement Drawing Dimensioning):
Clicking on this icon will execute and log command in FreeCAD Python console:
ReinforcementDrawing.make_reinforcement_drawing.makeStructuresReinforcementDrawing(structure_list=None, rebars_list=None, view="Front", rebars_stroke_width=0.35, rebars_color_style="Automatic", rebars_color=(0.67, 0.0, 0.0), structure_stroke_width=0.5, structure_color_style="Automatic", structure_color=(0.3, 0.9, 0.91), drawing_left_offset=20, drawing_top_offset=20, drawing_min_right_offset=20, drawing_min_bottom_offset=20, drawing_max_width=297, drawing_max_height=210, template_file=r"/home/blank/.FreeCAD/Mod/Reinforcement/ReinforcementDrawing/Templates/A4_Landscape_blank.svg", perform_dimensioning=True, dimension_rebars_filter_list=None, dimension_label_format="%M %C⌀%D,span=%S", dimension_font_family="DejaVu Sans", dimension_font_size=3, dimension_stroke_width=0.25, dimension_line_style="Continuous", dimension_line_color=(0.0, 0.0, 0.5), dimension_text_color=(0.0, 0.33, 0.0), dimension_single_rebar_line_start_symbol="None", dimension_single_rebar_line_end_symbol="FilledArrow", dimension_multi_rebar_line_start_symbol="FilledArrow", dimension_multi_rebar_line_end_symbol="FilledArrow", dimension_line_mid_point_symbol="Dot", dimension_left_offset=10, dimension_right_offset=10, dimension_top_offset=10, dimension_bottom_offset=10, dimension_left_offset_increment=6, dimension_right_offset_increment=6, dimension_top_offset_increment=6, dimension_bottom_offset_increment=6, dimension_single_rebar_outer_dim=False, dimension_multi_rebar_outer_dim=True, dimension_single_rebar_text_position_type="StartOfLine", dimension_multi_rebar_text_position_type="MidOfLine")
All default values in above command will be read from config.py file in Reinforcement directory.
This will generate Front view of structures. After that, user can also tweak with command logged into FreeCAD Python console to generate different views and can modify other parameters as required.
Thanks,
Suraj Dadral
Postby Suraj Dadral » Sat Oct 31, 2020 5:14 pm
Hi @Suraj,
Thanks @balrobs for the amazing work. :D
I added reference to above post in this issue related to BVBS implementation to use above icon in BVBS implementation.
Thanks,
balrobs
Postby balrobs » Sat Oct 31, 2020 7:21 pm
Hi @Suraj,
thank you for implementing this! Now hopefully more and more user will use this feature and suggest improvements.
BTW here is mine. Moving generated objects (structure front view and dimensions) within the page, then closing and reopening it or clicking the command "Turn View frames on=off" leads to the result that dimension objects are moved with respect to the structure.
Cheers
balrobs
Postby balrobs » Sun Nov 01, 2020 10:59 am
Hi @Suraj,
i will try to design a dialog for the ReinforcementDrawingDimensioning command. Will come back here when I have something usefull :roll:
Cheers
balrobs
Postby balrobs » Wed Nov 04, 2020 7:32 am
Hi @Suraj,
Cheers
Here is what I reached so far!
In order to make the input of the many parameters clearer, I took inspiration from the input dialog of the Column-Reinforcement and tried to structure all parameters into logical units.
My work can certainly be improved, it's my first dialog design :D ... everyone can feel free to do so
This first part includes the main dialog and the first two secondary dialogs ...
ReinforcementDrawingAndDimensioning_Main.ui
(4.04 KiB) Downloaded 5 times
ReinforcementDrawingAndDimensioning_Shapes.ui
(13.05 KiB) Downloaded 5 times
ReinforcementDrawingAndDimensioning_Drawing.ui
(25.31 KiB) Downloaded 4 times
balrobs
Postby balrobs » Wed Nov 04, 2020 7:37 am
Here is the second part with the next two secondary dialogs ...
Edit: Will upload my last dialog soon, Cheers! :D
Suraj Dadral
Postby Suraj Dadral » Wed Nov 04, 2020 6:02 pm
Hi @balrobs
I tried reproducing above issue, but not able to maybe because I am not able to understand the issue properly. :roll:
May you please share the model before and after the issue.
Thanks,
