GSoC Proposal: Extended functionality of Rebar Addon
carlopav
Re: GSoC Proposal: Extended functionality of Rebar Addon
Postby carlopav » Mon Apr 06, 2020 1:19 pm
Nice, may I suggest for the interface to just put the name of the "Column data" and a checkbox on the left, without a the Hide label, and set all of them checked by default (so user will uncheck what he wants to hide)?
O - Member - Member
It will just look cleaner :)
Suraj Dadral
Postby Suraj Dadral » Mon Apr 06, 2020 9:17 pm
O - Member - Member
Thanks @carlopav for your suggestion.
Implemented above as per commit: https://github.com/SurajDadral/FreeCAD- ... d7d3f76803
Modified UI:
Thanks,
carlopav
Postby carlopav » Mon Apr 06, 2020 9:19 pm
So quick! thanks for your work :)
bernd
Postby bernd » Thu Apr 09, 2020 4:21 am
If your latest wb is installed how do I create a BOM ?
I tried this branch https://github.com/SurajDadral/FreeCAD- ... BOM-rebar2
EDIT: found it. if the correct branch is installed the icon is there.
bernd
Postby bernd » Thu Apr 09, 2020 4:29 am
bernd
Postby bernd » Thu Apr 09, 2020 4:38 am
some remarks:
- mark is an integer
- no. of rebars is integer as well
- is it possible to change the units?
- I prefer diameter in mm (ok), piece length in cm (not ok), and total length in m (ok)
more to come after testing on real data ...
How to get it on a A4 paper?
karansohal875
Postby karansohal875 » Thu Apr 09, 2020 4:33 pm
Hello Suraj!
Thanks for adding BOM, this tool is really useful. :D
I was using BOM and I found that after exporting BOM spreadsheet to CSV file all the units(including m ) were automatically changed to mm again.
Here I'm attaching the screenshots of BOM sheet before
Before exporting.png (80.24 KiB) Viewed 286 times
and after
After exporting.jpg (194.4 KiB) Viewed 286 times
exporting to CSV file.
OS: Windows 10 (10.0)
Version: 0.19.19955 (Git)
Hash: fd907d6d9789f71007b8d0177d167f1de82629b8
Python version: 3.8.2
Qt version: 5.12.5
OCC version: 7.4.0
bernd
Postby bernd » Thu Apr 09, 2020 8:43 pm
tried a real world example ... very cool we have a BOM :)
- the diameter would look much better if rounded on mm as well
- the column count of the rebars for each mark is missing (the manufactor needs to know how many of each marks he should produce)
compared the crane foundation example and th BOM with sharp edges. Still the length is different.
Suraj Dadral
Postby Suraj Dadral » Thu Apr 09, 2020 9:03 pm
some remarks:
Hi @bernd
Implemented solution for above suggestions and made column units configurable through configuration file and ui as per commit: https://github.com/SurajDadral/FreeCAD- ... c2cce32bdf
Modified config file
import FreeCAD
# Units used to display data in Bill Of Material
COLUMN_UNITS = {
    "Diameter": "mm",
    "RebarLength": "m",
    "RebarsTotalLength": "m",
# Column are configurable i.e. you can change Name of column header, change
# their sequence and show/hide column.
# 1. To change column headers, change first value in tuple in below dictionary.
#    e.g. To change column header "Mark" to "Mark Number" replace ("Mark", 1)
#    with ("Mark Number", 1))
# 2. To modify sequence of column, change second value in tuple in below
# dictionary.
#    e.g. To place "Mark" column at third column in BOM, change ("Mark", 1)
#    to ("Mark", 3)
# 3. To hide column, set second value in tuple in below dictionary to 0. And to
#    show column, set it to other than 0 which will be used used as placement
#    sequence number for that column.
#    e.g. to hide column "Mark", replace ("Mark", 1) with ("Mark", 0)
# Note: You must take care that no two columns get same placement number. And
#       must not delete/modify values in LHS of ":" (colon).
COLUMN_HEADERS = {
    "Mark": ("Mark", 1),
    "RebarsCount": ("No. of Rebars", 2),
    "Diameter": ("Diameter in " + COLUMN_UNITS["Diameter"], 3),
    "RebarLength": ("Length in " + COLUMN_UNITS["RebarLength"] + "/piece", 4),
    "RebarsTotalLength": (
        "Total Length in " + COLUMN_UNITS["RebarsTotalLength"],
        5,
# Map diameter (in mm) with weight (kg/m)
# Default list is taken as per book SP34 from here:
# https://archive.org/details/gov.in.is.sp.34.1987/page/n236/mode/2up
DIA_WEIGHT_MAP = {
    6: FreeCAD.Units.Quantity("0.222 kg/m"),
    8: FreeCAD.Units.Quantity("0.395 kg/m"),
    10: FreeCAD.Units.Quantity("0.617 kg/m"),
    12: FreeCAD.Units.Quantity("0.888 kg/m"),
    14: FreeCAD.Units.Quantity("1.206 kg/m"),
    16: FreeCAD.Units.Quantity("1.578 kg/m"),
    18: FreeCAD.Units.Quantity("2.000 kg/m"),
    20: FreeCAD.Units.Quantity("2.466 kg/m"),
    22: FreeCAD.Units.Quantity("2.980 kg/m"),
    25: FreeCAD.Units.Quantity("3.854 kg/m"),
    28: FreeCAD.Units.Quantity("4.830 kg/m"),
    32: FreeCAD.Units.Quantity("6.313 kg/m"),
    36: FreeCAD.Units.Quantity("7.990 kg/m"),
    40: FreeCAD.Units.Quantity("9.864 kg/m"),
    45: FreeCAD.Units.Quantity("12.490 kg/m"),
    50: FreeCAD.Units.Quantity("15.410 kg/m"),
# Type of length to be used in BOM
# It can be "RealLength" or "LengthWithSharpEdges"
REBAR_LENGTH_TYPE = "RealLength"
Modified UI:
If user enter wrong units:
I am planning to export it to svg format, which then can be inserted on A4 paper. And after that a checkbox to add it to techdraw page.
Thanks,
Suraj Dadral
Postby Suraj Dadral » Thu Apr 09, 2020 9:48 pm
Hello Suraj!
Thanks @karansohal875
Here I'm attaching the screenshots of BOM sheet beforeBefore exporting.png and afterAfter exporting.jpg exporting to CSV file.
I found a workaround to do this. We need to set displayed data in each cell by adding ' (single quote) before it.
But there is one limitation with this that we can't modify data units after doing this. So, we need to do this at the end i.e. just before exporting spreadsheet.
I think there might be a better way to do this which I am not aware of as I am new to spreadsheet workbench.
@bernd or other members here may help in this.
Thanks,
