[Closed] 0.19pre DraftWB, "Split" donnot auto-recompute
Version: FreeCAD_0.19.20310-Win-Conda_vc14.x-x86_64.7z
OS: Windows 10 x64
Summary:
DraftWB "Split" command donnot auto-recompute after command.
Reproduce:
1. Restart FC, New document, activate DraftWB.
2. Toggle off snap bar.
3. On Top working plane, draw a line.
4. Select line, click toolbar command "Split"
5. click any position on line.
6. Observe result, the whole line is still there. And a new line object appear on TreeView.
7. If toggle off visibility of whole line, nothing left on viewport. (wrong behavior)
8. If delete whole line, splitted partial line appear on viewport. (wrong behavior)
9. If move whole line, whole line turn to partial line appear on viewport, and another partial line appear on viewport also. (become normal)
OS: Windows 10 x64
Summary:
Reproduce:
Re: 0.19pre DraftWB, "Split" produce wrong behavior
I think the problem is just that the object is not automatically recomputed by the command.
Try to recompute the document after you run the command, and tell us is it worked as expected.
Thank you. After recomputing, I got the correct result of Split.
So the issue is that "Split" now don't auto-recompute after command.
Perhaps vocx already corrected this in his splitting Draft Tools branch.
Ok, then I add "Closed" prefix to op. But hope @vocx would confirm it.
Negative. I'm working on the Creator tools right now, and Split is a Modifier, so it will take a few days to get there. However, the code for Draft_Split is pretty simple; it just uses Draft.split() underneath.
https://github.com/FreeCAD/FreeCAD/blob ... 3440-L3445
def proceed(self, info):
Draft.split(FreeCAD.ActiveDocument.getObject(info["Object"]),
self.point, int(info["Component"][4:]))
if self.call:
self.view.removeEventCallback("SoEvent", self.call)
self.finish()
Thanks, your fix works.
file: [FreeCAD]/Mod/Draft/DraftTools.py
line: from 3438
if self.call:
self.finish()
FreeCAD.ActiveDocument.recompute() #added fix
Re: [Closed] 0.19pre DraftWB, "Split" donnot auto-recompute
Pull request please!
The corrections are included here, #3308. But I still want to add more commits to it.
